[petsc-users] PETSc 3.5.0 build with Hypre
Fri Jul 11 10:25:46 CDT 2014
On Fri, 11 Jul 2014, Wadud Miah wrote:
> Hi Satish,
> The description of --with-fortran-interfaces is:
>   --with-fortran-interfaces=<bool>
>        Generate Fortran interface definitions for PETSc functions  current: 0
> I would like to use PETSc in Fortran 90 programs, so I thought this switch will create Fortran wrappers. Is this the case or have I misunderstood it?
The fortran wrappers are always built [if configured with a fortran compiler]
'Fortran interface definitions' gives you extra type checking for the
subroutine calls - when using a f90 compiler.
However this code can have rough edges - so its not enabled by
default. You can use it - and report if you encounter issues.
  --with-fortran-datatypes=<bool>
       Declare PETSc objects in Fortran like type(Vec) instead of Vec  current: 0
This is experimental - to provide a bit more native f90 coding support
[instead of preprocessing]. And it does not work with --with-fortran-interfaces=1
Satish
> Regards,
> Wadud.
> -----Original Message-----
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: 11 July 2014 16:06
> To: Wadud Miah
> Cc: petsc-users
> Subject: Re: [petsc-users] PETSc 3.5.0 build with Hypre
> > Hello Satish,
> > Thanks for the quick reply. I am also getting the following error when I use the
> > --with-fortran-datatypes=1 flag:
> > Cannot use generated fortran interface definitions with fortran datatypes
> > Any help will be greatly appreciated.
> As the message says - you cannot use --with-fortran-datatypes=1  with --with-fortran-interfaces=1
> Are you sure you need either of these options?
> Satish
> > Regards,
> > Wadud.
> > Sent: 11 July 2014 15:29
> > To: Wadud Miah
> > Cc: petsc-users at mcs.anl.gov
> > > Hello,
> > > I am trying to build PETSc 3.5.0 with Hypre 2.9.0b with the following configure options:
> > > ./configure \
> > > --with-hypre=1 \
> > > --with-hypre-lib=/data/home/eew918/hypre-2.9.0b/lib \
> > This should be: --with-hypre-lib="-L/data/home/eew918/hypre-2.9.0b/lib -lHYPRE"
> > You are probably better off using --download-hypre instead
> > > --with-hypre-include=/data/home/eew918/hypre-2.9.0b/include \
> > > --LDFLAGS="-L/opt/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64 -L/data/home/eew918/hypre-2.9.0b/lib" \
> > > --with-blas-lib="mkl_intel_lp64 mkl_sequential mkl_core" \
> > > --with-lapack-lib="mkl_intel_lp64 mkl_sequential mkl_core" \
> > You can use --with-blas-lapack-lib=/opt/intel/composer_xe_2013_sp1.2.144/mkl  [instead of the above 3 options
> > > --with-fortran-interfaces=1 \
> > > --prefix=$HOME/petsc-3.5.0 \
> > > --with-shared-libraries=1 \
> > > --with-mpi=1 \
> > > --with-mpi-include=/opt/openmpi/1.6.5/intel/13.1/include \
> > > --with-mpi-lib=/opt/openmpi/1.6.5/intel/13.1/lib/libmpi.so
> > You are better off using --with-mpi-dir=/opt/openmpi/1.6.5/intel/13.1 [instead of the above 3 options
> > Satish
> > > But I keep getting the following error message during configure:
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > > --with-hypre-lib=['/data/home/eew918/hypre-2.9.0b/lib'] and
> > > --with-hypre-include=['/data/home/eew918/hypre-2.9.0b/include'] did not work
> > > I see the compilation command with the correct library path (-L/data/home/eew918/hypre-2.9.0b/lib) but no library name with the -l switch.
> > > Regards,
> > > Wadud Miah
> > > Research Computing Services (HPC)
> > > 020 7882 8393
