[petsc-users] Convergence_Eigenvalues_k=3
Oo wumeng07maths at qq.com
Fri Apr 25 07:33:10 CDT 2014
Here is output when I used -ksp_view.
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=200, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=200, initial guess is zero
  tolerances:  relative=0.0001, absolute=0.0001, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: icc
    0 levels of fill
    tolerance for zero pivot 2.22045e-14
    using Manteuffel shift [POSITIVE_DEFINITE]
    matrix ordering: natural
    factor fill ratio given 1, needed 1
      Factored matrix follows:
        Matrix Object:         1 MPI processes
          type: seqsbaij
          rows=384, cols=384
          package used to perform factorization: petsc
          total: nonzeros=2560, allocated nonzeros=2560
          total number of mallocs used during MatSetValues calls =0
              block size is 1
  linear system matrix = precond matrix:
    type: seqaij
    rows=384, cols=384
    total: nonzeros=4736, allocated nonzeros=147456
      using I-node routines: found 96 nodes, limit used is 5
Meng
------------------ Original ------------------
Send time: Friday, Apr 25, 2014 6:22 PM
To: "Oo      "<wumeng07maths at qq.com>;
Cc: "Barry Smith"<bsmith at mcs.anl.gov>; "petsc-users"<petsc-users at mcs.anl.gov>;
Subject:  Re: [petsc-users] Convergence_Eigenvalues_k=3
On Fri, Apr 25, 2014 at 4:13 AM, Oo <wumeng07maths at qq.com> wrote:
What I can do for solving this linear system?
I am guessing that you are using the default GMRES/ILU. Run with -ksp_view to confirm.
 We would have to know something about the linear system to suggest improvements.
    Matt
 At this moment,
I use the common line "/Users/wumeng/MyWork/BuildMSplineTools/bin/msplinePDE_PFEM_2 -ksp_gmres_restart 200 -ksp_max_it 200 -ksp_monitor_true_residual -ksp_monitor_singular_value"
The following are the output:
  0 KSP preconditioned resid norm 7.463734841673e+00 true resid norm 7.520241011357e-02 ||r(i)||/||b|| 1.000000000000e+00
  0 KSP Residual norm 7.463734841673e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP preconditioned resid norm 3.449001344285e-03 true resid norm 7.834435231711e-05 ||r(i)||/||b|| 1.041779807307e-03
  1 KSP Residual norm 3.449001344285e-03 % max 9.999991695261e-01 min 9.999991695261e-01 max/min 1.000000000000e+00
  2 KSP preconditioned resid norm 1.811463883605e-05 true resid norm 3.597611565181e-07 ||r(i)||/||b|| 4.783904611232e-06
  2 KSP Residual norm 1.811463883605e-05 % max 1.000686014764e+00 min 9.991339510077e-01 max/min 1.001553409084e+00
  0 KSP preconditioned resid norm 9.374463936067e+00 true resid norm 9.058107112571e-02 ||r(i)||/||b|| 1.000000000000e+00
  0 KSP Residual norm 9.374463936067e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP preconditioned resid norm 2.595582184655e-01 true resid norm 6.637387889158e-03 ||r(i)||/||b|| 7.327566131280e-02
  1 KSP Residual norm 2.595582184655e-01 % max 9.933440157684e-01 min 9.933440157684e-01 max/min 1.000000000000e+00
  2 KSP preconditioned resid norm 6.351429855766e-03 true resid norm 1.844857600919e-04 ||r(i)||/||b|| 2.036692189651e-03
  2 KSP Residual norm 6.351429855766e-03 % max 1.000795215571e+00 min 8.099278726624e-01 max/min 1.235659679523e+00
  3 KSP preconditioned resid norm 1.883016084950e-04 true resid norm 3.876682412610e-06 ||r(i)||/||b|| 4.279793078656e-05
  3 KSP Residual norm 1.883016084950e-04 % max 1.184638644500e+00 min 8.086172954187e-01 max/min 1.465017692809e+00
  0 KSP preconditioned resid norm 1.414935390756e+03 true resid norm 1.787617427503e+01 ||r(i)||/||b|| 1.000000000000e+00
  0 KSP Residual norm 1.414935390756e+03 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP preconditioned resid norm 1.384179962960e+03 true resid norm 1.802958083039e+01 ||r(i)||/||b|| 1.008581621157e+00
  1 KSP Residual norm 1.384179962960e+03 % max 1.895999321723e+01 min 1.895999321723e+01 max/min 1.000000000000e+00
  2 KSP preconditioned resid norm 1.382373771674e+03 true resid norm 1.813982830244e+01 ||r(i)||/||b|| 1.014748906749e+00
  2 KSP Residual norm 1.382373771674e+03 % max 3.551645921348e+01 min 6.051184451182e+00 max/min 5.869340044086e+00
  3 KSP preconditioned resid norm 1.332723893134e+03 true resid norm 1.774590608681e+01 ||r(i)||/||b|| 9.927127479173e-01
  3 KSP Residual norm 1.332723893134e+03 % max 5.076435191911e+01 min 4.941060752900e+00 max/min 1.027397849527e+01
  4 KSP preconditioned resid norm 1.093788576095e+03 true resid norm 1.717433802192e+01 ||r(i)||/||b|| 9.607390125925e-01
  4 KSP Residual norm 1.093788576095e+03 % max 6.610818819562e+01 min 1.960683367943e+00 max/min 3.371691180560e+01
  5 KSP preconditioned resid norm 1.077330470806e+03 true resid norm 1.750861653688e+01 ||r(i)||/||b|| 9.794386800837e-01
  5 KSP Residual norm 1.077330470806e+03 % max 7.296006568006e+01 min 1.721275741199e+00 max/min 4.238720382432e+01
  6 KSP preconditioned resid norm 1.021951470305e+03 true resid norm 1.587225289158e+01 ||r(i)||/||b|| 8.878998742895e-01
  6 KSP Residual norm 1.021951470305e+03 % max 7.313469782749e+01 min 1.113708844536e+00 max/min 6.566769958438e+01
  7 KSP preconditioned resid norm 8.968401331418e+02 true resid norm 1.532116106999e+01 ||r(i)||/||b|| 8.570715878170e-01
  7 KSP Residual norm 8.968401331418e+02 % max 7.385099946342e+01 min 1.112940159952e+00 max/min 6.635666689088e+01
  8 KSP preconditioned resid norm 8.540750681178e+02 true resid norm 1.665367409583e+01 ||r(i)||/||b|| 9.316128741873e-01
  8 KSP Residual norm 8.540750681178e+02 % max 9.333712052307e+01 min 9.984044777583e-01 max/min 9.348627996205e+01
  9 KSP preconditioned resid norm 8.540461721597e+02 true resid norm 1.669107313551e+01 ||r(i)||/||b|| 9.337049907166e-01
  9 KSP Residual norm 8.540461721597e+02 % max 9.673114572055e+01 min 9.309725017804e-01 max/min 1.039033328434e+02
 10 KSP preconditioned resid norm 8.540453927813e+02 true resid norm 1.668902252063e+01 ||r(i)||/||b|| 9.335902785387e-01
 10 KSP Residual norm 8.540453927813e+02 % max 9.685490817256e+01 min 8.452348922200e-01 max/min 1.145893396783e+02
 11 KSP preconditioned resid norm 7.927564518868e+02 true resid norm 1.671721115974e+01 ||r(i)||/||b|| 9.351671617505e-01
 11 KSP Residual norm 7.927564518868e+02 % max 1.076430910935e+02 min 8.433341413962e-01 max/min 1.276399066629e+02
 12 KSP preconditioned resid norm 4.831253651357e+02 true resid norm 2.683431434549e+01 ||r(i)||/||b|| 1.501121768709e+00
 12 KSP Residual norm 4.831253651357e+02 % max 1.079017603981e+02 min 8.354112427301e-01 max/min 1.291600530124e+02
 13 KSP preconditioned resid norm 4.093462051807e+02 true resid norm 1.923302214627e+01 ||r(i)||/||b|| 1.075902586894e+00
 13 KSP Residual norm 4.093462051807e+02 % max 1.088474472678e+02 min 6.034301796734e-01 max/min 1.803811790233e+02
 14 KSP preconditioned resid norm 3.809274390266e+02 true resid norm 2.118308925475e+01 ||r(i)||/||b|| 1.184990083943e+00
 14 KSP Residual norm 3.809274390266e+02 % max 1.104675729761e+02 min 6.010582938812e-01 max/min 1.837884513045e+02
 15 KSP preconditioned resid norm 2.408316705377e+02 true resid norm 1.238065951026e+01 ||r(i)||/||b|| 6.925788101960e-01
 15 KSP Residual norm 2.408316705377e+02 % max 1.215487322437e+02 min 5.131416858605e-01 max/min 2.368716781211e+02
 16 KSP preconditioned resid norm 1.979802937570e+02 true resid norm 9.481184679187e+00 ||r(i)||/||b|| 5.303810834083e-01
 16 KSP Residual norm 1.979802937570e+02 % max 1.246827043503e+02 min 4.780929228356e-01 max/min 2.607917799970e+02
 17 KSP preconditioned resid norm 1.853329360151e+02 true resid norm 9.049630342765e+00 ||r(i)||/||b|| 5.062397694011e-01
 17 KSP Residual norm 1.853329360151e+02 % max 1.252018074901e+02 min 4.612413672912e-01 max/min 2.714453133841e+02
 18 KSP preconditioned resid norm 1.853299943955e+02 true resid norm 9.047741838474e+00 ||r(i)||/||b|| 5.061341257515e-01
 18 KSP Residual norm 1.853299943955e+02 % max 1.256988083109e+02 min 4.556318323953e-01 max/min 2.758780211867e+02
 19 KSP preconditioned resid norm 1.730151601343e+02 true resid norm 9.854026387827e+00 ||r(i)||/||b|| 5.512379906472e-01
 19 KSP Residual norm 1.730151601343e+02 % max 1.279580192729e+02 min 3.287110716087e-01 max/min 3.892720091436e+02
 20 KSP preconditioned resid norm 1.429145143492e+02 true resid norm 8.228490997826e+00 ||r(i)||/||b|| 4.603049215804e-01
 20 KSP Residual norm 1.429145143492e+02 % max 1.321397322884e+02 min 2.823235578054e-01 max/min 4.680435926621e+02
 21 KSP preconditioned resid norm 1.345382626439e+02 true resid norm 8.176256473861e+00 ||r(i)||/||b|| 4.573829024078e-01
 21 KSP Residual norm 1.345382626439e+02 % max 1.332774949926e+02 min 2.425224324298e-01 max/min 5.495470817166e+02
 22 KSP preconditioned resid norm 1.301499631466e+02 true resid norm 8.487706077838e+00 ||r(i)||/||b|| 4.748055119207e-01
 22 KSP Residual norm 1.301499631466e+02 % max 1.334143594976e+02 min 2.077893364534e-01 max/min 6.420654773469e+02
 23 KSP preconditioned resid norm 1.260084835452e+02 true resid norm 8.288260183397e+00 ||r(i)||/||b|| 4.636484325941e-01
 23 KSP Residual norm 1.260084835452e+02 % max 1.342473982017e+02 min 2.010966692943e-01 max/min 6.675764381023e+02
 24 KSP preconditioned resid norm 1.255711443195e+02 true resid norm 8.117619099395e+00 ||r(i)||/||b|| 4.541027053386e-01
 24 KSP Residual norm 1.255711443195e+02 % max 1.342478258493e+02 min 1.586270065907e-01 max/min 8.463112854147e+02
 25 KSP preconditioned resid norm 1.064125166220e+02 true resid norm 8.683750469293e+00 ||r(i)||/||b|| 4.857723098741e-01
 25 KSP Residual norm 1.064125166220e+02 % max 1.343100269972e+02 min 1.586061159091e-01 max/min 8.468149303534e+02
 26 KSP preconditioned resid norm 9.497012777512e+01 true resid norm 7.776308733811e+00 ||r(i)||/||b|| 4.350096734441e-01
 26 KSP Residual norm 9.497012777512e+01 % max 1.346211743671e+02 min 1.408944545921e-01 max/min 9.554753219835e+02
 27 KSP preconditioned resid norm 9.449347291209e+01 true resid norm 8.027397390699e+00 ||r(i)||/||b|| 4.490556685785e-01
 27 KSP Residual norm 9.449347291209e+01 % max 1.353601106604e+02 min 1.302056396509e-01 max/min 1.039587156311e+03
 28 KSP preconditioned resid norm 7.708808620337e+01 true resid norm 8.253756419882e+00 ||r(i)||/||b|| 4.617182789167e-01
 28 KSP Residual norm 7.708808620337e+01 % max 1.354170803310e+02 min 1.300840147004e-01 max/min 1.040997086712e+03
 29 KSP preconditioned resid norm 6.883976717639e+01 true resid norm 7.200274893950e+00 ||r(i)||/||b|| 4.027861209659e-01
 29 KSP Residual norm 6.883976717639e+01 % max 1.359172085675e+02 min 1.060952954746e-01 max/min 1.281086102446e+03
 30 KSP preconditioned resid norm 6.671786230822e+01 true resid norm 6.613746362850e+00 ||r(i)||/||b|| 3.699754914612e-01
 30 KSP Residual norm 6.671786230822e+01 % max 1.361448012233e+02 min 8.135160167393e-02 max/min 1.673535596373e+03
 31 KSP preconditioned resid norm 5.753308015718e+01 true resid norm 7.287752888130e+00 ||r(i)||/||b|| 4.076796732906e-01
 31 KSP Residual norm 5.753308015718e+01 % max 1.363247397022e+02 min 6.837262871767e-02 max/min 1.993849618759e+03
 32 KSP preconditioned resid norm 5.188554631220e+01 true resid norm 7.000101427370e+00 ||r(i)||/||b|| 3.915883409767e-01
 32 KSP Residual norm 5.188554631220e+01 % max 1.365417051351e+02 min 6.421828602757e-02 max/min 2.126212229901e+03
 33 KSP preconditioned resid norm 4.949709579590e+01 true resid norm 6.374314702607e+00 ||r(i)||/||b|| 3.565815931606e-01
 33 KSP Residual norm 4.949709579590e+01 % max 1.366317667622e+02 min 6.421330753944e-02 max/min 2.127779614503e+03
 34 KSP preconditioned resid norm 4.403827792460e+01 true resid norm 6.147327125810e+00 ||r(i)||/||b|| 3.438838216294e-01
 34 KSP Residual norm 4.403827792460e+01 % max 1.370253126927e+02 min 6.368216512224e-02 max/min 2.151706249775e+03
 35 KSP preconditioned resid norm 4.140066382940e+01 true resid norm 5.886089041852e+00 ||r(i)||/||b|| 3.292700636777e-01
 35 KSP Residual norm 4.140066382940e+01 % max 1.390943209074e+02 min 6.114512372501e-02 max/min 2.274822789352e+03
 36 KSP preconditioned resid norm 3.745028333544e+01 true resid norm 5.122854489971e+00 ||r(i)||/||b|| 2.865744320432e-01
 36 KSP Residual norm 3.745028333544e+01 % max 1.396462040364e+02 min 5.993486381149e-02 max/min 2.329966152515e+03
 37 KSP preconditioned resid norm 3.492028700266e+01 true resid norm 4.982433448736e+00 ||r(i)||/||b|| 2.787192254942e-01
 37 KSP Residual norm 3.492028700266e+01 % max 1.418761690073e+02 min 5.972847536278e-02 max/min 2.375352261139e+03
 38 KSP preconditioned resid norm 3.068024157121e+01 true resid norm 4.394664243655e+00 ||r(i)||/||b|| 2.458391922143e-01
 38 KSP Residual norm 3.068024157121e+01 % max 1.419282962644e+02 min 5.955136512602e-02 max/min 2.383292070032e+03
 39 KSP preconditioned resid norm 2.614836504484e+01 true resid norm 3.671741082517e+00 ||r(i)||/||b|| 2.053985951371e-01
