[petsc-users] Richardson: damping factor=0
Barry Smith
bsmith at mcs.anl.gov
Fri Dec 19 11:04:33 CST 2014
Mark,
Thanks for pointing this out. Perhaps this is a bug, since all the PCApplyRichardson_*() have an (implicit) damping of 1 perhaps we should error out when the damping is not one and one attempts to use a PCApplyRichardson_*().
The current code is questionable since people get a different result then they expect with no explanation why.
Barry
> On Dec 19, 2014, at 9:23 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Oh, SOR probably grabs the iteration ...
> Never mind.
> On Fri, Dec 19, 2014 at 10:20 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Richardson damping factor does not seem to do anything. I set it to zero and the solve was fine.
> Am I missing something?
> Thanks,
> Mark
> Down solver (pre-smoother) on level 3 -------------------------------
> KSP Object: (mg_levels_3_) 1024 MPI processes
> type: richardson
> maximum iterations=4
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> using nonzero initial guess
> using NONE norm type for convergence test
> PC Object: (mg_levels_3_) 1024 MPI processes
> type: sor
> SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
> linear system matrix followed by preconditioner matrix:
> Mat Object: 1024 MPI processes
> type: shell
> rows=33427584, cols=33427584
> type: mpiaij
> total: nonzeros=1.7272e+09, allocated nonzeros=3.4544e+09
> total number of mallocs used during MatSetValues calls =0
> not using I-node (on process 0) routines
