[petsc-users] Adaptive implicit method with PETSC
Wed Dec 17 17:00:17 CST 2014
   AIJ
> On Dec 17, 2014, at 3:59 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> Hi,
> I am trying to find a best way to implement adaptive implicit method (AIM) using PETSc for the linear solver.
> I am solving conservation equations so if I have a N cells problem then I will end of solving a N*M by N*M linear system matrix for each cell has M equations (or variables) when I solve them fully implicitly.  For such system I can use blocked matrix (BAIJ)
> In case each cell has its implicitness level varing from 1 to M so each sub block will have different size range from 1 by to M by M so BAIJ will be very inefficient in both storage and computations I supposed.
> So I am actually thinking if I should reconstruct matrix and using point matrix (AIJ) when implicitness changes but will this also too inefficient for constructing a new matrix?
> So what is the best way for me to implement AIM?
> Kan