 39 KSP Residual norm 2.614836504484e+01 % max 1.424590886621e+02 min 5.534838135054e-02 max/min 2.573861876102e+03
 40 KSP preconditioned resid norm 2.598742703782e+01 true resid norm 3.707086113835e+00 ||r(i)||/||b|| 2.073758096559e-01
 40 KSP Residual norm 2.598742703782e+01 % max 1.428352406023e+02 min 5.401263258718e-02 max/min 2.644478407376e+03
 41 KSP preconditioned resid norm 2.271029765350e+01 true resid norm 2.912150121100e+00 ||r(i)||/||b|| 1.629067873414e-01
 41 KSP Residual norm 2.271029765350e+01 % max 1.446928584608e+02 min 5.373910075949e-02 max/min 2.692506134562e+03
 42 KSP preconditioned resid norm 1.795836259709e+01 true resid norm 2.316834528159e+00 ||r(i)||/||b|| 1.296046062493e-01
 42 KSP Residual norm 1.795836259709e+01 % max 1.449375360478e+02 min 5.251640030193e-02 max/min 2.759852831011e+03
 43 KSP preconditioned resid norm 1.795769958691e+01 true resid norm 2.311558013062e+00 ||r(i)||/||b|| 1.293094359844e-01
 43 KSP Residual norm 1.795769958691e+01 % max 1.449864885595e+02 min 4.685673226983e-02 max/min 3.094250954688e+03
 44 KSP preconditioned resid norm 1.688955122733e+01 true resid norm 2.370951018341e+00 ||r(i)||/||b|| 1.326319033292e-01
 44 KSP Residual norm 1.688955122733e+01 % max 1.450141764818e+02 min 4.554223489616e-02 max/min 3.184169086398e+03
 45 KSP preconditioned resid norm 1.526531678793e+01 true resid norm 1.947726448658e+00 ||r(i)||/||b|| 1.089565596470e-01
 45 KSP Residual norm 1.526531678793e+01 % max 1.460128059490e+02 min 4.478596884382e-02 max/min 3.260235509433e+03
 46 KSP preconditioned resid norm 1.519131456699e+01 true resid norm 1.914601584750e+00 ||r(i)||/||b|| 1.071035421390e-01
 46 KSP Residual norm 1.519131456699e+01 % max 1.467440844081e+02 min 4.068627190104e-02 max/min 3.606722305867e+03
 47 KSP preconditioned resid norm 1.396606833105e+01 true resid norm 1.916085501806e+00 ||r(i)||/||b|| 1.071865530245e-01
 47 KSP Residual norm 1.396606833105e+01 % max 1.472676539618e+02 min 4.068014642358e-02 max/min 3.620135788804e+03
 48 KSP preconditioned resid norm 1.128785630240e+01 true resid norm 1.818072605558e+00 ||r(i)||/||b|| 1.017036742642e-01
 48 KSP Residual norm 1.128785630240e+01 % max 1.476343971960e+02 min 4.003858518052e-02 max/min 3.687303048557e+03
 49 KSP preconditioned resid norm 9.686331225178e+00 true resid norm 1.520702063515e+00 ||r(i)||/||b|| 8.506865284031e-02
 49 KSP Residual norm 9.686331225178e+00 % max 1.478478861627e+02 min 3.802148926353e-02 max/min 3.888534852961e+03
 50 KSP preconditioned resid norm 9.646313260413e+00 true resid norm 1.596152870343e+00 ||r(i)||/||b|| 8.928939972200e-02
 50 KSP Residual norm 9.646313260413e+00 % max 1.479986700685e+02 min 3.796210121957e-02 max/min 3.898590049388e+03
 51 KSP preconditioned resid norm 9.270552344731e+00 true resid norm 1.442564661256e+00 ||r(i)||/||b|| 8.069761678656e-02
 51 KSP Residual norm 9.270552344731e+00 % max 1.482179613835e+02 min 3.763123640547e-02 max/min 3.938694965706e+03
 52 KSP preconditioned resid norm 8.025547426875e+00 true resid norm 1.151158202903e+00 ||r(i)||/||b|| 6.439622847661e-02
 52 KSP Residual norm 8.025547426875e+00 % max 1.482612345232e+02 min 3.498901666812e-02 max/min 4.237364997409e+03
 53 KSP preconditioned resid norm 7.830903379041e+00 true resid norm 1.083539895672e+00 ||r(i)||/||b|| 6.061363460667e-02
 53 KSP Residual norm 7.830903379041e+00 % max 1.496916293673e+02 min 3.180425422032e-02 max/min 4.706654283743e+03
 54 KSP preconditioned resid norm 7.818451528162e+00 true resid norm 1.101275786636e+00 ||r(i)||/||b|| 6.160578710481e-02
 54 KSP Residual norm 7.818451528162e+00 % max 1.497547864750e+02 min 2.963830547627e-02 max/min 5.052744550289e+03
 55 KSP preconditioned resid norm 6.716190950888e+00 true resid norm 1.068051260258e+00 ||r(i)||/||b|| 5.974719444025e-02
 55 KSP Residual norm 6.716190950888e+00 % max 1.509985715255e+02 min 2.913583319816e-02 max/min 5.182572624524e+03
 56 KSP preconditioned resid norm 6.435651273713e+00 true resid norm 9.738533937643e-01 ||r(i)||/||b|| 5.447772989798e-02
 56 KSP Residual norm 6.435651273713e+00 % max 1.513751779517e+02 min 2.849133088254e-02 max/min 5.313025866562e+03
 57 KSP preconditioned resid norm 6.427111085122e+00 true resid norm 9.515491605865e-01 ||r(i)||/||b|| 5.323002259581e-02
 57 KSP Residual norm 6.427111085122e+00 % max 1.514217018182e+02 min 2.805206411012e-02 max/min 5.397880926830e+03
 58 KSP preconditioned resid norm 6.330738649886e+00 true resid norm 9.488038114070e-01 ||r(i)||/||b|| 5.307644671670e-02
 58 KSP Residual norm 6.330738649886e+00 % max 1.514492565938e+02 min 2.542367477260e-02 max/min 5.957016754989e+03
 59 KSP preconditioned resid norm 5.861133560095e+00 true resid norm 9.281566562924e-01 ||r(i)||/||b|| 5.192143699275e-02
 59 KSP Residual norm 5.861133560095e+00 % max 1.522146406650e+02 min 2.316380798762e-02 max/min 6.571227008373e+03
 60 KSP preconditioned resid norm 5.523892064332e+00 true resid norm 8.250464923972e-01 ||r(i)||/||b|| 4.615341513814e-02
 60 KSP Residual norm 5.523892064332e+00 % max 1.522274643717e+02 min 2.316038063761e-02 max/min 6.572753131893e+03
 61 KSP preconditioned resid norm 5.345610652504e+00 true resid norm 7.967455833060e-01 ||r(i)||/||b|| 4.457025150056e-02
 61 KSP Residual norm 5.345610652504e+00 % max 1.527689509969e+02 min 2.278107359995e-02 max/min 6.705959239659e+03
 62 KSP preconditioned resid norm 4.883527474160e+00 true resid norm 6.939057385062e-01 ||r(i)||/||b|| 3.881735139915e-02
 62 KSP Residual norm 4.883527474160e+00 % max 1.527847370492e+02 min 2.215885299007e-02 max/min 6.894974984387e+03
 63 KSP preconditioned resid norm 3.982941325093e+00 true resid norm 6.883730294386e-01 ||r(i)||/||b|| 3.850784954587e-02
 63 KSP Residual norm 3.982941325093e+00 % max 1.528029462870e+02 min 2.036330717837e-02 max/min 7.503837414449e+03
 64 KSP preconditioned resid norm 3.768777539791e+00 true resid norm 6.576940275451e-01 ||r(i)||/||b|| 3.679165449085e-02
 64 KSP Residual norm 3.768777539791e+00 % max 1.534842011203e+02 min 2.015613298342e-02 max/min 7.614764262895e+03
 65 KSP preconditioned resid norm 3.754783611569e+00 true resid norm 6.240730525064e-01 ||r(i)||/||b|| 3.491088433716e-02
 65 KSP Residual norm 3.754783611569e+00 % max 1.536539871370e+02 min 2.002205183069e-02 max/min 7.674237807208e+03
 66 KSP preconditioned resid norm 3.242712853326e+00 true resid norm 5.919043028914e-01 ||r(i)||/||b|| 3.311135222698e-02
 66 KSP Residual norm 3.242712853326e+00 % max 1.536763506920e+02 min 1.853540050760e-02 max/min 8.290964666717e+03
 67 KSP preconditioned resid norm 2.639460944665e+00 true resid norm 5.172526166420e-01 ||r(i)||/||b|| 2.893530845493e-02
 67 KSP Residual norm 2.639460944665e+00 % max 1.536900244470e+02 min 1.819164547837e-02 max/min 8.448384981431e+03
 68 KSP preconditioned resid norm 2.332848633723e+00 true resid norm 4.860086486067e-01 ||r(i)||/||b|| 2.718750897868e-02
 68 KSP Residual norm 2.332848633723e+00 % max 1.537025056230e+02 min 1.794260313013e-02 max/min 8.566343718814e+03
 69 KSP preconditioned resid norm 2.210456807969e+00 true resid norm 5.392952883712e-01 ||r(i)||/||b|| 3.016838391000e-02
 69 KSP Residual norm 2.210456807969e+00 % max 1.537288460363e+02 min 1.753831098488e-02 max/min 8.765316464556e+03
 70 KSP preconditioned resid norm 2.193036145802e+00 true resid norm 5.031209038994e-01 ||r(i)||/||b|| 2.814477505974e-02
 70 KSP Residual norm 2.193036145802e+00 % max 1.541461506421e+02 min 1.700508158735e-02 max/min 9.064711030659e+03
 71 KSP preconditioned resid norm 1.938788470922e+00 true resid norm 3.360317906409e-01 ||r(i)||/||b|| 1.879774640094e-02
 71 KSP Residual norm 1.938788470922e+00 % max 1.545641242905e+02 min 1.655870257931e-02 max/min 9.334313696993e+03
 72 KSP preconditioned resid norm 1.450214827437e+00 true resid norm 2.879267785157e-01 ||r(i)||/||b|| 1.610673369402e-02
 72 KSP Residual norm 1.450214827437e+00 % max 1.549625503409e+02 min 1.648921859604e-02 max/min 9.397810420079e+03
 73 KSP preconditioned resid norm 1.110389920050e+00 true resid norm 2.664130281817e-01 ||r(i)||/||b|| 1.490324630331e-02
 73 KSP Residual norm 1.110389920050e+00 % max 1.553700778851e+02 min 1.637230817799e-02 max/min 9.489809023627e+03
 74 KSP preconditioned resid norm 8.588797630056e-01 true resid norm 2.680334659775e-01 ||r(i)||/||b|| 1.499389421102e-02
 74 KSP Residual norm 8.588797630056e-01 % max 1.560105458550e+02 min 1.627972447765e-02 max/min 9.583119546597e+03
 75 KSP preconditioned resid norm 6.037657330005e-01 true resid norm 2.938298885198e-01 ||r(i)||/||b|| 1.643695591681e-02
 75 KSP Residual norm 6.037657330005e-01 % max 1.568417947105e+02 min 1.617453208191e-02 max/min 9.696836601902e+03
 76 KSP preconditioned resid norm 4.778003132962e-01 true resid norm 3.104440343355e-01 ||r(i)||/||b|| 1.736635756394e-02
 76 KSP Residual norm 4.778003132962e-01 % max 1.582399629678e+02 min 1.614387326366e-02 max/min 9.801858598824e+03
 77 KSP preconditioned resid norm 4.523141317161e-01 true resid norm 3.278599563956e-01 ||r(i)||/||b|| 1.834061087967e-02
 77 KSP Residual norm 4.523141317161e-01 % max 1.610754319747e+02 min 1.614204788287e-02 max/min 9.978624344533e+03
 78 KSP preconditioned resid norm 4.522674526201e-01 true resid norm 3.287567680693e-01 ||r(i)||/||b|| 1.839077886640e-02
 78 KSP Residual norm 4.522674526201e-01 % max 1.611450941232e+02 min 1.596556934579e-02 max/min 1.009328829014e+04
 79 KSP preconditioned resid norm 4.452139421181e-01 true resid norm 3.198810083892e-01 ||r(i)||/||b|| 1.789426548812e-02
 79 KSP Residual norm 4.452139421181e-01 % max 1.619065061486e+02 min 1.456184518464e-02 max/min 1.111854329555e+04
 80 KSP preconditioned resid norm 4.217533807980e-01 true resid norm 2.940346905843e-01 ||r(i)||/||b|| 1.644841262233e-02
 80 KSP Residual norm 4.217533807980e-01 % max 1.620409915505e+02 min 1.154094228288e-02 max/min 1.404053391644e+04
 81 KSP preconditioned resid norm 3.815105809981e-01 true resid norm 2.630686686818e-01 ||r(i)||/||b|| 1.471616155865e-02
 81 KSP Residual norm 3.815105809981e-01 % max 1.643140061303e+02 min 9.352799654900e-03 max/min 1.756843000953e+04
 82 KSP preconditioned resid norm 3.257333222641e-01 true resid norm 2.350339902943e-01 ||r(i)||/||b|| 1.314789096807e-02
 82 KSP Residual norm 3.257333222641e-01 % max 1.661730623934e+02 min 7.309343891643e-03 max/min 2.273433359502e+04
 83 KSP preconditioned resid norm 2.653029571859e-01 true resid norm 1.993496448136e-01 ||r(i)||/||b|| 1.115169508568e-02
 83 KSP Residual norm 2.653029571859e-01 % max 1.672909675648e+02 min 5.727931297058e-03 max/min 2.920617564857e+04
 84 KSP preconditioned resid norm 2.125985080811e-01 true resid norm 1.651488251908e-01 ||r(i)||/||b|| 9.238488205020e-03
 84 KSP Residual norm 2.125985080811e-01 % max 1.677205536916e+02 min 4.904920732181e-03 max/min 3.419434540321e+04
 85 KSP preconditioned resid norm 1.823170233996e-01 true resid norm 1.538640960567e-01 ||r(i)||/||b|| 8.607216157635e-03
 85 KSP Residual norm 1.823170233996e-01 % max 1.684045979154e+02 min 4.411887233900e-03 max/min 3.817064874674e+04
 86 KSP preconditioned resid norm 1.568093845918e-01 true resid norm 1.468517035130e-01 ||r(i)||/||b|| 8.214940246925e-03
 86 KSP Residual norm 1.568093845918e-01 % max 1.707938893954e+02 min 3.835536173319e-03 max/min 4.452933870980e+04
 87 KSP preconditioned resid norm 1.416153038224e-01 true resid norm 1.326462010194e-01 ||r(i)||/||b|| 7.420279024951e-03
 87 KSP Residual norm 1.416153038224e-01 % max 1.708004671154e+02 min 3.204409749322e-03 max/min 5.330169375233e+04
 88 KSP preconditioned resid norm 1.298764107063e-01 true resid norm 1.273603812747e-01 ||r(i)||/||b|| 7.124588254468e-03
 88 KSP Residual norm 1.298764107063e-01 % max 1.708079667291e+02 min 2.881989285724e-03 max/min 5.926738436372e+04
 89 KSP preconditioned resid norm 1.226436579597e-01 true resid norm 1.269051556519e-01 ||r(i)||/||b|| 7.099122759682e-03
 89 KSP Residual norm 1.226436579597e-01 % max 1.708200970069e+02 min 2.600538747361e-03 max/min 6.568642639154e+04
 90 KSP preconditioned resid norm 1.131214284449e-01 true resid norm 1.236585929815e-01 ||r(i)||/||b|| 6.917508806917e-03
 90 KSP Residual norm 1.131214284449e-01 % max 1.708228433345e+02 min 2.097699611380e-03 max/min 8.143341516003e+04
 91 KSP preconditioned resid norm 1.097877127886e-01 true resid norm 1.208660430826e-01 ||r(i)||/||b|| 6.761292501577e-03
 91 KSP Residual norm 1.097877127886e-01 % max 1.734053778533e+02 min 1.669096618002e-03 max/min 1.038917555659e+05
 92 KSP preconditioned resid norm 1.087819681706e-01 true resid norm 1.220967287438e-01 ||r(i)||/||b|| 6.830137526368e-03
 92 KSP Residual norm 1.087819681706e-01 % max 1.735898650322e+02 min 1.410331102754e-03 max/min 1.230844761867e+05
 93 KSP preconditioned resid norm 1.082792743495e-01 true resid norm 1.231464976286e-01 ||r(i)||/||b|| 6.888861997758e-03
 93 KSP Residual norm 1.082792743495e-01 % max 1.744253420547e+02 min 1.160377474118e-03 max/min 1.503177594750e+05
