[petsc-users] how to use external solvers
Sun, Hui hus003 at ucsd.edu
Wed Dec 3 23:54:06 CST 2014
Hello,
I try to use external packages such as umfpack or superlu, which are listed here:  http://www.mcs.anl.gov/research/projects/petsc/documentation/linearsolvertable.html
I have PETSc compiled and installed with those external packages. Presumably I think to use umfpack would be simply to specify an option in the command line arguments. However, I had a hard time finding the correct option. How can I look it up? Thank you.
Best,
Hui
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141204/a470db93/attachment.html>
