[petsc-users] with hdf5 dir
paul zhang
paulhuaizhang at gmail.com
Wed Dec 17 08:58:17 CST 2014
Hi All,
I attempted to include hdf5 dir in my configuration, but failed.
--with-hdf5-dir=$HDF5PATH
I tried HDF5PATH=/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3, but it shows
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
--with-hdf5-dir=/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3 did not work
As I run $module show hdf5, I got
*/usr/share/Modules/modulefiles/hdf5/1.8.3/icc/default:*
*module-whatis load HDF5 environment *
*prepend-path PATH /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/bin *
*append-path LD_LIBRARY_PATH
/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/lib *
*prepend-path MANPATH
/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/share/man *
*setenv HDF_INCL /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/include *
What is my HDF5PATH?
Paul
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141217/7201e3a3/attachment.html>