 94 KSP preconditioned resid norm 1.082786837568e-01 true resid norm 1.231972007582e-01 ||r(i)||/||b|| 6.891698350150e-03
 94 KSP Residual norm 1.082786837568e-01 % max 1.744405973598e+02 min 9.020124135986e-04 max/min 1.933904619603e+05
 95 KSP preconditioned resid norm 1.076120024876e-01 true resid norm 1.193390416348e-01 ||r(i)||/||b|| 6.675871458778e-03
 95 KSP Residual norm 1.076120024876e-01 % max 1.744577996139e+02 min 6.759449987513e-04 max/min 2.580946673712e+05
 96 KSP preconditioned resid norm 1.051338654734e-01 true resid norm 1.113305708771e-01 ||r(i)||/||b|| 6.227874553259e-03
 96 KSP Residual norm 1.051338654734e-01 % max 1.754402425643e+02 min 5.544787352320e-04 max/min 3.164057184102e+05
 97 KSP preconditioned resid norm 9.747169190114e-02 true resid norm 9.349805869502e-02 ||r(i)||/||b|| 5.230317027375e-03
 97 KSP Residual norm 9.747169190114e-02 % max 1.756210909470e+02 min 4.482270392115e-04 max/min 3.918127992813e+05
 98 KSP preconditioned resid norm 8.842962288098e-02 true resid norm 7.385511932515e-02 ||r(i)||/||b|| 4.131483514810e-03
 98 KSP Residual norm 8.842962288098e-02 % max 1.757463096622e+02 min 3.987817611456e-04 max/min 4.407079931572e+05
 99 KSP preconditioned resid norm 7.588962343124e-02 true resid norm 4.759948399141e-02 ||r(i)||/||b|| 2.662733270502e-03
 99 KSP Residual norm 7.588962343124e-02 % max 1.758800802719e+02 min 3.549508940132e-04 max/min 4.955053874730e+05
100 KSP preconditioned resid norm 5.762080294705e-02 true resid norm 2.979101328333e-02 ||r(i)||/||b|| 1.666520633833e-03
100 KSP Residual norm 5.762080294705e-02 % max 1.767054165485e+02 min 3.399974141580e-04 max/min 5.197257661094e+05
101 KSP preconditioned resid norm 4.010101211334e-02 true resid norm 1.618156300742e-02 ||r(i)||/||b|| 9.052028000211e-04
101 KSP Residual norm 4.010101211334e-02 % max 1.780221758963e+02 min 3.330380731227e-04 max/min 5.345400128792e+05
102 KSP preconditioned resid norm 2.613215615582e-02 true resid norm 8.507285387866e-03 ||r(i)||/||b|| 4.759007859835e-04
102 KSP Residual norm 2.613215615582e-02 % max 1.780247903707e+02 min 3.267877108360e-04 max/min 5.447719864228e+05
103 KSP preconditioned resid norm 1.756896108812e-02 true resid norm 4.899136161981e-03 ||r(i)||/||b|| 2.740595435358e-04
103 KSP Residual norm 1.756896108812e-02 % max 1.780337300599e+02 min 3.237486252629e-04 max/min 5.499134704135e+05
104 KSP preconditioned resid norm 1.142112016905e-02 true resid norm 3.312246267926e-03 ||r(i)||/||b|| 1.852883182367e-04
104 KSP Residual norm 1.142112016905e-02 % max 1.805569604942e+02 min 3.232308817378e-04 max/min 5.586005876774e+05
105 KSP preconditioned resid norm 7.345608733466e-03 true resid norm 1.880672268508e-03 ||r(i)||/||b|| 1.052055232609e-04
105 KSP Residual norm 7.345608733466e-03 % max 1.817568861663e+02 min 3.229958821968e-04 max/min 5.627219917794e+05
106 KSP preconditioned resid norm 4.810582452316e-03 true resid norm 1.418216565286e-03 ||r(i)||/||b|| 7.933557502107e-05
106 KSP Residual norm 4.810582452316e-03 % max 1.845797149153e+02 min 3.220343456392e-04 max/min 5.731677922395e+05
107 KSP preconditioned resid norm 3.114068270187e-03 true resid norm 1.177898700463e-03 ||r(i)||/||b|| 6.589210209864e-05
107 KSP Residual norm 3.114068270187e-03 % max 1.850561815508e+02 min 3.216059660171e-04 max/min 5.754127755856e+05
108 KSP preconditioned resid norm 2.293796939903e-03 true resid norm 1.090384984298e-03 ||r(i)||/||b|| 6.099655147246e-05
108 KSP Residual norm 2.293796939903e-03 % max 1.887275970943e+02 min 3.204019028106e-04 max/min 5.890339459248e+05
109 KSP preconditioned resid norm 1.897140553486e-03 true resid norm 1.085409353133e-03 ||r(i)||/||b|| 6.071821276936e-05
109 KSP Residual norm 1.897140553486e-03 % max 1.900700995337e+02 min 3.201092729524e-04 max/min 5.937663029274e+05
110 KSP preconditioned resid norm 1.638607873536e-03 true resid norm 1.080912735078e-03 ||r(i)||/||b|| 6.046667024205e-05
110 KSP Residual norm 1.638607873536e-03 % max 1.941847763082e+02 min 3.201003961856e-04 max/min 6.066371008040e+05
111 KSP preconditioned resid norm 1.445734513987e-03 true resid norm 1.072337220355e-03 ||r(i)||/||b|| 5.998695268109e-05
111 KSP Residual norm 1.445734513987e-03 % max 1.968706347099e+02 min 3.200841174449e-04 max/min 6.150590547303e+05
112 KSP preconditioned resid norm 1.309787940098e-03 true resid norm 1.071880522659e-03 ||r(i)||/||b|| 5.996140483796e-05
112 KSP Residual norm 1.309787940098e-03 % max 2.005995546657e+02 min 3.200727858161e-04 max/min 6.267310547950e+05
113 KSP preconditioned resid norm 1.203600185791e-03 true resid norm 1.068704252153e-03 ||r(i)||/||b|| 5.978372305568e-05
113 KSP Residual norm 1.203600185791e-03 % max 2.044005133646e+02 min 3.200669375682e-04 max/min 6.386180182109e+05
114 KSP preconditioned resid norm 1.120060134211e-03 true resid norm 1.067737533794e-03 ||r(i)||/||b|| 5.972964446230e-05
114 KSP Residual norm 1.120060134211e-03 % max 2.080860182134e+02 min 3.200663739818e-04 max/min 6.501339569812e+05
115 KSP preconditioned resid norm 1.051559355475e-03 true resid norm 1.066440021011e-03 ||r(i)||/||b|| 5.965706110284e-05
115 KSP Residual norm 1.051559355475e-03 % max 2.120208487134e+02 min 3.200660278464e-04 max/min 6.624284687130e+05
116 KSP preconditioned resid norm 9.943175666627e-04 true resid norm 1.065634036988e-03 ||r(i)||/||b|| 5.961197404955e-05
116 KSP Residual norm 9.943175666627e-04 % max 2.158491989548e+02 min 3.200660249513e-04 max/min 6.743896012946e+05
117 KSP preconditioned resid norm 9.454894909455e-04 true resid norm 1.064909725825e-03 ||r(i)||/||b|| 5.957145580713e-05
117 KSP Residual norm 9.454894909455e-04 % max 2.197604049280e+02 min 3.200659829252e-04 max/min 6.866096887885e+05
118 KSP preconditioned resid norm 9.032188050175e-04 true resid norm 1.064337854187e-03 ||r(i)||/||b|| 5.953946508976e-05
118 KSP Residual norm 9.032188050175e-04 % max 2.236450290076e+02 min 3.200659636119e-04 max/min 6.987466786029e+05
119 KSP preconditioned resid norm 8.661523005930e-04 true resid norm 1.063851383334e-03 ||r(i)||/||b|| 5.951225172494e-05
119 KSP Residual norm 8.661523005930e-04 % max 2.275386631435e+02 min 3.200659439058e-04 max/min 7.109118213789e+05
120 KSP preconditioned resid norm 8.333044554060e-04 true resid norm 1.063440179004e-03 ||r(i)||/||b|| 5.948924879800e-05
120 KSP Residual norm 8.333044554060e-04 % max 2.314181044639e+02 min 3.200659279880e-04 max/min 7.230326136825e+05
121 KSP preconditioned resid norm 8.039309218182e-04 true resid norm 1.063085844171e-03 ||r(i)||/||b|| 5.946942717246e-05
121 KSP Residual norm 8.039309218182e-04 % max 2.352840091878e+02 min 3.200659140872e-04 max/min 7.351111094065e+05
122 KSP preconditioned resid norm 7.774595735272e-04 true resid norm 1.062777951335e-03 ||r(i)||/||b|| 5.945220352987e-05
122 KSP Residual norm 7.774595735272e-04 % max 2.391301402333e+02 min 3.200659020264e-04 max/min 7.471278218621e+05
123 KSP preconditioned resid norm 7.534419441080e-04 true resid norm 1.062507774643e-03 ||r(i)||/||b|| 5.943708974281e-05
123 KSP Residual norm 7.534419441080e-04 % max 2.429535997478e+02 min 3.200658914252e-04 max/min 7.590736978126e+05
124 KSP preconditioned resid norm 7.315209774625e-04 true resid norm 1.062268823392e-03 ||r(i)||/||b|| 5.942372271877e-05
124 KSP Residual norm 7.315209774625e-04 % max 2.467514538222e+02 min 3.200658820413e-04 max/min 7.709395710924e+05
125 KSP preconditioned resid norm 7.114083600074e-04 true resid norm 1.062055971251e-03 ||r(i)||/||b|| 5.941181568889e-05
125 KSP Residual norm 7.114083600074e-04 % max 2.505215705167e+02 min 3.200658736748e-04 max/min 7.827187811071e+05
126 KSP preconditioned resid norm 6.928683961266e-04 true resid norm 1.061865165985e-03 ||r(i)||/||b|| 5.940114196966e-05
126 KSP Residual norm 6.928683961266e-04 % max 2.542622648377e+02 min 3.200658661692e-04 max/min 7.944060636045e+05
127 KSP preconditioned resid norm 6.757062709768e-04 true resid norm 1.061693150669e-03 ||r(i)||/||b|| 5.939151936730e-05
127 KSP Residual norm 6.757062709768e-04 % max 2.579722822206e+02 min 3.200658593982e-04 max/min 8.059974990947e+05
128 KSP preconditioned resid norm 6.597593638309e-04 true resid norm 1.061537280201e-03 ||r(i)||/||b|| 5.938279991397e-05
128 KSP Residual norm 6.597593638309e-04 % max 2.616507118184e+02 min 3.200658532588e-04 max/min 8.174902419435e+05
129 KSP preconditioned resid norm 6.448907155810e-04 true resid norm 1.061395383620e-03 ||r(i)||/||b|| 5.937486216514e-05
129 KSP Residual norm 6.448907155810e-04 % max 2.652969302909e+02 min 3.200658476664e-04 max/min 8.288823447585e+05
130 KSP preconditioned resid norm 6.309840465804e-04 true resid norm 1.061265662452e-03 ||r(i)||/||b|| 5.936760551361e-05
130 KSP Residual norm 6.309840465804e-04 % max 2.689105505574e+02 min 3.200658425513e-04 max/min 8.401725982813e+05
131 KSP preconditioned resid norm 6.179399078869e-04 true resid norm 1.061146614178e-03 ||r(i)||/||b|| 5.936094590780e-05
131 KSP Residual norm 6.179399078869e-04 % max 2.724913796166e+02 min 3.200658378548e-04 max/min 8.513603996069e+05
132 KSP preconditioned resid norm 6.056726732840e-04 true resid norm 1.061036973709e-03 ||r(i)||/||b|| 5.935481257818e-05
132 KSP Residual norm 6.056726732840e-04 % max 2.760393830832e+02 min 3.200658335276e-04 max/min 8.624456413884e+05
133 KSP preconditioned resid norm 5.941081632891e-04 true resid norm 1.060935668299e-03 ||r(i)||/||b|| 5.934914551493e-05
133 KSP Residual norm 5.941081632891e-04 % max 2.795546556158e+02 min 3.200658295276e-04 max/min 8.734286194450e+05
134 KSP preconditioned resid norm 5.831817499918e-04 true resid norm 1.060841782314e-03 ||r(i)||/||b|| 5.934389349718e-05
134 KSP Residual norm 5.831817499918e-04 % max 2.830373962684e+02 min 3.200658258193e-04 max/min 8.843099557533e+05
135 KSP preconditioned resid norm 5.728368317981e-04 true resid norm 1.060754529477e-03 ||r(i)||/||b|| 5.933901254021e-05
135 KSP Residual norm 5.728368317981e-04 % max 2.864878879810e+02 min 3.200658223718e-04 max/min 8.950905343719e+05
136 KSP preconditioned resid norm 5.630235956754e-04 true resid norm 1.060673230868e-03 ||r(i)||/||b|| 5.933446466506e-05
136 KSP Residual norm 5.630235956754e-04 % max 2.899064805338e+02 min 3.200658191584e-04 max/min 9.057714481857e+05
137 KSP preconditioned resid norm 5.536980049705e-04 true resid norm 1.060597297101e-03 ||r(i)||/||b|| 5.933021690118e-05
137 KSP Residual norm 5.536980049705e-04 % max 2.932935763968e+02 min 3.200658161562e-04 max/min 9.163539546933e+05
138 KSP preconditioned resid norm 5.448209657758e-04 true resid norm 1.060526214124e-03 ||r(i)||/||b|| 5.932624049239e-05
138 KSP Residual norm 5.448209657758e-04 % max 2.966496189942e+02 min 3.200658133448e-04 max/min 9.268394393456e+05
139 KSP preconditioned resid norm 5.363576357737e-04 true resid norm 1.060459531517e-03 ||r(i)||/||b|| 5.932251024194e-05
139 KSP Residual norm 5.363576357737e-04 % max 2.999750829834e+02 min 3.200658107070e-04 max/min 9.372293851716e+05
140 KSP preconditioned resid norm 5.282768476492e-04 true resid norm 1.060396852955e-03 ||r(i)||/||b|| 5.931900397932e-05
140 KSP Residual norm 5.282768476492e-04 % max 3.032704662136e+02 min 3.200658082268e-04 max/min 9.475253476584e+05
141 KSP preconditioned resid norm 5.205506252810e-04 true resid norm 1.060337828321e-03 ||r(i)||/||b|| 5.931570211878e-05
141 KSP Residual norm 5.205506252810e-04 % max 3.065362830844e+02 min 3.200658058907e-04 max/min 9.577289339963e+05
142 KSP preconditioned resid norm 5.131537755696e-04 true resid norm 1.060282147141e-03 ||r(i)||/||b|| 5.931258729233e-05
142 KSP Residual norm 5.131537755696e-04 % max 3.097730590695e+02 min 3.200658036863e-04 max/min 9.678417859756e+05
143 KSP preconditioned resid norm 5.060635423123e-04 true resid norm 1.060229533174e-03 ||r(i)||/||b|| 5.930964404698e-05
143 KSP Residual norm 5.060635423123e-04 % max 3.129813262144e+02 min 3.200658016030e-04 max/min 9.778655659143e+05
144 KSP preconditioned resid norm 4.992593112791e-04 true resid norm 1.060179739774e-03 ||r(i)||/||b|| 5.930685858524e-05
144 KSP Residual norm 4.992593112791e-04 % max 3.161616194433e+02 min 3.200657996311e-04 max/min 9.878019451242e+05
145 KSP preconditioned resid norm 4.927223577718e-04 true resid norm 1.060132546053e-03 ||r(i)||/||b|| 5.930421855048e-05
145 KSP Residual norm 4.927223577718e-04 % max 3.193144735429e+02 min 3.200657977617e-04 max/min 9.976525944849e+05
146 KSP preconditioned resid norm 4.864356296191e-04 true resid norm 1.060087753599e-03 ||r(i)||/||b|| 5.930171284355e-05
146 KSP Residual norm 4.864356296191e-04 % max 3.224404207086e+02 min 3.200657959872e-04 max/min 1.007419176779e+06
147 KSP preconditioned resid norm 4.803835598739e-04 true resid norm 1.060045183705e-03 ||r(i)||/||b|| 5.929933146747e-05
147 KSP Residual norm 4.803835598739e-04 % max 3.255399885620e+02 min 3.200657943002e-04 max/min 1.017103340498e+06
