[petsc-users] KSP: domain decomposition and distribution
mary sweat
mary.sweat78 at yahoo.it
Wed Jan 8 06:37:55 CST 2014
I do not explicitily check the size, because I use PETSC_DECIDE, instead I specify the number of processes. What I really care about is hw does KSPSolve solve the system in a parallel way with multiple processes.
Il Mercoledì 8 Gennaio 2014 12:34, Dave May <dave.mayhem23 at gmail.com> ha scritto:
Please check out the manual page for MatSetSizes()
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetSizes.html
Basically you have two choices:
1/ Define the global size of the matrix and use PETSC_DECIDE for the local sizes.
In this case, PETSc will define the local row size in a manner such that there are approximately the same number of rows on each process.
2/ Define the local sizes yourself and use PETSC_DETERMINE for the global size.
Then you have full control over the parallel layout.
The following functions described by these pages
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetSize.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSize.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetOwnershipRanges.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetOwnershipRangesColumn.html
might also be useful for you in double checking what the matrix decomposition looks like
Cheers,
Dave
On 8 January 2014 12:26, mary sweat <mary.sweat78 at yahoo.it> wrote:
My target is the following. I got a huge linear system with a sparse huge matrix, nothing to deal with PDE. How is the system splitted between processes? is there in this suggested book the answer?
>Thanks again
>Il Martedì 7 Gennaio 2014 17:34, Jed Brown <jedbrown at mcs.anl.gov> ha scritto:
>mary sweat <mary.sweat78 at yahoo.it> writes:
>> Hi all, I need to know how does KSP separate and distribute domain
>> between processes and the way processes share and communicate halfway
>> results. Is there any good documentation about it???
>The communication is in Mat and Vec functions. You can see it
>summarized in -log_summary. For the underlying theory, see Barry's
>book.
>http://www.mcs.anl.gov/~bsmith/ddbook.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140108/9a275281/attachment-0001.html>
