[petsc-users] running error
Jed Brown
jed at jedbrown.org
Mon Dec 1 15:18:19 CST 2014
paul zhang <paulhuaizhang at gmail.com> writes:
> Hi Jed,
> Does this mean I've passed the default test?
It's an MPI test. Run this to see if PETSc solvers are running correctly:
make PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2 PETSC_ARCH=linux-gnu-intel test
> Is the "open matplotlib " an issue?
No, it's just a Python library that would be used to create a nice
figure if you had it installed.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/4d3a0826/attachment.pgp>