148 KSP preconditioned resid norm 4.745519045267e-04 true resid norm 1.060004674955e-03 ||r(i)||/||b|| 5.929706539253e-05
148 KSP Residual norm 4.745519045267e-04 % max 3.286136985587e+02 min 3.200657926948e-04 max/min 1.026706714866e+06
149 KSP preconditioned resid norm 4.689276013781e-04 true resid norm 1.059966081181e-03 ||r(i)||/||b|| 5.929490644211e-05
149 KSP Residual norm 4.689276013781e-04 % max 3.316620647237e+02 min 3.200657911651e-04 max/min 1.036230905891e+06
150 KSP preconditioned resid norm 4.634986468865e-04 true resid norm 1.059929269736e-03 ||r(i)||/||b|| 5.929284719586e-05
150 KSP Residual norm 4.634986468865e-04 % max 3.346855926588e+02 min 3.200657897058e-04 max/min 1.045677493263e+06
151 KSP preconditioned resid norm 4.582539883466e-04 true resid norm 1.059894119959e-03 ||r(i)||/||b|| 5.929088090393e-05
151 KSP Residual norm 4.582539883466e-04 % max 3.376847787762e+02 min 3.200657883122e-04 max/min 1.055048027960e+06
152 KSP preconditioned resid norm 4.531834291922e-04 true resid norm 1.059860521790e-03 ||r(i)||/||b|| 5.928900140955e-05
152 KSP Residual norm 4.531834291922e-04 % max 3.406601097208e+02 min 3.200657869798e-04 max/min 1.064344030443e+06
153 KSP preconditioned resid norm 4.482775455769e-04 true resid norm 1.059828374748e-03 ||r(i)||/||b|| 5.928720309181e-05
153 KSP Residual norm 4.482775455769e-04 % max 3.436120619489e+02 min 3.200657857049e-04 max/min 1.073566989337e+06
154 KSP preconditioned resid norm 4.435276126791e-04 true resid norm 1.059797586777e-03 ||r(i)||/||b|| 5.928548080094e-05
154 KSP Residual norm 4.435276126791e-04 % max 3.465411014367e+02 min 3.200657844837e-04 max/min 1.082718360526e+06
155 KSP preconditioned resid norm 4.389255394186e-04 true resid norm 1.059768073502e-03 ||r(i)||/||b|| 5.928382981713e-05
155 KSP Residual norm 4.389255394186e-04 % max 3.494476834965e+02 min 3.200657833130e-04 max/min 1.091799566575e+06
156 KSP preconditioned resid norm 4.344638104739e-04 true resid norm 1.059739757336e-03 ||r(i)||/||b|| 5.928224580001e-05
156 KSP Residual norm 4.344638104739e-04 % max 3.523322526810e+02 min 3.200657821896e-04 max/min 1.100811996430e+06
157 KSP preconditioned resid norm 4.301354346542e-04 true resid norm 1.059712566921e-03 ||r(i)||/||b|| 5.928072475785e-05
157 KSP Residual norm 4.301354346542e-04 % max 3.551952427605e+02 min 3.200657811108e-04 max/min 1.109757005350e+06
158 KSP preconditioned resid norm 4.259338988194e-04 true resid norm 1.059686436414e-03 ||r(i)||/||b|| 5.927926300733e-05
158 KSP Residual norm 4.259338988194e-04 % max 3.580370767604e+02 min 3.200657800738e-04 max/min 1.118635915023e+06
159 KSP preconditioned resid norm 4.218531266563e-04 true resid norm 1.059661305045e-03 ||r(i)||/||b|| 5.927785714894e-05
159 KSP Residual norm 4.218531266563e-04 % max 3.608581670458e+02 min 3.200657790764e-04 max/min 1.127450013829e+06
160 KSP preconditioned resid norm 4.178874417186e-04 true resid norm 1.059637116561e-03 ||r(i)||/||b|| 5.927650403596e-05
160 KSP Residual norm 4.178874417186e-04 % max 3.636589154466e+02 min 3.200657781164e-04 max/min 1.136200557232e+06
161 KSP preconditioned resid norm 4.140315342180e-04 true resid norm 1.059613818894e-03 ||r(i)||/||b|| 5.927520075559e-05
161 KSP Residual norm 4.140315342180e-04 % max 3.664397134134e+02 min 3.200657771916e-04 max/min 1.144888768267e+06
162 KSP preconditioned resid norm 4.102804311252e-04 true resid norm 1.059591363713e-03 ||r(i)||/||b|| 5.927394460419e-05
162 KSP Residual norm 4.102804311252e-04 % max 3.692009421979e+02 min 3.200657763002e-04 max/min 1.153515838106e+06
163 KSP preconditioned resid norm 4.066294691985e-04 true resid norm 1.059569706138e-03 ||r(i)||/||b|| 5.927273307117e-05
163 KSP Residual norm 4.066294691985e-04 % max 3.719429730532e+02 min 3.200657754405e-04 max/min 1.162082926678e+06
164 KSP preconditioned resid norm 4.030742706055e-04 true resid norm 1.059548804412e-03 ||r(i)||/||b|| 5.927156382068e-05
164 KSP Residual norm 4.030742706055e-04 % max 3.746661674483e+02 min 3.200657746106e-04 max/min 1.170591163345e+06
165 KSP preconditioned resid norm 3.996107208498e-04 true resid norm 1.059528619651e-03 ||r(i)||/||b|| 5.927043467745e-05
165 KSP Residual norm 3.996107208498e-04 % max 3.773708772938e+02 min 3.200657738091e-04 max/min 1.179041647605e+06
166 KSP preconditioned resid norm 3.962349487489e-04 true resid norm 1.059509115572e-03 ||r(i)||/||b|| 5.926934361186e-05
166 KSP Residual norm 3.962349487489e-04 % max 3.800574451754e+02 min 3.200657730346e-04 max/min 1.187435449820e+06
167 KSP preconditioned resid norm 3.929433082418e-04 true resid norm 1.059490258328e-03 ||r(i)||/||b|| 5.926828873043e-05
167 KSP Residual norm 3.929433082418e-04 % max 3.827262045917e+02 min 3.200657722858e-04 max/min 1.195773611962e+06
168 KSP preconditioned resid norm 3.897323618319e-04 true resid norm 1.059472016256e-03 ||r(i)||/||b|| 5.926726826196e-05
168 KSP Residual norm 3.897323618319e-04 % max 3.853774801959e+02 min 3.200657715611e-04 max/min 1.204057148368e+06
169 KSP preconditioned resid norm 3.865988654946e-04 true resid norm 1.059454359751e-03 ||r(i)||/||b|| 5.926628055033e-05
169 KSP Residual norm 3.865988654946e-04 % max 3.880115880375e+02 min 3.200657708600e-04 max/min 1.212287046487e+06
170 KSP preconditioned resid norm 3.835397548978e-04 true resid norm 1.059437261066e-03 ||r(i)||/||b|| 5.926532404338e-05
170 KSP Residual norm 3.835397548978e-04 % max 3.906288358040e+02 min 3.200657701808e-04 max/min 1.220464267652e+06
171 KSP preconditioned resid norm 3.805521328045e-04 true resid norm 1.059420694153e-03 ||r(i)||/||b|| 5.926439728400e-05
171 KSP Residual norm 3.805521328045e-04 % max 3.932295230610e+02 min 3.200657695227e-04 max/min 1.228589747812e+06
172 KSP preconditioned resid norm 3.776332575372e-04 true resid norm 1.059404634604e-03 ||r(i)||/||b|| 5.926349890668e-05
172 KSP Residual norm 3.776332575372e-04 % max 3.958139414889e+02 min 3.200657688847e-04 max/min 1.236664398283e+06
173 KSP preconditioned resid norm 3.747805324013e-04 true resid norm 1.059389059461e-03 ||r(i)||/||b|| 5.926262762725e-05
173 KSP Residual norm 3.747805324013e-04 % max 3.983823751168e+02 min 3.200657682658e-04 max/min 1.244689106477e+06
174 KSP preconditioned resid norm 3.719914959745e-04 true resid norm 1.059373947132e-03 ||r(i)||/||b|| 5.926178223783e-05
174 KSP Residual norm 3.719914959745e-04 % max 4.009351005517e+02 min 3.200657676654e-04 max/min 1.252664736614e+06
175 KSP preconditioned resid norm 3.692638131792e-04 true resid norm 1.059359277291e-03 ||r(i)||/||b|| 5.926096160129e-05
175 KSP Residual norm 3.692638131792e-04 % max 4.034723872035e+02 min 3.200657670824e-04 max/min 1.260592130428e+06
176 KSP preconditioned resid norm 3.665952670646e-04 true resid norm 1.059345030772e-03 ||r(i)||/||b|| 5.926016464562e-05
176 KSP Residual norm 3.665952670646e-04 % max 4.059944975044e+02 min 3.200657665165e-04 max/min 1.268472107852e+06
177 KSP preconditioned resid norm 3.639837512333e-04 true resid norm 1.059331189535e-03 ||r(i)||/||b|| 5.925939036157e-05
177 KSP Residual norm 3.639837512333e-04 % max 4.085016871234e+02 min 3.200657659664e-04 max/min 1.276305467690e+06
178 KSP preconditioned resid norm 3.614272628526e-04 true resid norm 1.059317736504e-03 ||r(i)||/||b|| 5.925863779385e-05
178 KSP Residual norm 3.614272628526e-04 % max 4.109942051749e+02 min 3.200657654318e-04 max/min 1.284092988266e+06
179 KSP preconditioned resid norm 3.589238961979e-04 true resid norm 1.059304655605e-03 ||r(i)||/||b|| 5.925790604337e-05
179 KSP Residual norm 3.589238961979e-04 % max 4.134722944217e+02 min 3.200657649118e-04 max/min 1.291835428058e+06
180 KSP preconditioned resid norm 3.564718366825e-04 true resid norm 1.059291931579e-03 ||r(i)||/||b|| 5.925719425653e-05
180 KSP Residual norm 3.564718366825e-04 % max 4.159361914728e+02 min 3.200657644063e-04 max/min 1.299533526319e+06
181 KSP preconditioned resid norm 3.540693553287e-04 true resid norm 1.059279550018e-03 ||r(i)||/||b|| 5.925650162730e-05
181 KSP Residual norm 3.540693553287e-04 % max 4.183861269743e+02 min 3.200657639142e-04 max/min 1.307188003670e+06
182 KSP preconditioned resid norm 3.517148036444e-04 true resid norm 1.059267497309e-03 ||r(i)||/||b|| 5.925582739414e-05
182 KSP Residual norm 3.517148036444e-04 % max 4.208223257952e+02 min 3.200657634351e-04 max/min 1.314799562686e+06
183 KSP preconditioned resid norm 3.494066088688e-04 true resid norm 1.059255760488e-03 ||r(i)||/||b|| 5.925517083190e-05
183 KSP Residual norm 3.494066088688e-04 % max 4.232450072075e+02 min 3.200657629684e-04 max/min 1.322368888450e+06
184 KSP preconditioned resid norm 3.471432695577e-04 true resid norm 1.059244327320e-03 ||r(i)||/||b|| 5.925453125615e-05
184 KSP Residual norm 3.471432695577e-04 % max 4.256543850606e+02 min 3.200657625139e-04 max/min 1.329896649105e+06
185 KSP preconditioned resid norm 3.449233514781e-04 true resid norm 1.059233186159e-03 ||r(i)||/||b|| 5.925390801536e-05
185 KSP Residual norm 3.449233514781e-04 % max 4.280506679492e+02 min 3.200657620711e-04 max/min 1.337383496377e+06
186 KSP preconditioned resid norm 3.427454837895e-04 true resid norm 1.059222325963e-03 ||r(i)||/||b|| 5.925330049183e-05
186 KSP Residual norm 3.427454837895e-04 % max 4.304340593770e+02 min 3.200657616393e-04 max/min 1.344830066085e+06
187 KSP preconditioned resid norm 3.406083554860e-04 true resid norm 1.059211736238e-03 ||r(i)||/||b|| 5.925270809861e-05
187 KSP Residual norm 3.406083554860e-04 % max 4.328047579144e+02 min 3.200657612184e-04 max/min 1.352236978635e+06
188 KSP preconditioned resid norm 3.385107120797e-04 true resid norm 1.059201407008e-03 ||r(i)||/||b|| 5.925213027752e-05
188 KSP Residual norm 3.385107120797e-04 % max 4.351629573503e+02 min 3.200657608077e-04 max/min 1.359604839494e+06
189 KSP preconditioned resid norm 3.364513525062e-04 true resid norm 1.059191328770e-03 ||r(i)||/||b|| 5.925156649705e-05
189 KSP Residual norm 3.364513525062e-04 % max 4.375088468402e+02 min 3.200657604069e-04 max/min 1.366934239651e+06
190 KSP preconditioned resid norm 3.344291262348e-04 true resid norm 1.059181492481e-03 ||r(i)||/||b|| 5.925101625132e-05
190 KSP Residual norm 3.344291262348e-04 % max 4.398426110478e+02 min 3.200657600159e-04 max/min 1.374225756063e+06
191 KSP preconditioned resid norm 3.324429305670e-04 true resid norm 1.059171889545e-03 ||r(i)||/||b|| 5.925047905943e-05
191 KSP Residual norm 3.324429305670e-04 % max 4.421644302826e+02 min 3.200657596338e-04 max/min 1.381479952084e+06
192 KSP preconditioned resid norm 3.304917081101e-04 true resid norm 1.059162511741e-03 ||r(i)||/||b|| 5.924995446149e-05
192 KSP Residual norm 3.304917081101e-04 % max 4.444744806328e+02 min 3.200657592613e-04 max/min 1.388697377872e+06
193 KSP preconditioned resid norm 3.285744444114e-04 true resid norm 1.059153351271e-03 ||r(i)||/||b|| 5.924944202127e-05
193 KSP Residual norm 3.285744444114e-04 % max 4.467729340931e+02 min 3.200657588967e-04 max/min 1.395878570808e+06
194 KSP preconditioned resid norm 3.266901657422e-04 true resid norm 1.059144400627e-03 ||r(i)||/||b|| 5.924894131886e-05
194 KSP Residual norm 3.266901657422e-04 % max 4.490599586887e+02 min 3.200657585410e-04 max/min 1.403024055856e+06
195 KSP preconditioned resid norm 3.248379370193e-04 true resid norm 1.059135652724e-03 ||r(i)||/||b|| 5.924845195782e-05
195 KSP Residual norm 3.248379370193e-04 % max 4.513357185943e+02 min 3.200657581935e-04 max/min 1.410134345960e+06
196 KSP preconditioned resid norm 3.230168598555e-04 true resid norm 1.059127100716e-03 ||r(i)||/||b|| 5.924797355524e-05
196 KSP Residual norm 3.230168598555e-04 % max 4.536003742498e+02 min 3.200657578528e-04 max/min 1.417209942397e+06
197 KSP preconditioned resid norm 3.212260707284e-04 true resid norm 1.059118738110e-03 ||r(i)||/||b|| 5.924750574787e-05
197 KSP Residual norm 3.212260707284e-04 % max 4.558540824713e+02 min 3.200657575203e-04 max/min 1.424251335110e+06
198 KSP preconditioned resid norm 3.194647392600e-04 true resid norm 1.059110558683e-03 ||r(i)||/||b|| 5.924704818760e-05
198 KSP Residual norm 3.194647392600e-04 % max 4.580969965587e+02 min 3.200657571950e-04 max/min 1.431259003067e+06
199 KSP preconditioned resid norm 3.177320665985e-04 true resid norm 1.059102556481e-03 ||r(i)||/||b|| 5.924660054140e-05
199 KSP Residual norm 3.177320665985e-04 % max 4.603292663993e+02 min 3.200657568766e-04 max/min 1.438233414569e+06
200 KSP preconditioned resid norm 3.160272838961e-04 true resid norm 1.059094725800e-03 ||r(i)||/||b|| 5.924616249011e-05
200 KSP Residual norm 3.160272838961e-04 % max 4.625510385677e+02 min 3.200657565653e-04 max/min 1.445175027567e+06
Meng
 Send time: Friday, Apr 25, 2014 6:54 AM
Cc: "Dave May"<dave.mayhem23 at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
  Run the bad case again with -ksp_gmres_restart 200 -ksp_max_it 200 and send the output
On Apr 24, 2014, at 5:46 PM, Oo <wumeng07maths at qq.com> wrote:
> Thanks,
> The following is the output at the beginning.
