[petsc-users] fill factor in factorization SLEPC
jifeng zhao jifengzhao2015 at u.northwestern.edu
Thu Jul 3 21:45:32 CDT 2014
Hi all,
I am using SLEPC to solve an eigenvalue problem.
I tried to add -info at run time. And I get instruction:
MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 3.87526 or use
MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,3.87526);
MatLUFactorSymbolic_SeqAIJ(): for best performance.
However, when I tried to add -*st_pc_factor_fill* 3.87526 at run time. It
is not recognized at all!
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-st_pc_factor_fill value: 3.87526
Same things happened if I tried *pc_factor_fill* 3.87526
Does anybody know how to change the fill of factorization for SLEPC?
Jifeng Zhao
Jifeng Zhao
PhD candidate at Northwestern University, US
Theoretical and Applied Mechanics Program
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140703/4558d4bf/attachment.html>
