[petsc-users] fill factor in factorization SLEPC
jifeng zhao jifengzhao2015 at u.northwestern.edu
Fri Jul 4 10:13:28 CDT 2014
Hi Hong,
Thanks a lot. -st_redundant_pc_factor_fill does work for me. And thank you
for presenting how you found the solution. It is helpful.
Cheers,
Jifeng
On Thu, Jul 3, 2014 at 10:34 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> You may try -st_redundant_pc_factor_fill <fill>.
> Here is how I found the option using
> slepc-3.4.4/src/eps/examples/tutorials/ex13.c:
> 1)
> ./ex13 -info | |grep fill
> [0] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.95217 or use
> 2)
> ./ex13 -help |grep fill
>   -st_redundant_pc_factor_fill <5>: Expected non-zeros in factored
> matrix (PCFactorSetFill)
>   -st_redundant_pc_factor_reuse_fill: <FALSE> Use fill from previous
> factorization (PCFactorSetReuseFill)
> i.e., the default fill=5, sufficient for this case. There is no need
> to set as 2.95217. If you want to, do
> ./ex13 -st_redundant_pc_factor_fill 2.95217 -info
> [0] MatLUFactorSymbolic_SeqAIJ(): Reallocs 0 Fill ratio:given 4 needed
> 2.95217
> [0] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.95217);
> As you see, Reallocs 0, good performance.
> Hong
> On Thu, Jul 3, 2014 at 9:45 PM, jifeng zhao
> <jifengzhao2015 at u.northwestern.edu> wrote:
> > Hi all,
> > I am using SLEPC to solve an eigenvalue problem.
> > I tried to add -info at run time. And I get instruction:
> > MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 3.87526 or use
> > MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,3.87526);
> > MatLUFactorSymbolic_SeqAIJ(): for best performance.
> > However, when I tried to add -st_pc_factor_fill 3.87526 at run time. It
> is
> > not recognized at all!
> > WARNING! There are options you set that were not used!
> > WARNING! could be spelling mistake, etc!
> > Option left: name:-st_pc_factor_fill value: 3.87526
> > Same things happened if I tried pc_factor_fill 3.87526
> > Does anybody know how to change the fill of factorization for SLEPC?
> > Thanks,
> > Jifeng Zhao
> > Jifeng Zhao
> > PhD candidate at Northwestern University, US
> > Theoretical and Applied Mechanics Program
Jifeng Zhao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140704/38884c01/attachment.html>