> When solving the linear system:
> Output:
> +00 max/min 7.343521316293e+01
> 9636 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064989678e-01 ||r(i)||/||b|| 8.917260288210e-03
> 9636 KSP Residual norm 1.080641720588e+00 % max 9.802496207537e+01 min 1.168945135768e+00 max/min 8.385762434515e+01
 > 9637 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064987918e-01 ||r(i)||/||b|| 8.917260278361e-03
> 9637 KSP Residual norm 1.080641720588e+00 % max 1.122401280488e+02 min 1.141681830513e+00 max/min 9.831121512938e+01
 > 9638 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064986859e-01 ||r(i)||/||b|| 8.917260272440e-03
> 9638 KSP Residual norm 1.080641720588e+00 % max 1.134941067042e+02 min 1.090790142559e+00 max/min 1.040476094127e+02
 > 9639 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064442988e-01 ||r(i)||/||b|| 8.917257230005e-03
> 9639 KSP Residual norm 1.080641720588e+00 % max 1.139914662925e+02 min 4.119649156568e-01 max/min 2.767018791170e+02
 > 9640 KSP preconditioned resid norm 1.080641720586e+00 true resid norm 1.594063809183e-01 ||r(i)||/||b|| 8.917253684473e-03
> 9640 KSP Residual norm 1.080641720586e+00 % max 1.140011421526e+02 min 2.894486589274e-01 max/min 3.938561766878e+02
 > 9641 KSP preconditioned resid norm 1.080641720586e+00 true resid norm 1.594063839202e-01 ||r(i)||/||b|| 8.917253852403e-03
> 9641 KSP Residual norm 1.080641720586e+00 % max 1.140392299942e+02 min 2.880532973299e-01 max/min 3.958962839563e+02
 > 9642 KSP preconditioned resid norm 1.080641720586e+00 true resid norm 1.594064091676e-01 ||r(i)||/||b|| 8.917255264750e-03
> 9642 KSP Residual norm 1.080641720586e+00 % max 1.140392728591e+02 min 2.501717295613e-01 max/min 4.558439639005e+02
 > 9643 KSP preconditioned resid norm 1.080641720583e+00 true resid norm 1.594064099334e-01 ||r(i)||/||b|| 8.917255307591e-03
> 9643 KSP Residual norm 1.080641720583e+00 % max 1.141360429432e+02 min 2.500714638111e-01 max/min 4.564137035220e+02
 > 9644 KSP preconditioned resid norm 1.080641720582e+00 true resid norm 1.594064169337e-01 ||r(i)||/||b|| 8.917255699186e-03
> 9644 KSP Residual norm 1.080641720582e+00 % max 1.141719168213e+02 min 2.470526471293e-01 max/min 4.621359784969e+02
 > 9645 KSP preconditioned resid norm 1.080641720554e+00 true resid norm 1.594064833602e-01 ||r(i)||/||b|| 8.917259415111e-03
> 9645 KSP Residual norm 1.080641720554e+00 % max 1.141770017757e+02 min 2.461729098264e-01 max/min 4.638081495493e+02
 > 9646 KSP preconditioned resid norm 1.080641720550e+00 true resid norm 1.594066163854e-01 ||r(i)||/||b|| 8.917266856592e-03
> 9646 KSP Residual norm 1.080641720550e+00 % max 1.150251695783e+02 min 1.817293289064e-01 max/min 6.329477485583e+02
 > 9647 KSP preconditioned resid norm 1.080641720425e+00 true resid norm 1.594070759575e-01 ||r(i)||/||b|| 8.917292565231e-03
> 9647 KSP Residual norm 1.080641720425e+00 % max 1.153670774825e+02 min 1.757825842976e-01 max/min 6.563055034347e+02
 > 9648 KSP preconditioned resid norm 1.080641720405e+00 true resid norm 1.594072309986e-01 ||r(i)||/||b|| 8.917301238287e-03
> 9648 KSP Residual norm 1.080641720405e+00 % max 1.154419449950e+02 min 1.682003217110e-01 max/min 6.863360534671e+02
 > 9649 KSP preconditioned resid norm 1.080641719971e+00 true resid norm 1.594088666650e-01 ||r(i)||/||b|| 8.917392738093e-03
> 9649 KSP Residual norm 1.080641719971e+00 % max 1.154420890958e+02 min 1.254364806923e-01 max/min 9.203230867027e+02
 > 9650 KSP preconditioned resid norm 1.080641719766e+00 true resid norm 1.594089470619e-01 ||r(i)||/||b|| 8.917397235527e-03
> 9650 KSP Residual norm 1.080641719766e+00 % max 1.155791388935e+02 min 1.115280748954e-01 max/min 1.036323266603e+03
 > 9651 KSP preconditioned resid norm 1.080641719668e+00 true resid norm 1.594099325489e-01 ||r(i)||/||b|| 8.917452364041e-03
> 9651 KSP Residual norm 1.080641719668e+00 % max 1.156952656131e+02 min 9.753165869338e-02 max/min 1.186232933624e+03
 > 9652 KSP preconditioned resid norm 1.080641719560e+00 true resid norm 1.594104650490e-01 ||r(i)||/||b|| 8.917482152303e-03
> 9652 KSP Residual norm 1.080641719560e+00 % max 1.157175173166e+02 min 8.164906465197e-02 max/min 1.417254659437e+03
 > 9653 KSP preconditioned resid norm 1.080641719545e+00 true resid norm 1.594102433389e-01 ||r(i)||/||b|| 8.917469749751e-03
> 9653 KSP Residual norm 1.080641719545e+00 % max 1.157284977956e+02 min 8.043379142473e-02 max/min 1.438804459490e+03
 > 9654 KSP preconditioned resid norm 1.080641719502e+00 true resid norm 1.594103748106e-01 ||r(i)||/||b|| 8.917477104328e-03
> 9654 KSP Residual norm 1.080641719502e+00 % max 1.158252103352e+02 min 8.042977537341e-02 max/min 1.440078749412e+03
 > 9655 KSP preconditioned resid norm 1.080641719500e+00 true resid norm 1.594103839160e-01 ||r(i)||/||b|| 8.917477613692e-03
> 9655 KSP Residual norm 1.080641719500e+00 % max 1.158319413225e+02 min 7.912584859399e-02 max/min 1.463895090931e+03
 > 9656 KSP preconditioned resid norm 1.080641719298e+00 true resid norm 1.594103559180e-01 ||r(i)||/||b|| 8.917476047469e-03
> 9656 KSP Residual norm 1.080641719298e+00 % max 1.164752277567e+02 min 7.459488142962e-02 max/min 1.561437266532e+03
 > 9657 KSP preconditioned resid norm 1.080641719265e+00 true resid norm 1.594102184171e-01 ||r(i)||/||b|| 8.917468355617e-03
> 9657 KSP Residual norm 1.080641719265e+00 % max 1.166579038733e+02 min 7.458594814570e-02 max/min 1.564073485335e+03
 > 9658 KSP preconditioned resid norm 1.080641717458e+00 true resid norm 1.594091333285e-01 ||r(i)||/||b|| 8.917407655346e-03
> 9658 KSP Residual norm 1.080641717458e+00 % max 1.166903646829e+02 min 6.207842503132e-02 max/min 1.879724954749e+03
 > 9659 KSP preconditioned resid norm 1.080641710951e+00 true resid norm 1.594084758922e-01 ||r(i)||/||b|| 8.917370878110e-03
> 9659 KSP Residual norm 1.080641710951e+00 % max 1.166911765130e+02 min 4.511759655558e-02 max/min 2.586378384966e+03
 > 9660 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073892570e-01 ||r(i)||/||b|| 8.917310091324e-03
> 9660 KSP Residual norm 1.080641710473e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9661 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073892624e-01 ||r(i)||/||b|| 8.917310091626e-03
> 9661 KSP Residual norm 1.080641710473e+00 % max 3.063497860835e+01 min 3.063497860835e+01 max/min 1.000000000000e+00
 > 9662 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073892715e-01 ||r(i)||/||b|| 8.917310092135e-03
> 9662 KSP Residual norm 1.080641710473e+00 % max 3.066567116490e+01 min 3.845920135843e+00 max/min 7.973559013643e+00
 > 9663 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073893803e-01 ||r(i)||/||b|| 8.917310098220e-03
> 9663 KSP Residual norm 1.080641710473e+00 % max 3.713314039929e+01 min 1.336313376350e+00 max/min 2.778774878443e+01
 > 9664 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073893840e-01 ||r(i)||/||b|| 8.917310098430e-03
> 9664 KSP Residual norm 1.080641710473e+00 % max 4.496286107838e+01 min 1.226793755688e+00 max/min 3.665070911057e+01
 > 9665 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073893901e-01 ||r(i)||/||b|| 8.917310098770e-03
> 9665 KSP Residual norm 1.080641710473e+00 % max 8.684753794468e+01 min 1.183106109633e+00 max/min 7.340638108242e+01
 > 9666 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073897030e-01 ||r(i)||/||b|| 8.917310116272e-03
> 9666 KSP Residual norm 1.080641710473e+00 % max 9.802657279239e+01 min 1.168685545918e+00 max/min 8.387762913199e+01
 > 9667 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073898787e-01 ||r(i)||/||b|| 8.917310126104e-03
> 9667 KSP Residual norm 1.080641710473e+00 % max 1.123342619847e+02 min 1.141262650540e+00 max/min 9.842980661068e+01
 > 9668 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073899832e-01 ||r(i)||/||b|| 8.917310131950e-03
> 9668 KSP Residual norm 1.080641710473e+00 % max 1.134978630027e+02 min 1.090790451862e+00 max/min 1.040510235573e+02
 > 9669 KSP preconditioned resid norm 1.080641710472e+00 true resid norm 1.594074437274e-01 ||r(i)||/||b|| 8.917313138421e-03
> 9669 KSP Residual norm 1.080641710472e+00 % max 1.139911467053e+02 min 4.122424185123e-01 max/min 2.765148407498e+02
 > 9670 KSP preconditioned resid norm 1.080641710471e+00 true resid norm 1.594075064381e-01 ||r(i)||/||b|| 8.917316646478e-03
> 9670 KSP Residual norm 1.080641710471e+00 % max 1.140007007543e+02 min 2.895766957825e-01 max/min 3.936805081855e+02
 > 9671 KSP preconditioned resid norm 1.080641710471e+00 true resid norm 1.594075034738e-01 ||r(i)||/||b|| 8.917316480653e-03
> 9671 KSP Residual norm 1.080641710471e+00 % max 1.140387089437e+02 min 2.881955202443e-01 max/min 3.956991033277e+02
 > 9672 KSP preconditioned resid norm 1.080641710470e+00 true resid norm 1.594074784660e-01 ||r(i)||/||b|| 8.917315081711e-03
> 9672 KSP Residual norm 1.080641710470e+00 % max 1.140387584514e+02 min 2.501644562253e-01 max/min 4.558551609294e+02
 > 9673 KSP preconditioned resid norm 1.080641710468e+00 true resid norm 1.594074777329e-01 ||r(i)||/||b|| 8.917315040700e-03
> 9673 KSP Residual norm 1.080641710468e+00 % max 1.141359894823e+02 min 2.500652210717e-01 max/min 4.564248838488e+02
 > 9674 KSP preconditioned resid norm 1.080641710467e+00 true resid norm 1.594074707419e-01 ||r(i)||/||b|| 8.917314649619e-03
> 9674 KSP Residual norm 1.080641710467e+00 % max 1.141719424825e+02 min 2.470352404045e-01 max/min 4.621686456374e+02
 > 9675 KSP preconditioned resid norm 1.080641710439e+00 true resid norm 1.594074050132e-01 ||r(i)||/||b|| 8.917310972734e-03
> 9675 KSP Residual norm 1.080641710439e+00 % max 1.141769957478e+02 min 2.461583334135e-01 max/min 4.638355897383e+02
 > 9676 KSP preconditioned resid norm 1.080641710435e+00 true resid norm 1.594072732317e-01 ||r(i)||/||b|| 8.917303600825e-03
> 9676 KSP Residual norm 1.080641710435e+00 % max 1.150247840524e+02 min 1.817432478135e-01 max/min 6.328971526384e+02
 > 9677 KSP preconditioned resid norm 1.080641710313e+00 true resid norm 1.594068192028e-01 ||r(i)||/||b|| 8.917278202275e-03
> 9677 KSP Residual norm 1.080641710313e+00 % max 1.153658698688e+02 min 1.758229849082e-01 max/min 6.561478291873e+02
 > 9678 KSP preconditioned resid norm 1.080641710294e+00 true resid norm 1.594066656020e-01 ||r(i)||/||b|| 8.917269609788e-03
> 9678 KSP Residual norm 1.080641710294e+00 % max 1.154409214869e+02 min 1.682261493961e-01 max/min 6.862245964808e+02
 > 9679 KSP preconditioned resid norm 1.080641709867e+00 true resid norm 1.594050456081e-01 ||r(i)||/||b|| 8.917178986714e-03
> 9679 KSP Residual norm 1.080641709867e+00 % max 1.154410567101e+02 min 1.254614849745e-01 max/min 9.201314390116e+02
 > 9680 KSP preconditioned resid norm 1.080641709664e+00 true resid norm 1.594049650069e-01 ||r(i)||/||b|| 8.917174477851e-03
> 9680 KSP Residual norm 1.080641709664e+00 % max 1.155780217907e+02 min 1.115227545913e-01 max/min 1.036362688622e+03
 > 9681 KSP preconditioned resid norm 1.080641709568e+00 true resid norm 1.594039822189e-01 ||r(i)||/||b|| 8.917119500317e-03
> 9681 KSP Residual norm 1.080641709568e+00 % max 1.156949294099e+02 min 9.748012982669e-02 max/min 1.186856538000e+03
 > 9682 KSP preconditioned resid norm 1.080641709462e+00 true resid norm 1.594034585197e-01 ||r(i)||/||b|| 8.917090204385e-03
> 9682 KSP Residual norm 1.080641709462e+00 % max 1.157178049396e+02 min 8.161660044005e-02 max/min 1.417821917547e+03
 > 9683 KSP preconditioned resid norm 1.080641709447e+00 true resid norm 1.594036816693e-01 ||r(i)||/||b|| 8.917102687458e-03
> 9683 KSP Residual norm 1.080641709447e+00 % max 1.157298376396e+02 min 8.041659530019e-02 max/min 1.439128791856e+03
 > 9684 KSP preconditioned resid norm 1.080641709407e+00 true resid norm 1.594035571975e-01 ||r(i)||/||b|| 8.917095724454e-03
> 9684 KSP Residual norm 1.080641709407e+00 % max 1.158244705264e+02 min 8.041209608100e-02 max/min 1.440386162919e+03
 > 9685 KSP preconditioned resid norm 1.080641709405e+00 true resid norm 1.594035489927e-01 ||r(i)||/||b|| 8.917095265477e-03
> 9685 KSP Residual norm 1.080641709405e+00 % max 1.158301451854e+02 min 7.912026880308e-02 max/min 1.463975627707e+03
 > 9686 KSP preconditioned resid norm 1.080641709207e+00 true resid norm 1.594035774591e-01 ||r(i)||/||b|| 8.917096857899e-03
> 9686 KSP Residual norm 1.080641709207e+00 % max 1.164678839370e+02 min 7.460755571674e-02 max/min 1.561073577845e+03
 > 9687 KSP preconditioned resid norm 1.080641709174e+00 true resid norm 1.594037147171e-01 ||r(i)||/||b|| 8.917104536162e-03
> 9687 KSP Residual norm 1.080641709174e+00 % max 1.166488052404e+02 min 7.459794478802e-02 max/min 1.563699986264e+03
 > 9688 KSP preconditioned resid norm 1.080641707398e+00 true resid norm 1.594047860513e-01 ||r(i)||/||b|| 8.917164467006e-03
> 9688 KSP Residual norm 1.080641707398e+00 % max 1.166807852257e+02 min 6.210503072987e-02 max/min 1.878765437428e+03
 > 9689 KSP preconditioned resid norm 1.080641701010e+00 true resid norm 1.594054414016e-01 ||r(i)||/||b|| 8.917201127549e-03
> 9689 KSP Residual norm 1.080641701010e+00 % max 1.166815140099e+02 min 4.513527468187e-02 max/min 2.585151299782e+03
 > 9690 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065078534e-01 ||r(i)||/||b|| 8.917260785273e-03
> 9690 KSP Residual norm 1.080641700548e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9691 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065078481e-01 ||r(i)||/||b|| 8.917260784977e-03
> 9691 KSP Residual norm 1.080641700548e+00 % max 3.063462923862e+01 min 3.063462923862e+01 max/min 1.000000000000e+00
 > 9692 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065078391e-01 ||r(i)||/||b|| 8.917260784472e-03
> 9692 KSP Residual norm 1.080641700548e+00 % max 3.066527639129e+01 min 3.844401168431e+00 max/min 7.976606771193e+00
 > 9693 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065077314e-01 ||r(i)||/||b|| 8.917260778448e-03
> 9693 KSP Residual norm 1.080641700548e+00 % max 3.714560719346e+01 min 1.336559823443e+00 max/min 2.779195255007e+01
 > 9694 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065077277e-01 ||r(i)||/||b|| 8.917260778237e-03
> 9694 KSP Residual norm 1.080641700548e+00 % max 4.500980776068e+01 min 1.226798344943e+00 max/min 3.668883965014e+01
 > 9695 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065077215e-01 ||r(i)||/||b|| 8.917260777894e-03
> 9695 KSP Residual norm 1.080641700548e+00 % max 8.688252795875e+01 min 1.183121330492e+00 max/min 7.343501103356e+01
 > 9696 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065074170e-01 ||r(i)||/||b|| 8.917260760857e-03
> 9696 KSP Residual norm 1.080641700548e+00 % max 9.802496799855e+01 min 1.168942571066e+00 max/min 8.385781339895e+01
 > 9697 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065072444e-01 ||r(i)||/||b|| 8.917260751202e-03
> 9697 KSP Residual norm 1.080641700548e+00 % max 1.122410641497e+02 min 1.141677885656e+00 max/min 9.831237475989e+01
 > 9698 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065071406e-01 ||r(i)||/||b|| 8.917260745398e-03
> 9698 KSP Residual norm 1.080641700548e+00 % max 1.134941426413e+02 min 1.090790153651e+00 max/min 1.040476413006e+02
 > 9699 KSP preconditioned resid norm 1.080641700547e+00 true resid norm 1.594064538413e-01 ||r(i)||/||b|| 8.917257763815e-03
