[petsc-users] assemble the matrix on proc 0
Matthew Knepley
knepley at gmail.com
Thu Dec 18 08:21:03 CST 2014
On Thu, Dec 18, 2014 at 8:03 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
> Yes, I did it, like:
> int my_size;
> if(rank == 0)
> my_size = n;
> else
> my_size = 0;
> PetscErrorCode ierr;
> Mat A;
> ierr = MatCreate(PETSC_COMM_WORLD, &A);
> ierr = MatSetSizes(A, my_size, PETSC_DECIDE, n, n);
View the matrix first
ierr = MatView(A, PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
There are a lot of possible mistakes to make. This can help sort it out.
Matt
> Regards,
> Bui
> On 12/18/2014 02:17 PM, Barry Smith wrote:
>> Likely when you set the sizes for the matrix you did not set the
>> local size properly on each process. You need to set the local size to be
>> the complete matrix size on process 0 and 0 on all the other processes.
>> Barry
>> On Dec 18, 2014, at 4:42 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
>>> Hello
>>> I want to assemble petsc matrix from csr matrix on proc 0. I did that
>>> like:
>>> ierr = MatSetType(A, MATMPIAIJ);
>>> ierr = MatMPIAIJSetPreallocation(A, PETSC_DEFAULT, PETSC_NULL,
>>> PETSC_DEFAULT, PETSC_NULL);
>>> on proc 0, I assemble the matrix
>>> for(Ii = Istart; Ii < Iend; ++Ii)
>>> int nz = ia[Ii + 1] - ia[Ii];
>>> ierr = MatSetValues(A, 1, &Ii, nz, &ja[ia[Ii]], &v[ia[Ii]],
>>> INSERT_VALUES);
>>> the other proc also called this code, but input matrix only exists in
>>> proc 0.
>>> The matrix print out correctly:
>>> row 0: (0, 1) (3, 6)
>>> row 1: (1, 10.5)
>>> row 2: (2, 0.015)
>>> row 3: (1, 250.5) (3, -280) (4, 33.32)
>>> row 4: (4, 12)
>>> However, when solved by ksp, it created an error:
>>> [3]PETSC ERROR: Invalid argument
>>> [3]PETSC ERROR: Must be square matrix, rows 0 columns 1
>>> What should be wrong in this case?
>>> Regards,
>>> Bui
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141218/e1c6270c/attachment.html>
