[petsc-users] Speedup studies using DMPlex
Thu Dec 11 11:28:42 CST 2014
On Thu, Dec 11, 2014 at 4:45 AM, Justin Chang <jychang48 at gmail.com> wrote:
> I am manually creating a structured tetrahedral mesh within my code and
> using the DMPlexCreateFromDAG function to make a DMPlex out of it. If I go
> with your suggestion, do I simply call DMRefine(...) after the mesh is
> distributed? Because I notice that regular refinement is present in PETSc
> 3.5.2 SNES ex12.c but not in the PETSc developer's version (which I am
> using).
In 3.5.2 the regular refinement code is in there explicitly, but in dev you
can now use the regular mechanism -dm_refine <# times>
     Matt
> Thanks,
> Justin
> On Thu, Dec 11, 2014 at 4:07 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Dec 10, 2014 at 7:34 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> Hi all,
>>> So I am trying to run a speed-up (i.e., strong scaling) study by solving
>>> a diffusion problem much like in SNES ex12.c, and plan on using up to 1k
>>> cores on LANL's Mustang HPC system. However, it seems that DMPlexDistribute
>>> is taking an extremely long time. I am using -petscpartitioner_type
>>> parmetis on command line but it seems to make over 50% of the code
>>> execution time. Is this normal or is there a "better" way to conduct such a
>>> study?
>> 0) What mesh are you using? The most scalable way of running now is to
>> read and distribute a coarse mesh and use regular refinement in parallel.
>> 1) This is pure overhead in the sense that its one-to-many communication,
>> and its done once, so most people do not report the time.
>> 2) I agree its too slow. There is a branch in next that completely
>> reworks distribution. We have run it up to 8K cores on Hector and
>>     it is faster.
>> 3) Early next year we plan to have parallel startup working, where each
>> process reads a chunk of the mesh, and then its redistributes
>>     for load balance.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141211/3a8504b5/attachment-0001.html>