> 9699 KSP Residual norm 1.080641700547e+00 % max 1.139914632588e+02 min 4.119681054781e-01 max/min 2.766997292824e+02
 > 9700 KSP preconditioned resid norm 1.080641700546e+00 true resid norm 1.594063917269e-01 ||r(i)||/||b|| 8.917254289111e-03
> 9700 KSP Residual norm 1.080641700546e+00 % max 1.140011377578e+02 min 2.894500209686e-01 max/min 3.938543081679e+02
 > 9701 KSP preconditioned resid norm 1.080641700546e+00 true resid norm 1.594063946692e-01 ||r(i)||/||b|| 8.917254453705e-03
> 9701 KSP Residual norm 1.080641700546e+00 % max 1.140392249545e+02 min 2.880548133071e-01 max/min 3.958941829341e+02
 > 9702 KSP preconditioned resid norm 1.080641700546e+00 true resid norm 1.594064194159e-01 ||r(i)||/||b|| 8.917255838042e-03
> 9702 KSP Residual norm 1.080641700546e+00 % max 1.140392678944e+02 min 2.501716607446e-01 max/min 4.558440694479e+02
 > 9703 KSP preconditioned resid norm 1.080641700543e+00 true resid norm 1.594064201661e-01 ||r(i)||/||b|| 8.917255880013e-03
> 9703 KSP Residual norm 1.080641700543e+00 % max 1.141360426034e+02 min 2.500714053220e-01 max/min 4.564138089137e+02
 > 9704 KSP preconditioned resid norm 1.080641700542e+00 true resid norm 1.594064270279e-01 ||r(i)||/||b|| 8.917256263859e-03
> 9704 KSP Residual norm 1.080641700542e+00 % max 1.141719170495e+02 min 2.470524869868e-01 max/min 4.621362789824e+02
 > 9705 KSP preconditioned resid norm 1.080641700515e+00 true resid norm 1.594064921269e-01 ||r(i)||/||b|| 8.917259905523e-03
> 9705 KSP Residual norm 1.080641700515e+00 % max 1.141770017414e+02 min 2.461727640845e-01 max/min 4.638084239987e+02
 > 9706 KSP preconditioned resid norm 1.080641700511e+00 true resid norm 1.594066225181e-01 ||r(i)||/||b|| 8.917267199657e-03
> 9706 KSP Residual norm 1.080641700511e+00 % max 1.150251667711e+02 min 1.817294170466e-01 max/min 6.329474261263e+02
 > 9707 KSP preconditioned resid norm 1.080641700391e+00 true resid norm 1.594070728983e-01 ||r(i)||/||b|| 8.917292394097e-03
> 9707 KSP Residual norm 1.080641700391e+00 % max 1.153670687494e+02 min 1.757829178698e-01 max/min 6.563042083238e+02
 > 9708 KSP preconditioned resid norm 1.080641700372e+00 true resid norm 1.594072248425e-01 ||r(i)||/||b|| 8.917300893916e-03
> 9708 KSP Residual norm 1.080641700372e+00 % max 1.154419380718e+02 min 1.682005223292e-01 max/min 6.863351936912e+02
 > 9709 KSP preconditioned resid norm 1.080641699955e+00 true resid norm 1.594088278507e-01 ||r(i)||/||b|| 8.917390566803e-03
> 9709 KSP Residual norm 1.080641699955e+00 % max 1.154420821193e+02 min 1.254367014624e-01 max/min 9.203214113045e+02
 > 9710 KSP preconditioned resid norm 1.080641699758e+00 true resid norm 1.594089066545e-01 ||r(i)||/||b|| 8.917394975116e-03
> 9710 KSP Residual norm 1.080641699758e+00 % max 1.155791306030e+02 min 1.115278858784e-01 max/min 1.036324948623e+03
 > 9711 KSP preconditioned resid norm 1.080641699664e+00 true resid norm 1.594098725388e-01 ||r(i)||/||b|| 8.917449007053e-03
> 9711 KSP Residual norm 1.080641699664e+00 % max 1.156952614563e+02 min 9.753133694719e-02 max/min 1.186236804269e+03
 > 9712 KSP preconditioned resid norm 1.080641699560e+00 true resid norm 1.594103943811e-01 ||r(i)||/||b|| 8.917478199111e-03
> 9712 KSP Residual norm 1.080641699560e+00 % max 1.157175157006e+02 min 8.164872572382e-02 max/min 1.417260522743e+03
 > 9713 KSP preconditioned resid norm 1.080641699546e+00 true resid norm 1.594101771105e-01 ||r(i)||/||b|| 8.917466044914e-03
> 9713 KSP Residual norm 1.080641699546e+00 % max 1.157285025175e+02 min 8.043358651149e-02 max/min 1.438808183705e+03
 > 9714 KSP preconditioned resid norm 1.080641699505e+00 true resid norm 1.594103059104e-01 ||r(i)||/||b|| 8.917473250025e-03
> 9714 KSP Residual norm 1.080641699505e+00 % max 1.158251990486e+02 min 8.042956633721e-02 max/min 1.440082351843e+03
 > 9715 KSP preconditioned resid norm 1.080641699503e+00 true resid norm 1.594103148215e-01 ||r(i)||/||b|| 8.917473748516e-03
> 9715 KSP Residual norm 1.080641699503e+00 % max 1.158319218998e+02 min 7.912575668150e-02 max/min 1.463896545925e+03
 > 9716 KSP preconditioned resid norm 1.080641699309e+00 true resid norm 1.594102873744e-01 ||r(i)||/||b|| 8.917472213115e-03
> 9716 KSP Residual norm 1.080641699309e+00 % max 1.164751648212e+02 min 7.459498920670e-02 max/min 1.561434166824e+03
 > 9717 KSP preconditioned resid norm 1.080641699277e+00 true resid norm 1.594101525703e-01 ||r(i)||/||b|| 8.917464672122e-03
> 9717 KSP Residual norm 1.080641699277e+00 % max 1.166578264103e+02 min 7.458604738274e-02 max/min 1.564070365758e+03
 > 9718 KSP preconditioned resid norm 1.080641697541e+00 true resid norm 1.594090891807e-01 ||r(i)||/||b|| 8.917405185702e-03
> 9718 KSP Residual norm 1.080641697541e+00 % max 1.166902828397e+02 min 6.207863457218e-02 max/min 1.879717291527e+03
 > 9719 KSP preconditioned resid norm 1.080641691292e+00 true resid norm 1.594084448306e-01 ||r(i)||/||b|| 8.917369140517e-03
> 9719 KSP Residual norm 1.080641691292e+00 % max 1.166910940162e+02 min 4.511779816158e-02 max/min 2.586364999424e+03
 > 9720 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073798840e-01 ||r(i)||/||b|| 8.917309566993e-03
> 9720 KSP Residual norm 1.080641690833e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9721 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073798892e-01 ||r(i)||/||b|| 8.917309567288e-03
> 9721 KSP Residual norm 1.080641690833e+00 % max 3.063497720423e+01 min 3.063497720423e+01 max/min 1.000000000000e+00
 > 9722 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073798982e-01 ||r(i)||/||b|| 8.917309567787e-03
> 9722 KSP Residual norm 1.080641690833e+00 % max 3.066566915002e+01 min 3.845904218039e+00 max/min 7.973591491484e+00
 > 9723 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073800048e-01 ||r(i)||/||b|| 8.917309573750e-03
> 9723 KSP Residual norm 1.080641690833e+00 % max 3.713330064708e+01 min 1.336316867286e+00 max/min 2.778779611043e+01
 > 9724 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073800084e-01 ||r(i)||/||b|| 8.917309573955e-03
> 9724 KSP Residual norm 1.080641690833e+00 % max 4.496345800250e+01 min 1.226793989785e+00 max/min 3.665118868930e+01
 > 9725 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073800144e-01 ||r(i)||/||b|| 8.917309574290e-03
> 9725 KSP Residual norm 1.080641690833e+00 % max 8.684799302076e+01 min 1.183106260116e+00 max/min 7.340675639080e+01
 > 9726 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073803210e-01 ||r(i)||/||b|| 8.917309591441e-03
> 9726 KSP Residual norm 1.080641690833e+00 % max 9.802654643741e+01 min 1.168688159857e+00 max/min 8.387741897664e+01
 > 9727 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073804933e-01 ||r(i)||/||b|| 8.917309601077e-03
> 9727 KSP Residual norm 1.080641690833e+00 % max 1.123333202151e+02 min 1.141267080659e+00 max/min 9.842859933384e+01
 > 9728 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073805957e-01 ||r(i)||/||b|| 8.917309606809e-03
> 9728 KSP Residual norm 1.080641690833e+00 % max 1.134978238790e+02 min 1.090790456842e+00 max/min 1.040509872149e+02
 > 9729 KSP preconditioned resid norm 1.080641690832e+00 true resid norm 1.594074332665e-01 ||r(i)||/||b|| 8.917312553232e-03
> 9729 KSP Residual norm 1.080641690832e+00 % max 1.139911500486e+02 min 4.122400558994e-01 max/min 2.765164336102e+02
 > 9730 KSP preconditioned resid norm 1.080641690831e+00 true resid norm 1.594074947247e-01 ||r(i)||/||b|| 8.917315991226e-03
> 9730 KSP Residual norm 1.080641690831e+00 % max 1.140007051733e+02 min 2.895754967285e-01 max/min 3.936821535706e+02
 > 9731 KSP preconditioned resid norm 1.080641690831e+00 true resid norm 1.594074918191e-01 ||r(i)||/||b|| 8.917315828690e-03
> 9731 KSP Residual norm 1.080641690831e+00 % max 1.140387143094e+02 min 2.881941911453e-01 max/min 3.957009468380e+02
 > 9732 KSP preconditioned resid norm 1.080641690830e+00 true resid norm 1.594074673079e-01 ||r(i)||/||b|| 8.917314457521e-03
> 9732 KSP Residual norm 1.080641690830e+00 % max 1.140387637599e+02 min 2.501645326450e-01 max/min 4.558550428958e+02
 > 9733 KSP preconditioned resid norm 1.080641690828e+00 true resid norm 1.594074665892e-01 ||r(i)||/||b|| 8.917314417314e-03
> 9733 KSP Residual norm 1.080641690828e+00 % max 1.141359902062e+02 min 2.500652873669e-01 max/min 4.564247657404e+02
 > 9734 KSP preconditioned resid norm 1.080641690827e+00 true resid norm 1.594074597377e-01 ||r(i)||/||b|| 8.917314034043e-03
> 9734 KSP Residual norm 1.080641690827e+00 % max 1.141719421992e+02 min 2.470354276866e-01 max/min 4.621682941123e+02
 > 9735 KSP preconditioned resid norm 1.080641690800e+00 true resid norm 1.594073953224e-01 ||r(i)||/||b|| 8.917310430625e-03
> 9735 KSP Residual norm 1.080641690800e+00 % max 1.141769958343e+02 min 2.461584786890e-01 max/min 4.638353163473e+02
 > 9736 KSP preconditioned resid norm 1.080641690797e+00 true resid norm 1.594072661531e-01 ||r(i)||/||b|| 8.917303204847e-03
> 9736 KSP Residual norm 1.080641690797e+00 % max 1.150247889475e+02 min 1.817430598855e-01 max/min 6.328978340080e+02
 > 9737 KSP preconditioned resid norm 1.080641690679e+00 true resid norm 1.594068211899e-01 ||r(i)||/||b|| 8.917278313432e-03
> 9737 KSP Residual norm 1.080641690679e+00 % max 1.153658852526e+02 min 1.758225138542e-01 max/min 6.561496745986e+02
 > 9738 KSP preconditioned resid norm 1.080641690661e+00 true resid norm 1.594066706603e-01 ||r(i)||/||b|| 8.917269892752e-03
> 9738 KSP Residual norm 1.080641690661e+00 % max 1.154409350014e+02 min 1.682258367468e-01 max/min 6.862259521714e+02
 > 9739 KSP preconditioned resid norm 1.080641690251e+00 true resid norm 1.594050830368e-01 ||r(i)||/||b|| 8.917181080485e-03
> 9739 KSP Residual norm 1.080641690251e+00 % max 1.154410703479e+02 min 1.254612102469e-01 max/min 9.201335625627e+02
 > 9740 KSP preconditioned resid norm 1.080641690057e+00 true resid norm 1.594050040532e-01 ||r(i)||/||b|| 8.917176662114e-03
> 9740 KSP Residual norm 1.080641690057e+00 % max 1.155780358111e+02 min 1.115226752201e-01 max/min 1.036363551923e+03
 > 9741 KSP preconditioned resid norm 1.080641689964e+00 true resid norm 1.594040409622e-01 ||r(i)||/||b|| 8.917122786435e-03
> 9741 KSP Residual norm 1.080641689964e+00 % max 1.156949319460e+02 min 9.748084084270e-02 max/min 1.186847907198e+03
 > 9742 KSP preconditioned resid norm 1.080641689862e+00 true resid norm 1.594035276798e-01 ||r(i)||/||b|| 8.917094073223e-03
> 9742 KSP Residual norm 1.080641689862e+00 % max 1.157177974822e+02 min 8.161690928512e-02 max/min 1.417816461022e+03
 > 9743 KSP preconditioned resid norm 1.080641689848e+00 true resid norm 1.594037462881e-01 ||r(i)||/||b|| 8.917106302257e-03
> 9743 KSP Residual norm 1.080641689848e+00 % max 1.157298152734e+02 min 8.041673363017e-02 max/min 1.439126038190e+03
 > 9744 KSP preconditioned resid norm 1.080641689809e+00 true resid norm 1.594036242374e-01 ||r(i)||/||b|| 8.917099474695e-03
> 9744 KSP Residual norm 1.080641689809e+00 % max 1.158244737331e+02 min 8.041224000025e-02 max/min 1.440383624841e+03
 > 9745 KSP preconditioned resid norm 1.080641689808e+00 true resid norm 1.594036161930e-01 ||r(i)||/||b|| 8.917099024685e-03
> 9745 KSP Residual norm 1.080641689808e+00 % max 1.158301611517e+02 min 7.912028815054e-02 max/min 1.463975471516e+03
 > 9746 KSP preconditioned resid norm 1.080641689617e+00 true resid norm 1.594036440841e-01 ||r(i)||/||b|| 8.917100584928e-03
> 9746 KSP Residual norm 1.080641689617e+00 % max 1.164679674294e+02 min 7.460741052548e-02 max/min 1.561077734894e+03
 > 9747 KSP preconditioned resid norm 1.080641689585e+00 true resid norm 1.594037786262e-01 ||r(i)||/||b|| 8.917108111263e-03
> 9747 KSP Residual norm 1.080641689585e+00 % max 1.166489093034e+02 min 7.459780450955e-02 max/min 1.563704321734e+03
 > 9748 KSP preconditioned resid norm 1.080641687880e+00 true resid norm 1.594048285858e-01 ||r(i)||/||b|| 8.917166846404e-03
> 9748 KSP Residual norm 1.080641687880e+00 % max 1.166808944816e+02 min 6.210471238399e-02 max/min 1.878776827114e+03
 > 9749 KSP preconditioned resid norm 1.080641681745e+00 true resid norm 1.594054707973e-01 ||r(i)||/||b|| 8.917202771956e-03
> 9749 KSP Residual norm 1.080641681745e+00 % max 1.166816242497e+02 min 4.513512286802e-02 max/min 2.585162437485e+03
 > 9750 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065161384e-01 ||r(i)||/||b|| 8.917261248737e-03
> 9750 KSP Residual norm 1.080641681302e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9751 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065161332e-01 ||r(i)||/||b|| 8.917261248446e-03
> 9751 KSP Residual norm 1.080641681302e+00 % max 3.063463477969e+01 min 3.063463477969e+01 max/min 1.000000000000e+00
 > 9752 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065161243e-01 ||r(i)||/||b|| 8.917261247951e-03
> 9752 KSP Residual norm 1.080641681302e+00 % max 3.066528223339e+01 min 3.844415595957e+00 max/min 7.976578355796e+00
 > 9753 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065160188e-01 ||r(i)||/||b|| 8.917261242049e-03
> 9753 KSP Residual norm 1.080641681302e+00 % max 3.714551741771e+01 min 1.336558367241e+00 max/min 2.779191566050e+01
 > 9754 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065160151e-01 ||r(i)||/||b|| 8.917261241840e-03
> 9754 KSP Residual norm 1.080641681302e+00 % max 4.500946346995e+01 min 1.226798482639e+00 max/min 3.668855489054e+01
 > 9755 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065160091e-01 ||r(i)||/||b|| 8.917261241506e-03
> 9755 KSP Residual norm 1.080641681302e+00 % max 8.688228012809e+01 min 1.183121177118e+00 max/min 7.343481108144e+01
 > 9756 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065157105e-01 ||r(i)||/||b|| 8.917261224803e-03
> 9756 KSP Residual norm 1.080641681302e+00 % max 9.802497401249e+01 min 1.168940055038e+00 max/min 8.385799903943e+01
 > 9757 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065155414e-01 ||r(i)||/||b|| 8.917261215340e-03
> 9757 KSP Residual norm 1.080641681302e+00 % max 1.122419823631e+02 min 1.141674012007e+00 max/min 9.831351259875e+01
 > 9758 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065154397e-01 ||r(i)||/||b|| 8.917261209650e-03
> 9758 KSP Residual norm 1.080641681302e+00 % max 1.134941779165e+02 min 1.090790164362e+00 max/min 1.040476726180e+02
 > 9759 KSP preconditioned resid norm 1.080641681301e+00 true resid norm 1.594064632071e-01 ||r(i)||/||b|| 8.917258287741e-03
> 9759 KSP Residual norm 1.080641681301e+00 % max 1.139914602803e+02 min 4.119712251563e-01 max/min 2.766976267263e+02
 > 9760 KSP preconditioned resid norm 1.080641681300e+00 true resid norm 1.594064023343e-01 ||r(i)||/||b|| 8.917254882493e-03
> 9760 KSP Residual norm 1.080641681300e+00 % max 1.140011334474e+02 min 2.894513550128e-01 max/min 3.938524780524e+02
 > 9761 KSP preconditioned resid norm 1.080641681299e+00 true resid norm 1.594064052181e-01 ||r(i)||/||b|| 8.917255043816e-03
> 9761 KSP Residual norm 1.080641681299e+00 % max 1.140392200085e+02 min 2.880562980628e-01 max/min 3.958921251693e+02
 > 9762 KSP preconditioned resid norm 1.080641681299e+00 true resid norm 1.594064294735e-01 ||r(i)||/||b|| 8.917256400669e-03
> 9762 KSP Residual norm 1.080641681299e+00 % max 1.140392630219e+02 min 2.501715931763e-01 max/min 4.558441730892e+02
 > 9763 KSP preconditioned resid norm 1.080641681297e+00 true resid norm 1.594064302085e-01 ||r(i)||/||b|| 8.917256441789e-03
