[petsc-users] Trying to apply FieldSplitPC by reading bloc matrix
Barry Smith
bsmith at mcs.anl.gov
Fri Dec 19 18:23:41 CST 2014
In both cases the preconditioned residual is decreasing nicely but the unpreconditioned residual is not decreasing, so something is wrong even in the sequential case!
> 14 KSP preconditioned resid norm 5.169032607321e-10 true resid norm 9.990557312817e-03 ||r(i)||/||b|| 4.162732213674e-04
So you need to go back to the sequential case and see what is going on. Don't even touch the parallel case until the true residual is converging properly for the sequential. First try running with -ksp_pc_side right and watch the residuals. Next run with direct solvers everywhere you can and see what happens.
Barry
> On Dec 19, 2014, at 8:14 AM, Gilles Steiner <gilles.steiner at epfl.ch> wrote:
> Hello Petsc Users,
> I have an issue trying to use FiledSplitPC in parallel.
> My goal : I want to get a linear system from petsc binary files and solve this in parallel with the FieldSplitPC.
> The problem I want to solve is an FE approximation of the Stokes equations.
> Skipping the details, my code looks like :
> // Reading the four blocs UU, UP, PU and PP
> for(int i=0; i < 4; ++i)
> string name = matrix + to_string(i) + ".petscbin";
> PetscViewer PETSC_matreader;
> PetscViewerBinaryOpen(PETSC_COMM_WORLD, name.c_str(), FILE_MODE_READ, &PETSC_matreader);
> MatCreate(PETSC_COMM_WORLD,&PETSC_subA[i]);
> MatLoad(PETSC_subA[i],PETSC_matreader);
> PetscViewerDestroy(&PETSC_matreader);
> // Reading the RHS vector and duplicating it to create the solution vector
> PetscViewerBinaryOpen(PETSC_COMM_WORLD, rhs.c_str(), FILE_MODE_READ, &PETSC_vecreader);
> VecCreate(PETSC_COMM_WORLD,&PETSC_rhs);
> VecLoad(PETSC_rhs,PETSC_vecreader);
> PetscViewerDestroy(&PETSC_vecreader);
> VecDuplicate(PETSC_rhs,&PETSC_sol);
> // Create global matrixwith MatCreateNest
> MatCreateNest(PETSC_COMM_WORLD, 2, NULL, 2, NULL, PETSC_subA, &PETSC_A);
> MatNestGetISs(PETSC_A, PETSC_isg, NULL);
> // Setting up the ksp and precond
> KSPCreate(PETSC_COMM_WORLD,&PETSC_ksp);
> KSPSetOperators(PETSC_ksp,PETSC_A,PETSC_A);
> KSPSetFromOptions(PETSC_ksp);
> KSPGetPC(PETSC_ksp, &PETSC_pc);
> PCSetType(PETSC_pc, PCFIELDSPLIT);
> PCFieldSplitSetIS(PETSC_pc, "0", PETSC_isg[0]);
> PCFieldSplitSetIS(PETSC_pc, "1", PETSC_isg[1]);
> PCSetFromOptions(PETSC_pc);
> // Solving the system and writing back the solution in rhs file
> KSPSolve(PETSC_ksp,PETSC_rhs,PETSC_sol);
> PetscViewer PETSC_vecwriter;
> PetscViewerBinaryOpen(PETSC_COMM_WORLD, rhs.c_str(), FILE_MODE_WRITE, &PETSC_vecwriter);
> VecView(PETSC_sol,PETSC_vecwriter);
> PetscViewerDestroy(&PETSC_vecwriter);
> When I run it with 1 proc, everything works fine and I get the correct solution :
> 0 KSP preconditioned resid norm 1.271697253018e+03 true resid norm 2.400000000000e+01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 5.009545069728e+01 true resid norm 9.166803391041e-02 ||r(i)||/||b|| 3.819501412934e-03
> 2 KSP preconditioned resid norm 6.460631387766e+00 true resid norm 4.995542253831e-02 ||r(i)||/||b|| 2.081475939096e-03
> 3 KSP preconditioned resid norm 1.155895209298e+00 true resid norm 1.515734830704e-02 ||r(i)||/||b|| 6.315561794600e-04
> 4 KSP preconditioned resid norm 7.407384739634e-02 true resid norm 9.992802256200e-03 ||r(i)||/||b|| 4.163667606750e-04
