[petsc-users] Hang with Internal Error: Ring ids do not match
Florian Lindner mailinglists at xgm.de
Mon Dec 15 07:12:17 CST 2014
Hello,
since our application has two possible entry paths, petsc could be initialized at different positions. When used as a library (in contrast to a standalone executable), the code looks like:
    PetscErrorCode ierr;
    std::cout << "Petsc before PetscInitializeNoArguments()"  << std::endl;
    ierr = PetscInitializeNoArguments(); CHKERRV(ierr);
    std::cout << "Petsc after PetscInitializeNoArguments()"  << std::endl;
It never get's to "Petsc after..." and instead hangs and prints this error message:
Internal Error: invalid error code 609e0e (Ring ids do not match) in MPIR_Allreduce_impl:712
[0]PETSC ERROR: #1 PetscWorldIsSingleHost() line 99 in /data2/scratch/lindner/petsc/src/sys/utils/pdisplay.c
[0]PETSC ERROR: #2 PetscSetDisplay() line 123 in /data2/scratch/lindner/petsc/src/sys/utils/pdisplay.c
[0]PETSC ERROR: #3 PetscOptionsCheckInitial_Private() line 324 in /data2/scratch/lindner/petsc/src/sys/objects/init.c
[0]PETSC ERROR: #4 PetscInitialize() line 881 in /data2/scratch/lindner/petsc/src/sys/objects/pinit.c
[0]PETSC ERROR: #5 SolverInterfaceImpl() line 120 in src/precice/impl/SolverInterfaceImpl.cpp
Which is somehow incomprehensible for me... What could be the cause for that?
Florian
