[petsc-users] Structured multi-block topology
Mark Lohry mlohry at gmail.com
Fri Apr 25 13:31:49 CDT 2014
To resurrect this thread:
https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2012-August/014930.html
Matt Knepley suggested the correct way to handle a structred
multi-block mesh was to use DMComposite. I'm not seeing anything in
the documentation about how to properly use DMComposite, however.
What are the necessary steps to go from a single-block code using DMDA
to a multi-block code that handles all the appropriate data passing at
block boundaries?