> 9763 KSP Residual norm 1.080641681297e+00 % max 1.141360422663e+02 min 2.500713478839e-01 max/min 4.564139123977e+02
 > 9764 KSP preconditioned resid norm 1.080641681296e+00 true resid norm 1.594064369343e-01 ||r(i)||/||b|| 8.917256818032e-03
> 9764 KSP Residual norm 1.080641681296e+00 % max 1.141719172739e+02 min 2.470523296471e-01 max/min 4.621365742109e+02
 > 9765 KSP preconditioned resid norm 1.080641681269e+00 true resid norm 1.594065007316e-01 ||r(i)||/||b|| 8.917260386877e-03
> 9765 KSP Residual norm 1.080641681269e+00 % max 1.141770017074e+02 min 2.461726211496e-01 max/min 4.638086931610e+02
 > 9766 KSP preconditioned resid norm 1.080641681266e+00 true resid norm 1.594066285385e-01 ||r(i)||/||b|| 8.917267536440e-03
> 9766 KSP Residual norm 1.080641681266e+00 % max 1.150251639969e+02 min 1.817295045513e-01 max/min 6.329471060897e+02
 > 9767 KSP preconditioned resid norm 1.080641681150e+00 true resid norm 1.594070699054e-01 ||r(i)||/||b|| 8.917292226672e-03
> 9767 KSP Residual norm 1.080641681150e+00 % max 1.153670601170e+02 min 1.757832464778e-01 max/min 6.563029323251e+02
 > 9768 KSP preconditioned resid norm 1.080641681133e+00 true resid norm 1.594072188128e-01 ||r(i)||/||b|| 8.917300556609e-03
> 9768 KSP Residual norm 1.080641681133e+00 % max 1.154419312149e+02 min 1.682007202940e-01 max/min 6.863343451393e+02
 > 9769 KSP preconditioned resid norm 1.080641680732e+00 true resid norm 1.594087897943e-01 ||r(i)||/||b|| 8.917388437917e-03
> 9769 KSP Residual norm 1.080641680732e+00 % max 1.154420752094e+02 min 1.254369186538e-01 max/min 9.203197627011e+02
 > 9770 KSP preconditioned resid norm 1.080641680543e+00 true resid norm 1.594088670353e-01 ||r(i)||/||b|| 8.917392758804e-03
> 9770 KSP Residual norm 1.080641680543e+00 % max 1.155791224140e+02 min 1.115277033208e-01 max/min 1.036326571538e+03
 > 9771 KSP preconditioned resid norm 1.080641680452e+00 true resid norm 1.594098136932e-01 ||r(i)||/||b|| 8.917445715209e-03
> 9771 KSP Residual norm 1.080641680452e+00 % max 1.156952573953e+02 min 9.753101753312e-02 max/min 1.186240647556e+03
 > 9772 KSP preconditioned resid norm 1.080641680352e+00 true resid norm 1.594103250846e-01 ||r(i)||/||b|| 8.917474322641e-03
> 9772 KSP Residual norm 1.080641680352e+00 % max 1.157175142052e+02 min 8.164839358709e-02 max/min 1.417266269688e+03
 > 9773 KSP preconditioned resid norm 1.080641680339e+00 true resid norm 1.594101121664e-01 ||r(i)||/||b|| 8.917462411912e-03
> 9773 KSP Residual norm 1.080641680339e+00 % max 1.157285073186e+02 min 8.043338619163e-02 max/min 1.438811826757e+03
 > 9774 KSP preconditioned resid norm 1.080641680299e+00 true resid norm 1.594102383476e-01 ||r(i)||/||b|| 8.917469470538e-03
> 9774 KSP Residual norm 1.080641680299e+00 % max 1.158251880541e+02 min 8.042936196082e-02 max/min 1.440085874492e+03
 > 9775 KSP preconditioned resid norm 1.080641680298e+00 true resid norm 1.594102470687e-01 ||r(i)||/||b|| 8.917469958400e-03
> 9775 KSP Residual norm 1.080641680298e+00 % max 1.158319028736e+02 min 7.912566724984e-02 max/min 1.463897960037e+03
 > 9776 KSP preconditioned resid norm 1.080641680112e+00 true resid norm 1.594102201623e-01 ||r(i)||/||b|| 8.917468453243e-03
> 9776 KSP Residual norm 1.080641680112e+00 % max 1.164751028861e+02 min 7.459509526345e-02 max/min 1.561431116546e+03
 > 9777 KSP preconditioned resid norm 1.080641680081e+00 true resid norm 1.594100880055e-01 ||r(i)||/||b|| 8.917461060344e-03
> 9777 KSP Residual norm 1.080641680081e+00 % max 1.166577501679e+02 min 7.458614509876e-02 max/min 1.564067294448e+03
 > 9778 KSP preconditioned resid norm 1.080641678414e+00 true resid norm 1.594090458938e-01 ||r(i)||/||b|| 8.917402764217e-03
> 9778 KSP Residual norm 1.080641678414e+00 % max 1.166902022924e+02 min 6.207884124039e-02 max/min 1.879709736213e+03
 > 9779 KSP preconditioned resid norm 1.080641672412e+00 true resid norm 1.594084143785e-01 ||r(i)||/||b|| 8.917367437011e-03
> 9779 KSP Residual norm 1.080641672412e+00 % max 1.166910128239e+02 min 4.511799534103e-02 max/min 2.586351896663e+03
 > 9780 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073707031e-01 ||r(i)||/||b|| 8.917309053412e-03
> 9780 KSP Residual norm 1.080641671971e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9781 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073707083e-01 ||r(i)||/||b|| 8.917309053702e-03
> 9781 KSP Residual norm 1.080641671971e+00 % max 3.063497578379e+01 min 3.063497578379e+01 max/min 1.000000000000e+00
 > 9782 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073707170e-01 ||r(i)||/||b|| 8.917309054190e-03
> 9782 KSP Residual norm 1.080641671971e+00 % max 3.066566713389e+01 min 3.845888622043e+00 max/min 7.973623302070e+00
 > 9783 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073708215e-01 ||r(i)||/||b|| 8.917309060034e-03
> 9783 KSP Residual norm 1.080641671971e+00 % max 3.713345706068e+01 min 1.336320269525e+00 max/min 2.778784241137e+01
 > 9784 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073708251e-01 ||r(i)||/||b|| 8.917309060235e-03
> 9784 KSP Residual norm 1.080641671971e+00 % max 4.496404075363e+01 min 1.226794215442e+00 max/min 3.665165696713e+01
 > 9785 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073708309e-01 ||r(i)||/||b|| 8.917309060564e-03
> 9785 KSP Residual norm 1.080641671971e+00 % max 8.684843710054e+01 min 1.183106407741e+00 max/min 7.340712258198e+01
 > 9786 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073711314e-01 ||r(i)||/||b|| 8.917309077372e-03
> 9786 KSP Residual norm 1.080641671971e+00 % max 9.802652080694e+01 min 1.168690722569e+00 max/min 8.387721311884e+01
 > 9787 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073713003e-01 ||r(i)||/||b|| 8.917309086817e-03
> 9787 KSP Residual norm 1.080641671971e+00 % max 1.123323967807e+02 min 1.141271419633e+00 max/min 9.842741599265e+01
 > 9788 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073714007e-01 ||r(i)||/||b|| 8.917309092435e-03
> 9788 KSP Residual norm 1.080641671971e+00 % max 1.134977855491e+02 min 1.090790461557e+00 max/min 1.040509516255e+02
 > 9789 KSP preconditioned resid norm 1.080641671970e+00 true resid norm 1.594074230188e-01 ||r(i)||/||b|| 8.917311979972e-03
> 9789 KSP Residual norm 1.080641671970e+00 % max 1.139911533240e+02 min 4.122377311421e-01 max/min 2.765180009315e+02
 > 9790 KSP preconditioned resid norm 1.080641671969e+00 true resid norm 1.594074832488e-01 ||r(i)||/||b|| 8.917315349259e-03
> 9790 KSP Residual norm 1.080641671969e+00 % max 1.140007095063e+02 min 2.895743194700e-01 max/min 3.936837690403e+02
 > 9791 KSP preconditioned resid norm 1.080641671969e+00 true resid norm 1.594074804009e-01 ||r(i)||/||b|| 8.917315189946e-03
> 9791 KSP Residual norm 1.080641671969e+00 % max 1.140387195674e+02 min 2.881928861513e-01 max/min 3.957027568944e+02
 > 9792 KSP preconditioned resid norm 1.080641671968e+00 true resid norm 1.594074563767e-01 ||r(i)||/||b|| 8.917313846024e-03
> 9792 KSP Residual norm 1.080641671968e+00 % max 1.140387689617e+02 min 2.501646075030e-01 max/min 4.558549272813e+02
 > 9793 KSP preconditioned resid norm 1.080641671966e+00 true resid norm 1.594074556720e-01 ||r(i)||/||b|| 8.917313806607e-03
> 9793 KSP Residual norm 1.080641671966e+00 % max 1.141359909124e+02 min 2.500653522913e-01 max/min 4.564246500628e+02
 > 9794 KSP preconditioned resid norm 1.080641671965e+00 true resid norm 1.594074489575e-01 ||r(i)||/||b|| 8.917313430994e-03
> 9794 KSP Residual norm 1.080641671965e+00 % max 1.141719419220e+02 min 2.470356110582e-01 max/min 4.621679499282e+02
 > 9795 KSP preconditioned resid norm 1.080641671939e+00 true resid norm 1.594073858301e-01 ||r(i)||/||b|| 8.917309899620e-03
> 9795 KSP Residual norm 1.080641671939e+00 % max 1.141769959186e+02 min 2.461586211459e-01 max/min 4.638350482589e+02
 > 9796 KSP preconditioned resid norm 1.080641671936e+00 true resid norm 1.594072592237e-01 ||r(i)||/||b|| 8.917302817214e-03
> 9796 KSP Residual norm 1.080641671936e+00 % max 1.150247937261e+02 min 1.817428765765e-01 max/min 6.328984986528e+02
 > 9797 KSP preconditioned resid norm 1.080641671823e+00 true resid norm 1.594068231505e-01 ||r(i)||/||b|| 8.917278423111e-03
> 9797 KSP Residual norm 1.080641671823e+00 % max 1.153659002697e+02 min 1.758220533048e-01 max/min 6.561514787326e+02
 > 9798 KSP preconditioned resid norm 1.080641671805e+00 true resid norm 1.594066756326e-01 ||r(i)||/||b|| 8.917270170903e-03
> 9798 KSP Residual norm 1.080641671805e+00 % max 1.154409481864e+02 min 1.682255312531e-01 max/min 6.862272767188e+02
 > 9799 KSP preconditioned resid norm 1.080641671412e+00 true resid norm 1.594051197519e-01 ||r(i)||/||b|| 8.917183134347e-03
> 9799 KSP Residual norm 1.080641671412e+00 % max 1.154410836529e+02 min 1.254609413083e-01 max/min 9.201356410140e+02
 > 9800 KSP preconditioned resid norm 1.080641671225e+00 true resid norm 1.594050423544e-01 ||r(i)||/||b|| 8.917178804700e-03
> 9800 KSP Residual norm 1.080641671225e+00 % max 1.155780495006e+02 min 1.115226000164e-01 max/min 1.036364373532e+03
 > 9801 KSP preconditioned resid norm 1.080641671136e+00 true resid norm 1.594040985764e-01 ||r(i)||/||b|| 8.917126009400e-03
> 9801 KSP Residual norm 1.080641671136e+00 % max 1.156949344498e+02 min 9.748153395641e-02 max/min 1.186839494150e+03
 > 9802 KSP preconditioned resid norm 1.080641671038e+00 true resid norm 1.594035955111e-01 ||r(i)||/||b|| 8.917097867731e-03
> 9802 KSP Residual norm 1.080641671038e+00 % max 1.157177902650e+02 min 8.161721244731e-02 max/min 1.417811106202e+03
 > 9803 KSP preconditioned resid norm 1.080641671024e+00 true resid norm 1.594038096704e-01 ||r(i)||/||b|| 8.917109847884e-03
> 9803 KSP Residual norm 1.080641671024e+00 % max 1.157297935320e+02 min 8.041686995864e-02 max/min 1.439123328121e+03
 > 9804 KSP preconditioned resid norm 1.080641670988e+00 true resid norm 1.594036899968e-01 ||r(i)||/||b|| 8.917103153299e-03
> 9804 KSP Residual norm 1.080641670988e+00 % max 1.158244769690e+02 min 8.041238179269e-02 max/min 1.440381125230e+03
 > 9805 KSP preconditioned resid norm 1.080641670986e+00 true resid norm 1.594036821095e-01 ||r(i)||/||b|| 8.917102712083e-03
> 9805 KSP Residual norm 1.080641670986e+00 % max 1.158301768585e+02 min 7.912030787936e-02 max/min 1.463975304989e+03
 > 9806 KSP preconditioned resid norm 1.080641670803e+00 true resid norm 1.594037094369e-01 ||r(i)||/||b|| 8.917104240783e-03
> 9806 KSP Residual norm 1.080641670803e+00 % max 1.164680491000e+02 min 7.460726855236e-02 max/min 1.561081800203e+03
 > 9807 KSP preconditioned resid norm 1.080641670773e+00 true resid norm 1.594038413140e-01 ||r(i)||/||b|| 8.917111618039e-03
> 9807 KSP Residual norm 1.080641670773e+00 % max 1.166490110820e+02 min 7.459766739249e-02 max/min 1.563708560326e+03
 > 9808 KSP preconditioned resid norm 1.080641669134e+00 true resid norm 1.594048703119e-01 ||r(i)||/||b|| 8.917169180576e-03
> 9808 KSP Residual norm 1.080641669134e+00 % max 1.166810013448e+02 min 6.210440124755e-02 max/min 1.878787960288e+03
 > 9809 KSP preconditioned resid norm 1.080641663243e+00 true resid norm 1.594054996410e-01 ||r(i)||/||b|| 8.917204385483e-03
> 9809 KSP Residual norm 1.080641663243e+00 % max 1.166817320749e+02 min 4.513497352470e-02 max/min 2.585173380262e+03
 > 9810 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065242705e-01 ||r(i)||/||b|| 8.917261703653e-03
> 9810 KSP Residual norm 1.080641662817e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9811 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065242654e-01 ||r(i)||/||b|| 8.917261703367e-03
> 9811 KSP Residual norm 1.080641662817e+00 % max 3.063464017134e+01 min 3.063464017134e+01 max/min 1.000000000000e+00
 > 9812 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065242568e-01 ||r(i)||/||b|| 8.917261702882e-03
> 9812 KSP Residual norm 1.080641662817e+00 % max 3.066528792324e+01 min 3.844429757599e+00 max/min 7.976550452671e+00
 > 9813 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065241534e-01 ||r(i)||/||b|| 8.917261697099e-03
> 9813 KSP Residual norm 1.080641662817e+00 % max 3.714542869717e+01 min 1.336556919260e+00 max/min 2.779187938941e+01
 > 9814 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065241497e-01 ||r(i)||/||b|| 8.917261696894e-03
> 9814 KSP Residual norm 1.080641662817e+00 % max 4.500912339640e+01 min 1.226798613987e+00 max/min 3.668827375841e+01
 > 9815 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065241439e-01 ||r(i)||/||b|| 8.917261696565e-03
> 9815 KSP Residual norm 1.080641662817e+00 % max 8.688203511576e+01 min 1.183121026759e+00 max/min 7.343461332421e+01
 > 9816 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065238512e-01 ||r(i)||/||b|| 8.917261680193e-03
> 9816 KSP Residual norm 1.080641662817e+00 % max 9.802498010891e+01 min 1.168937586878e+00 max/min 8.385818131719e+01
 > 9817 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065236853e-01 ||r(i)||/||b|| 8.917261670916e-03
> 9817 KSP Residual norm 1.080641662817e+00 % max 1.122428829897e+02 min 1.141670208530e+00 max/min 9.831462899798e+01
 > 9818 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065235856e-01 ||r(i)||/||b|| 8.917261665338e-03
> 9818 KSP Residual norm 1.080641662817e+00 % max 1.134942125400e+02 min 1.090790174709e+00 max/min 1.040477033727e+02
 > 9819 KSP preconditioned resid norm 1.080641662816e+00 true resid norm 1.594064723991e-01 ||r(i)||/||b|| 8.917258801942e-03
> 9819 KSP Residual norm 1.080641662816e+00 % max 1.139914573562e+02 min 4.119742762810e-01 max/min 2.766955703769e+02
 > 9820 KSP preconditioned resid norm 1.080641662815e+00 true resid norm 1.594064127438e-01 ||r(i)||/||b|| 8.917255464802e-03
> 9820 KSP Residual norm 1.080641662815e+00 % max 1.140011292201e+02 min 2.894526616195e-01 max/min 3.938506855740e+02
 > 9821 KSP preconditioned resid norm 1.080641662815e+00 true resid norm 1.594064155702e-01 ||r(i)||/||b|| 8.917255622914e-03
> 9821 KSP Residual norm 1.080641662815e+00 % max 1.140392151549e+02 min 2.880577522236e-01 max/min 3.958901097943e+02
 > 9822 KSP preconditioned resid norm 1.080641662815e+00 true resid norm 1.594064393436e-01 ||r(i)||/||b|| 8.917256952808e-03
> 9822 KSP Residual norm 1.080641662815e+00 % max 1.140392582401e+02 min 2.501715268375e-01 max/min 4.558442748531e+02
 > 9823 KSP preconditioned resid norm 1.080641662812e+00 true resid norm 1.594064400637e-01 ||r(i)||/||b|| 8.917256993092e-03
> 9823 KSP Residual norm 1.080641662812e+00 % max 1.141360419319e+02 min 2.500712914815e-01 max/min 4.564140140028e+02
 > 9824 KSP preconditioned resid norm 1.080641662811e+00 true resid norm 1.594064466562e-01 ||r(i)||/||b|| 8.917257361878e-03
> 9824 KSP Residual norm 1.080641662811e+00 % max 1.141719174947e+02 min 2.470521750742e-01 max/min 4.621368642491e+02
 > 9825 KSP preconditioned resid norm 1.080641662786e+00 true resid norm 1.594065091771e-01 ||r(i)||/||b|| 8.917260859317e-03
> 9825 KSP Residual norm 1.080641662786e+00 % max 1.141770016737e+02 min 2.461724809746e-01 max/min 4.638089571251e+02
 > 9826 KSP preconditioned resid norm 1.080641662783e+00 true resid norm 1.594066344484e-01 ||r(i)||/||b|| 8.917267867042e-03
> 9826 KSP Residual norm 1.080641662783e+00 % max 1.150251612560e+02 min 1.817295914017e-01 max/min 6.329467885162e+02
