[petsc-users] can't find PETSc package
paul zhang
paulhuaizhang at gmail.com
Mon Dec 1 21:44:28 CST 2014
Sounds like a warning, is it serious?
-- Performing Test MULTIPASS_TEST_2_petsc_works_allincludes
-- Performing Test MULTIPASS_TEST_2_petsc_works_allincludes - Success
-- PETSc requires extra include paths, but links correctly with only
interface libraries. This is an unexpected configuration (but it seems to
work fine).
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
On Mon, Dec 1, 2014 at 10:41 PM, paul zhang <paulhuaizhang at gmail.com> wrote:
> Problem solved!
> This is a baby step for me. I actually have a code project which works
> with petsc-3.1-p8, and configured with Cmake. As I attempted to update
> PETSc, my old configuration flag never works. I have to start it over.
> Thanks a lot.
> Paul
> On Mon, Dec 1, 2014 at 10:28 PM, Jed Brown <jed at jedbrown.org> wrote:
>> paul zhang <paulhuaizhang at gmail.com> writes:
>> > Like this? still in trouble though...
>> > CMAKE_MINIMUM_REQUIRED(VERSION 2.8)
>> > set(PETSC_DIR /home/hzh225/LIB_CFD/nP/petsc-3.5.2)
>> If you're going to manually set local paths in your build files, then
>> CMake is definitely a waste of time. These are normally environment
>> variables.
>> > set(PETSC_ARCH /home/hzh225/LIB_CFD/nP/petsc-3.5.2/linux-gnu-intel)
>> This is not how PETSC_ARCH works. It should probably be
>> "linux-gnu-intel". Please read what PETSc's build prints or read the
>> documentation.
>> http://www.mcs.anl.gov/petsc/documentation/installation.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/0385aae6/attachment.html>
