[petsc-users] MPIBAIJ MatMult and non conforming object sizes error on some matrices
Barry Smith
bsmith at mcs.anl.gov
Thu Dec 18 03:35:12 CST 2014
You are setting the local vector size per process without regard to the local size of the matrix
ierr = VecSetSizes(x,m/total_ranks,m);CHKERRQ(ierr); //Force local size instead of PETSC_DECIDE
ierr = VecSetFromOptions(x);CHKERRQ(ierr);
hence the parallel layout of the vector does not match that of the matrix,
The easiest fix is to use MatCreateVecs() (previously called MatGetVecs()) to get an empty vector with the right layout to match that matrix.
Barry
> On Dec 18, 2014, at 2:36 AM, Steena M <stm8086 at yahoo.com> wrote:
> Hello,
> I am loading symmetric sparse matrices (source: Florida sparse matrix database) in binary format, converting it to MPIBAIJ format for executing parallel MatMult. The following piece of code seems to work for most matrices but aborts with a "non conforming object sizes " error for some matrices. For instance, MPIBAIJ MatMult() on a sparse matrix of size 19366x19366 with block size 2 using two MPI ranks:
> [1]PETSC ERROR: Nonconforming object sizes!
> [1]PETSC ERROR: Mat mat,Vec y: local dim 9682 9683!
> Another instance, matrix thermomech_TK with dimensions 102158*102158 with block size 2 using two MPI ranks:
> [1]PETSC ERROR: Mat mat,Vec y: local dim 51078 51079!
> thermomech_TK completes a clean execution with block size 7 without errors. Does this mean that depending on the sparsity pattern of a matrix, compatible block sizes will not always work?
> On a different note: For unsymmetric matrices in MATMULT, in addition to setting "-mat_nonsym", is there a different recommended technique to load matrices?
> PETSc code for the symmetric case is as follows:
> static char help[] = "Parallel SpMV--reads binary matrix file";
> #include <petscmat.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
> Vec x,y;
> Mat A;
> PetscViewer fd;
> int rank, global_row_size, global_col_size,ierr, fd1;
> PetscBool PetscPreLoad = PETSC_FALSE;
> PetscInt fileheader[4];
> char filein[PETSC_MAX_PATH_LEN] ; /*binary .dat matrix file */
> PetscScalar one = 1.0;
> PetscScalar zero = 0.0;
> PetscInt bs;
> int m, n,M,N, total_ranks;
> PetscInitialize(&argc,&args,(char *)0,help);
> MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
> MPI_Comm_size(MPI_COMM_WORLD,&total_ranks);
> PetscPrintf (PETSC_COMM_WORLD,"Total ranks is %d", total_ranks);
> int local_size = m/total_ranks;
> ierr = PetscOptionsGetString(NULL,"-fin",filein,PETSC_MAX_PATH_LEN,NULL); //filename from command prompt
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,filein,FILE_MODE_READ,&fd); //Send it to the petscviewer
> /*Matrix creating and loading*/
> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> ierr = MatSetType(A, MATMPIBAIJ);
> ierr = MatLoad(A,fd);CHKERRQ(ierr);
> ierr = PetscViewerDestroy(&fd);CHKERRQ(ierr);
> /* Vector setup */
> ierr = MatGetSize(A,&m,&n);
> ierr = VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);
> ierr = VecSetType(x,VECMPI);
> ierr = VecCreate(PETSC_COMM_WORLD,&y);CHKERRQ(ierr);
> ierr = VecSetSizes(y,m/total_ranks,m);CHKERRQ(ierr); //Force local size instead of PETSC_DECIDE
> ierr = VecSetFromOptions(y);CHKERRQ(ierr);
> ierr = VecSet(x,one);CHKERRQ(ierr);
> ierr = VecSet(y,zero); CHKERRQ(ierr);
> /* SpMV*/
> ierr = MatMult(A,x,y);CHKERRQ(ierr);
> ierr = VecDestroy(&x);CHKERRQ(ierr);
> ierr = VecDestroy(&y);CHKERRQ(ierr);
> ierr = MatDestroy(&A);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return 0;
