[petsc-users] Dumping KSP solve information to a file
Patrick Sanan patrick.sanan at gmail.com
Wed Dec 3 19:26:48 CST 2014
I'd like to be able to obtain and process post-solve information about
KSP solves, after a PETSc application has run.  Specifically, I would
like the information produced by -ksp_converged_reason, as well as the
final residual norm, to be available as a file for post-processing.
A direct approach is to modify the application source, adding my own
code invoking KSPGetIterationNumber(), KSPGetConvergedReason(),
KSPGetResidualNorm(), etc. to the source, and producing the required
output with an ASCII viewer.
However, it'd be more convenient to be able to obtain the required
information without modifying the application source. An inelegant and
potentially fragile approach is to provide flags like
-ksp_converged_reason, -ksp_monitor, etc. and write a script to extract
the required information from what is dumped to stdout.
My first thought on how to do things properly is to link in my own
custom KSP viewer; should that be a viable approach? Is there a
simpler/better method?
-Patrick
