[petsc-users] interpolate staggered grid values in parallel
    Bishesh Khanal
    bisheshkh at gmail.com
    Mon Dec  1 14:42:18 CST 2014
On Wed, Nov 26, 2014 at 10:13 PM, Bishesh Khanal <bisheshkh at gmail.com>
wrote:
> On Tue, Nov 25, 2014 at 6:40 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Nov 25, 2014 at 11:36 AM, Bishesh Khanal <bisheshkh at gmail.com>
>> wrote:
>>> Dear all,
>>> I'm solving a system using petsc and I get a global Vec, say X . It uses
>>> DMDA with 4 dofs (3 velocity + 1 pressure). X contains velocity at the cell
>>> faces since I solve using staggered grid.
>>> Now I'd like to create one array for velocity with values at cell
>>> centers and another array for pressure (not the Vec so that I can send the
>>> pointer to the array to other part of the code that does not use Petsc).
>>> Currently what I do is :
>>> ------ Vec               X, X_local;
>>> ------ PetscScalar  *X_array;
>>> // Scatter X to X_local and then use:
>>> ------- VecGetArray(X_local, &X_array)
>>> And then have a function, say
>>> getVelocityAt(x, y, z, component) {
>>> // interpolate velocity at (x,y,z) cell center using X_array
>>> The function getVelocityAt() gets called from outside petsc in a loop
>>> over all (x,y,z) positions.
>>> This is not done in parallel.
>>> Now, how do I use Petsc to instead interpolate the cell center
>>> velocities in parallel and store it
>>> in an array say
>>> PetscScalar *X_array_cellCenter;
>>> This would need to have size one less along each axis compared to the
>>> orginal DMDA size.
>>> This way I intend to return X_array_cellCenter to the code outside Petsc.
>> SNES ex30 is an example of a staggered grid code using DMDA. It does this
>> kind of interpolation,
>> and puts the result in a Vec.
> After looking at the example, I tried the following but I have a problem:
> The idea I take from the e.g is to use DMDALocalInfo *info to get local
> grid coordinates and use for loop to iterate through local grid values
> that are
> available in the Field **x array to do the interpolation.
> Here is what I tried in my case where I get the solution from a ksp
> attached to a dmda:
> // Get the solution to Vec x from ksp.
> // ksp is attached to DMDA da which has 4 dofs: vx,vy,vz,p;
> KSPGetSoution(ksp, &x);
> //x has velocity solution in faces of the cell.
> //Get the array from x:
> Field ***xArray;   //Field is a struct with 4 members: vx,vy,vz and p.
> DMDAGetVectorArray(da,xVec,&xArray);
> //Now I want to have a new array to store the cell center velocity values
> //by interpolating from xArray.
> DMCreateGlobalVector(daV, &xC); //daV has same size as da but with dof=3
> FieldVelocity ***xCArray;  //FieldVelocity is a struct with 3 members:
> vx,vy and vz.
> DMDAVecGetArray(daV,xC,&xCArray);
> //Do the interpolation
> DMDAGetLocalInfo(da,&info);
> for (PetscInt k=info.zs; k<info.zs+info.zm; ++k) {
>   for (PetscInt j=info.ys; j<info.ys+info.ym; ++j) {
>     for (PetscInt i=info.xs; i<info.xs+info.xm; ++i) {
>         //do interpolation which requires access such as:
>     if(i==0 || j==0 || k==0) {
>         xCArray[k][j][i].vx = 0; //boundary condition;
>         xCArray[k][j][i].vy = 0;
>         xCArray[k][j][i].vz = 0
>     } else {
>         xCArray[k][j][i].vx = 0.5*(xArray[k][j][i].vx +
> xArray[k][j][i-1].vx);
>         xCArray[k][j][i].vy = 0.5*(xArray[k][j][i].vy +
> xArray[k][j][i-1].vy);
>         xCArray[k][j][i].vz = 0.5*(xArray[k][j][i].vz +
> xArray[k][j][i-1].vz);
> I get runtime error within this loop.
> What am I doing wrong here ?
Ok, I now see that KSPGetSolution(ksp, &x) gives a GLOBAL vector in x and
not a local vector; hence the runtime memory error above since I can't
access ghost values in indices such as [i-1] wth the global vec.
Was there any reason not to make this information explicit in the docs to
prevent the confusion I had ? Or should it have been obvious to me and that
I'm missing something here ?
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPGetSolution.html
Thanks
>>   Thanks,
>>      Matt
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/afa3806a/attachment.html>
