[petsc-users] infinite loop with NEWTONTR?
Sun Apr 27 23:34:21 CDT 2014
  I have run your code. I changed to use -snes_type newtonls and also -snes_mf_operator  there is something wrong with your Jacobian:
  Without -snes_mf_operator
 0 SNES Function norm 1.821611413735e+03
    0 KSP Residual norm 1821.61
    Linear solve converged due to CONVERGED_ITS iterations 1
    Linear solve converged due to CONVERGED_RTOL iterations 1
    1 KSP Residual norm 0.000167024
    2 KSP Residual norm 7.66595e-06
    3 KSP Residual norm 4.4581e-07
    4 KSP Residual norm 3.77537e-08
    5 KSP Residual norm 2.20453e-09
    6 KSP Residual norm 1.711e-10
  Linear solve converged due to CONVERGED_RTOL iterations 6
with -snes_mf_operator
    1 KSP Residual norm 1796.39
    2 KSP Residual norm 1786.2
    3 KSP Residual norm 1741.11
    4 KSP Residual norm 1733.92
    5 KSP Residual norm 1726.57
    6 KSP Residual norm 1725.35
    7 KSP Residual norm 1723.89
    8 KSP Residual norm 1715.41
    9 KSP Residual norm 1713.72
   10 KSP Residual norm 1702.84
  This means your Jacobian is wrong. Your first order of business is to fix your Jacobian. I noticed in previous emails your discussion with Jed about switching to MatGetLocalSubMatrix() and using -snes_type test  YOU NEED TO DO THIS. You will get no where with an incorrect Jacobian. You need to fix your Jacobian before you do anything else! No amount of other options or methods will help you with a wrong Jacobian! Once you have a correct Jacobian if you still have convergence problems let us know and we can make further suggestions.
  Barry
On Apr 25, 2014, at 7:31 AM, Norihiro Watanabe <norihiro.w at gmail.com> wrote:
> Hi,
> In my simulation, nonlinear solve with the trust regtion method got stagnent after linear solve (see output below). Is it possible that the method goes to inifite loop? Is there any parameter to avoid this situation?
>   0 SNES Function norm 1.828728087153e+03
>     0 KSP Residual norm 91.2735
>     Linear solve converged due to CONVERGED_RTOL iterations 3
>     1 KSP Residual norm 3.42223
>   Linear solve converged due to CONVERGED_STEP_LENGTH iterations 1
> Thank you in advance,
> Nori
