[petsc-users] Assembling a matrix for a DMComposite vector
Anton Popov
popov at uni-mainz.de
Tue Apr 29 04:14:12 CDT 2014
On 4/29/14 7:07 AM, Anush Krishnan wrote:
> Hi all,
> I created a DMComposite using two DMDAs (representing the x and y
> components of velocity in a 2-D staggered cartesian grid used for CFD
> simulations). DMCompositeGetISLocalToGlobalMappings gives me the
> global indices of the elements and ghost cells, which I can use to set
> up a matrix that operates on the vector created with the DMComposite.
> I obtain the correct global indices for all the interior points. But
> when I look at the global indices of the ghost cells, the ones outside
> the domain from the x-component DM return -1, but the ones outside the
> domain from the y-component DM return a positive value (which seems to
> be the largest global index of the interior points on Process 0). My
> question is: Why do they not return -1? Wouldn't that make matrix
> assembly easier (since MatSetValues ignores negative indices)? I have
> attached a code which demonstrates the above.
> On a related note: Is it possible to use MatSetValuesStencil for
> assembling a block diagonal matrix that operates on a vector created
> using the above DMComposite?
> Thanks,
> Anush
You can do the whole thing much easier (to my opinion).
Since you created two DMDA anyway, just do:
- find first index on every processor using MPI_Scan
- create two global vectors (no ghosts)
- put proper global indicies to global vectors
- create two local vectors (with ghosts) and set ALL entries to -1 (to
have what you need in boundary ghosts)
- call global-to-local scatter
Done!
The advantage is that you can access global indices (including ghosts)
in every block using i-j-k indexing scheme.
I personally find this way quite easy to implement with PETSc
Anton
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140429/083813c4/attachment-0001.html>
