[petsc-users] RCM for ILU?
Jed Brown
jed at jedbrown.org
Tue Feb 18 10:11:44 CST 2014
Qin Lu <lu_qin_2000 at yahoo.com> writes:
> RCM did not help much for my case. This case represents some strong
> connectivities in channels. I am wondering if PETSc has some
> reordering algorithm or solver that is not based on connectivity
> graph, but is based on connectivity strength (such as percolation type
> of reordering). Any information is appreciated. Thanks, Qin
There isn't such an ordering, but it would be a welcome contribution.
One challenge is that features like anisotropy are not necessarily
apparent in the matrix entries. In that case, and for vector-valued
problems, you would ideally use a better strength-of-connection measure.
If you computed a strength-of-connection, then thresholded (or used edge
weights as a "priority"), followed by something like an RCM ordering,
you could find something good for low-fill incomplete factorization in
problems with hidden anisotropy.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140218/3319dc44/attachment.pgp>