> 5 KSP preconditioned resid norm 1.574456882990e-02 true resid norm 9.994876664681e-03 ||r(i)||/||b|| 4.164531943617e-04
> 6 KSP preconditioned resid norm 2.383022349902e-03 true resid norm 9.990760645581e-03 ||r(i)||/||b|| 4.162816935659e-04
> 7 KSP preconditioned resid norm 6.175379834254e-04 true resid norm 9.990821066459e-03 ||r(i)||/||b|| 4.162842111025e-04
> 8 KSP preconditioned resid norm 6.867982689960e-05 true resid norm 9.990532094790e-03 ||r(i)||/||b|| 4.162721706163e-04
> 9 KSP preconditioned resid norm 1.041091257246e-05 true resid norm 9.990558069113e-03 ||r(i)||/||b|| 4.162732528797e-04
> 10 KSP preconditioned resid norm 1.447793722489e-06 true resid norm 9.990557786778e-03 ||r(i)||/||b|| 4.162732411158e-04
> 11 KSP preconditioned resid norm 2.139317335854e-07 true resid norm 9.990557262754e-03 ||r(i)||/||b|| 4.162732192814e-04
> 12 KSP preconditioned resid norm 4.383129810322e-08 true resid norm 9.990557306920e-03 ||r(i)||/||b|| 4.162732211217e-04
> 13 KSP preconditioned resid norm 3.351461304399e-09 true resid norm 9.990557311707e-03 ||r(i)||/||b|| 4.162732213211e-04
> [14:49:10::INFO ] System Solved. Final tolerance reached is 5.16903e-10 in 14 iterations.
> But if I do it with 2 procs, the resolution seems fine but the solution is wrong :
> 0 KSP preconditioned resid norm 1.247694088756e+03 true resid norm 2.400000000000e+01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 4.481954484303e+01 true resid norm 5.277507840772e-01 ||r(i)||/||b|| 2.198961600321e-02
> 2 KSP preconditioned resid norm 1.110647693456e+01 true resid norm 4.005558168981e-02 ||r(i)||/||b|| 1.668982570409e-03
> 3 KSP preconditioned resid norm 1.220368027409e+00 true resid norm 1.877650834971e-02 ||r(i)||/||b|| 7.823545145714e-04
> 4 KSP preconditioned resid norm 2.834261749922e-01 true resid norm 1.613967205264e-02 ||r(i)||/||b|| 6.724863355265e-04
> 5 KSP preconditioned resid norm 4.215090288154e-02 true resid norm 1.562561614611e-02 ||r(i)||/||b|| 6.510673394212e-04
> 6 KSP preconditioned resid norm 1.209476134754e-02 true resid norm 1.563808960492e-02 ||r(i)||/||b|| 6.515870668718e-04
> 7 KSP preconditioned resid norm 2.038835108629e-03 true resid norm 1.564163643064e-02 ||r(i)||/||b|| 6.517348512765e-04
> 8 KSP preconditioned resid norm 1.928844666836e-04 true resid norm 1.564072761376e-02 ||r(i)||/||b|| 6.516969839065e-04
> 9 KSP preconditioned resid norm 3.138911950605e-05 true resid norm 1.564047323377e-02 ||r(i)||/||b|| 6.516863847403e-04
> 10 KSP preconditioned resid norm 4.950062975470e-06 true resid norm 1.564048216528e-02 ||r(i)||/||b|| 6.516867568865e-04
> 11 KSP preconditioned resid norm 7.677242244159e-07 true resid norm 1.564049253364e-02 ||r(i)||/||b|| 6.516871889019e-04
> 12 KSP preconditioned resid norm 1.870521888617e-07 true resid norm 1.564049269566e-02 ||r(i)||/||b|| 6.516871956526e-04
> 13 KSP preconditioned resid norm 3.077235724319e-08 true resid norm 1.564049264800e-02 ||r(i)||/||b|| 6.516871936666e-04
> 14 KSP preconditioned resid norm 6.584409191524e-09 true resid norm 1.564049264183e-02 ||r(i)||/||b|| 6.516871934095e-04
> 15 KSP preconditioned resid norm 1.091619359913e-09 true resid norm 1.564049263170e-02 ||r(i)||/||b|| 6.516871929874e-04
> [15:10:58::INFO ] System Solved. Final tolerance reached is 1.09162e-09 in 15 iterations.
> Any idea of what is wrong with this ? Is it the code or the base concept ?
> Thank you.
> Gilles