 > 9827 KSP preconditioned resid norm 1.080641662672e+00 true resid norm 1.594070669773e-01 ||r(i)||/||b|| 8.917292062876e-03
> 9827 KSP Residual norm 1.080641662672e+00 % max 1.153670515865e+02 min 1.757835701538e-01 max/min 6.563016753248e+02
 > 9828 KSP preconditioned resid norm 1.080641662655e+00 true resid norm 1.594072129068e-01 ||r(i)||/||b|| 8.917300226227e-03
> 9828 KSP Residual norm 1.080641662655e+00 % max 1.154419244262e+02 min 1.682009156098e-01 max/min 6.863335078032e+02
 > 9829 KSP preconditioned resid norm 1.080641662270e+00 true resid norm 1.594087524825e-01 ||r(i)||/||b|| 8.917386350680e-03
> 9829 KSP Residual norm 1.080641662270e+00 % max 1.154420683680e+02 min 1.254371322814e-01 max/min 9.203181407961e+02
 > 9830 KSP preconditioned resid norm 1.080641662088e+00 true resid norm 1.594088281904e-01 ||r(i)||/||b|| 8.917390585807e-03
> 9830 KSP Residual norm 1.080641662088e+00 % max 1.155791143272e+02 min 1.115275270000e-01 max/min 1.036328137421e+03
 > 9831 KSP preconditioned resid norm 1.080641662001e+00 true resid norm 1.594097559916e-01 ||r(i)||/||b|| 8.917442487360e-03
> 9831 KSP Residual norm 1.080641662001e+00 % max 1.156952534277e+02 min 9.753070058662e-02 max/min 1.186244461814e+03
 > 9832 KSP preconditioned resid norm 1.080641661905e+00 true resid norm 1.594102571355e-01 ||r(i)||/||b|| 8.917470521541e-03
> 9832 KSP Residual norm 1.080641661905e+00 % max 1.157175128244e+02 min 8.164806814555e-02 max/min 1.417271901866e+03
 > 9833 KSP preconditioned resid norm 1.080641661892e+00 true resid norm 1.594100484838e-01 ||r(i)||/||b|| 8.917458849484e-03
> 9833 KSP Residual norm 1.080641661892e+00 % max 1.157285121903e+02 min 8.043319039381e-02 max/min 1.438815389813e+03
 > 9834 KSP preconditioned resid norm 1.080641661854e+00 true resid norm 1.594101720988e-01 ||r(i)||/||b|| 8.917465764556e-03
> 9834 KSP Residual norm 1.080641661854e+00 % max 1.158251773437e+02 min 8.042916217223e-02 max/min 1.440089318544e+03
 > 9835 KSP preconditioned resid norm 1.080641661853e+00 true resid norm 1.594101806342e-01 ||r(i)||/||b|| 8.917466242026e-03
> 9835 KSP Residual norm 1.080641661853e+00 % max 1.158318842362e+02 min 7.912558026309e-02 max/min 1.463899333832e+03
 > 9836 KSP preconditioned resid norm 1.080641661674e+00 true resid norm 1.594101542582e-01 ||r(i)||/||b|| 8.917464766544e-03
> 9836 KSP Residual norm 1.080641661674e+00 % max 1.164750419425e+02 min 7.459519966941e-02 max/min 1.561428114124e+03
 > 9837 KSP preconditioned resid norm 1.080641661644e+00 true resid norm 1.594100247000e-01 ||r(i)||/||b|| 8.917457519010e-03
> 9837 KSP Residual norm 1.080641661644e+00 % max 1.166576751361e+02 min 7.458624135723e-02 max/min 1.564064269942e+03
 > 9838 KSP preconditioned resid norm 1.080641660043e+00 true resid norm 1.594090034525e-01 ||r(i)||/||b|| 8.917400390036e-03
> 9838 KSP Residual norm 1.080641660043e+00 % max 1.166901230302e+02 min 6.207904511461e-02 max/min 1.879702286251e+03
 > 9839 KSP preconditioned resid norm 1.080641654279e+00 true resid norm 1.594083845247e-01 ||r(i)||/||b|| 8.917365766976e-03
> 9839 KSP Residual norm 1.080641654279e+00 % max 1.166909329256e+02 min 4.511818825181e-02 max/min 2.586339067391e+03
 > 9840 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073617105e-01 ||r(i)||/||b|| 8.917308550363e-03
> 9840 KSP Residual norm 1.080641653856e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9841 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073617156e-01 ||r(i)||/||b|| 8.917308550646e-03
> 9841 KSP Residual norm 1.080641653856e+00 % max 3.063497434930e+01 min 3.063497434930e+01 max/min 1.000000000000e+00
 > 9842 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073617242e-01 ||r(i)||/||b|| 8.917308551127e-03
> 9842 KSP Residual norm 1.080641653856e+00 % max 3.066566511835e+01 min 3.845873341758e+00 max/min 7.973654458505e+00
 > 9843 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073618265e-01 ||r(i)||/||b|| 8.917308556853e-03
> 9843 KSP Residual norm 1.080641653856e+00 % max 3.713360973998e+01 min 1.336323585560e+00 max/min 2.778788771015e+01
 > 9844 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073618300e-01 ||r(i)||/||b|| 8.917308557050e-03
> 9844 KSP Residual norm 1.080641653856e+00 % max 4.496460969624e+01 min 1.226794432981e+00 max/min 3.665211423154e+01
 > 9845 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073618358e-01 ||r(i)||/||b|| 8.917308557372e-03
> 9845 KSP Residual norm 1.080641653856e+00 % max 8.684887047460e+01 min 1.183106552555e+00 max/min 7.340747989862e+01
 > 9846 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073621302e-01 ||r(i)||/||b|| 8.917308573843e-03
> 9846 KSP Residual norm 1.080641653856e+00 % max 9.802649587879e+01 min 1.168693234980e+00 max/min 8.387701147298e+01
 > 9847 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073622957e-01 ||r(i)||/||b|| 8.917308583099e-03
> 9847 KSP Residual norm 1.080641653856e+00 % max 1.123314913547e+02 min 1.141275669292e+00 max/min 9.842625614229e+01
 > 9848 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073623942e-01 ||r(i)||/||b|| 8.917308588608e-03
> 9848 KSP Residual norm 1.080641653856e+00 % max 1.134977479974e+02 min 1.090790466016e+00 max/min 1.040509167741e+02
 > 9849 KSP preconditioned resid norm 1.080641653855e+00 true resid norm 1.594074129801e-01 ||r(i)||/||b|| 8.917311418404e-03
> 9849 KSP Residual norm 1.080641653855e+00 % max 1.139911565327e+02 min 4.122354439173e-01 max/min 2.765195429329e+02
 > 9850 KSP preconditioned resid norm 1.080641653854e+00 true resid norm 1.594074720057e-01 ||r(i)||/||b|| 8.917314720319e-03
> 9850 KSP Residual norm 1.080641653854e+00 % max 1.140007137546e+02 min 2.895731636857e-01 max/min 3.936853550364e+02
 > 9851 KSP preconditioned resid norm 1.080641653854e+00 true resid norm 1.594074692144e-01 ||r(i)||/||b|| 8.917314564169e-03
> 9851 KSP Residual norm 1.080641653854e+00 % max 1.140387247200e+02 min 2.881916049088e-01 max/min 3.957045339889e+02
 > 9852 KSP preconditioned resid norm 1.080641653853e+00 true resid norm 1.594074456679e-01 ||r(i)||/||b|| 8.917313246972e-03
> 9852 KSP Residual norm 1.080641653853e+00 % max 1.140387740588e+02 min 2.501646808296e-01 max/min 4.558548140395e+02
 > 9853 KSP preconditioned resid norm 1.080641653851e+00 true resid norm 1.594074449772e-01 ||r(i)||/||b|| 8.917313208332e-03
> 9853 KSP Residual norm 1.080641653851e+00 % max 1.141359916013e+02 min 2.500654158720e-01 max/min 4.564245367688e+02
 > 9854 KSP preconditioned resid norm 1.080641653850e+00 true resid norm 1.594074383969e-01 ||r(i)||/||b|| 8.917312840228e-03
> 9854 KSP Residual norm 1.080641653850e+00 % max 1.141719416509e+02 min 2.470357905993e-01 max/min 4.621676129356e+02
 > 9855 KSP preconditioned resid norm 1.080641653826e+00 true resid norm 1.594073765323e-01 ||r(i)||/||b|| 8.917309379499e-03
> 9855 KSP Residual norm 1.080641653826e+00 % max 1.141769960009e+02 min 2.461587608334e-01 max/min 4.638347853812e+02
 > 9856 KSP preconditioned resid norm 1.080641653822e+00 true resid norm 1.594072524403e-01 ||r(i)||/||b|| 8.917302437746e-03
> 9856 KSP Residual norm 1.080641653822e+00 % max 1.150247983913e+02 min 1.817426977612e-01 max/min 6.328991470261e+02
 > 9857 KSP preconditioned resid norm 1.080641653714e+00 true resid norm 1.594068250847e-01 ||r(i)||/||b|| 8.917278531310e-03
> 9857 KSP Residual norm 1.080641653714e+00 % max 1.153659149296e+02 min 1.758216030104e-01 max/min 6.561532425728e+02
 > 9858 KSP preconditioned resid norm 1.080641653697e+00 true resid norm 1.594066805198e-01 ||r(i)||/||b|| 8.917270444298e-03
> 9858 KSP Residual norm 1.080641653697e+00 % max 1.154409610504e+02 min 1.682252327368e-01 max/min 6.862285709010e+02
 > 9859 KSP preconditioned resid norm 1.080641653319e+00 true resid norm 1.594051557657e-01 ||r(i)||/||b|| 8.917185148971e-03
> 9859 KSP Residual norm 1.080641653319e+00 % max 1.154410966341e+02 min 1.254606780252e-01 max/min 9.201376754146e+02
 > 9860 KSP preconditioned resid norm 1.080641653140e+00 true resid norm 1.594050799233e-01 ||r(i)||/||b|| 8.917180906316e-03
> 9860 KSP Residual norm 1.080641653140e+00 % max 1.155780628675e+02 min 1.115225287992e-01 max/min 1.036365155202e+03
 > 9861 KSP preconditioned resid norm 1.080641653054e+00 true resid norm 1.594041550812e-01 ||r(i)||/||b|| 8.917129170295e-03
> 9861 KSP Residual norm 1.080641653054e+00 % max 1.156949369211e+02 min 9.748220965886e-02 max/min 1.186831292869e+03
 > 9862 KSP preconditioned resid norm 1.080641652960e+00 true resid norm 1.594036620365e-01 ||r(i)||/||b|| 8.917101589189e-03
> 9862 KSP Residual norm 1.080641652960e+00 % max 1.157177832797e+02 min 8.161751000999e-02 max/min 1.417805851533e+03
 > 9863 KSP preconditioned resid norm 1.080641652947e+00 true resid norm 1.594038718371e-01 ||r(i)||/||b|| 8.917113325517e-03
> 9863 KSP Residual norm 1.080641652947e+00 % max 1.157297723960e+02 min 8.041700428565e-02 max/min 1.439120661408e+03
 > 9864 KSP preconditioned resid norm 1.080641652912e+00 true resid norm 1.594037544972e-01 ||r(i)||/||b|| 8.917106761475e-03
> 9864 KSP Residual norm 1.080641652912e+00 % max 1.158244802295e+02 min 8.041252146115e-02 max/min 1.440378663980e+03
 > 9865 KSP preconditioned resid norm 1.080641652910e+00 true resid norm 1.594037467642e-01 ||r(i)||/||b|| 8.917106328887e-03
> 9865 KSP Residual norm 1.080641652910e+00 % max 1.158301923080e+02 min 7.912032794006e-02 max/min 1.463975129069e+03
 > 9866 KSP preconditioned resid norm 1.080641652734e+00 true resid norm 1.594037735388e-01 ||r(i)||/||b|| 8.917107826673e-03
> 9866 KSP Residual norm 1.080641652734e+00 % max 1.164681289889e+02 min 7.460712971447e-02 max/min 1.561085776047e+03
 > 9867 KSP preconditioned resid norm 1.080641652705e+00 true resid norm 1.594039028009e-01 ||r(i)||/||b|| 8.917115057644e-03
> 9867 KSP Residual norm 1.080641652705e+00 % max 1.166491106270e+02 min 7.459753335320e-02 max/min 1.563712704477e+03
 > 9868 KSP preconditioned resid norm 1.080641651132e+00 true resid norm 1.594049112430e-01 ||r(i)||/||b|| 8.917171470279e-03
> 9868 KSP Residual norm 1.080641651132e+00 % max 1.166811058685e+02 min 6.210409714784e-02 max/min 1.878798843026e+03
 > 9869 KSP preconditioned resid norm 1.080641645474e+00 true resid norm 1.594055279416e-01 ||r(i)||/||b|| 8.917205968634e-03
> 9869 KSP Residual norm 1.080641645474e+00 % max 1.166818375393e+02 min 4.513482662958e-02 max/min 2.585184130582e+03
 > 9870 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065322524e-01 ||r(i)||/||b|| 8.917262150160e-03
> 9870 KSP Residual norm 1.080641645065e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9871 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065322474e-01 ||r(i)||/||b|| 8.917262149880e-03
> 9871 KSP Residual norm 1.080641645065e+00 % max 3.063464541814e+01 min 3.063464541814e+01 max/min 1.000000000000e+00
 > 9872 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065322389e-01 ||r(i)||/||b|| 8.917262149406e-03
> 9872 KSP Residual norm 1.080641645065e+00 % max 3.066529346532e+01 min 3.844443657370e+00 max/min 7.976523054651e+00
 > 9873 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065321376e-01 ||r(i)||/||b|| 8.917262143737e-03
> 9873 KSP Residual norm 1.080641645065e+00 % max 3.714534104643e+01 min 1.336555480314e+00 max/min 2.779184373079e+01
 > 9874 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065321340e-01 ||r(i)||/||b|| 8.917262143537e-03
> 9874 KSP Residual norm 1.080641645065e+00 % max 4.500878758461e+01 min 1.226798739269e+00 max/min 3.668799628162e+01
 > 9875 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065321283e-01 ||r(i)||/||b|| 8.917262143216e-03
> 9875 KSP Residual norm 1.080641645065e+00 % max 8.688179296761e+01 min 1.183120879361e+00 max/min 7.343441780400e+01
 > 9876 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065318413e-01 ||r(i)||/||b|| 8.917262127165e-03
> 9876 KSP Residual norm 1.080641645065e+00 % max 9.802498627683e+01 min 1.168935165788e+00 max/min 8.385836028017e+01
 > 9877 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065316788e-01 ||r(i)||/||b|| 8.917262118072e-03
> 9877 KSP Residual norm 1.080641645065e+00 % max 1.122437663284e+02 min 1.141666474192e+00 max/min 9.831572430803e+01
 > 9878 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065315811e-01 ||r(i)||/||b|| 8.917262112605e-03
> 9878 KSP Residual norm 1.080641645065e+00 % max 1.134942465219e+02 min 1.090790184702e+00 max/min 1.040477335730e+02
 > 9879 KSP preconditioned resid norm 1.080641645064e+00 true resid norm 1.594064814200e-01 ||r(i)||/||b|| 8.917259306578e-03
> 9879 KSP Residual norm 1.080641645064e+00 % max 1.139914544856e+02 min 4.119772603942e-01 max/min 2.766935591945e+02
 > 9880 KSP preconditioned resid norm 1.080641645063e+00 true resid norm 1.594064229585e-01 ||r(i)||/||b|| 8.917256036220e-03
> 9880 KSP Residual norm 1.080641645063e+00 % max 1.140011250742e+02 min 2.894539413393e-01 max/min 3.938489299774e+02
 > 9881 KSP preconditioned resid norm 1.080641645063e+00 true resid norm 1.594064257287e-01 ||r(i)||/||b|| 8.917256191184e-03
> 9881 KSP Residual norm 1.080641645063e+00 % max 1.140392103921e+02 min 2.880591764056e-01 max/min 3.958881359556e+02
 > 9882 KSP preconditioned resid norm 1.080641645063e+00 true resid norm 1.594064490294e-01 ||r(i)||/||b|| 8.917257494633e-03
> 9882 KSP Residual norm 1.080641645063e+00 % max 1.140392535477e+02 min 2.501714617108e-01 max/min 4.558443747654e+02
 > 9883 KSP preconditioned resid norm 1.080641645061e+00 true resid norm 1.594064497349e-01 ||r(i)||/||b|| 8.917257534101e-03
> 9883 KSP Residual norm 1.080641645061e+00 % max 1.141360416004e+02 min 2.500712361002e-01 max/min 4.564141137554e+02
 > 9884 KSP preconditioned resid norm 1.080641645059e+00 true resid norm 1.594064561966e-01 ||r(i)||/||b|| 8.917257895569e-03
> 9884 KSP Residual norm 1.080641645059e+00 % max 1.141719177119e+02 min 2.470520232306e-01 max/min 4.621371491678e+02
 > 9885 KSP preconditioned resid norm 1.080641645035e+00 true resid norm 1.594065174658e-01 ||r(i)||/||b|| 8.917261322993e-03
> 9885 KSP Residual norm 1.080641645035e+00 % max 1.141770016402e+02 min 2.461723435101e-01 max/min 4.638092159834e+02
 > 9886 KSP preconditioned resid norm 1.080641645032e+00 true resid norm 1.594066402497e-01 ||r(i)||/||b|| 8.917268191569e-03
> 9886 KSP Residual norm 1.080641645032e+00 % max 1.150251585488e+02 min 1.817296775460e-01 max/min 6.329464735865e+02
 > 9887 KSP preconditioned resid norm 1.080641644925e+00 true resid norm 1.594070641129e-01 ||r(i)||/||b|| 8.917291902641e-03
> 9887 KSP Residual norm 1.080641644925e+00 % max 1.153670431587e+02 min 1.757838889123e-01 max/min 6.563004372733e+02
 > 9888 KSP preconditioned resid norm 1.080641644909e+00 true resid norm 1.594072071224e-01 ||r(i)||/||b|| 8.917299902647e-03
> 9888 KSP Residual norm 1.080641644909e+00 % max 1.154419177071e+02 min 1.682011082589e-01 max/min 6.863326817642e+02
 > 9889 KSP preconditioned resid norm 1.080641644540e+00 true resid norm 1.594087159021e-01 ||r(i)||/||b|| 8.917384304358e-03
> 9889 KSP Residual norm 1.080641644540e+00 % max 1.154420615965e+02 min 1.254373423966e-01 max/min 9.203165452239e+02
 > 9890 KSP preconditioned resid norm 1.080641644365e+00 true resid norm 1.594087901062e-01 ||r(i)||/||b|| 8.917388455364e-03
> 9890 KSP Residual norm 1.080641644365e+00 % max 1.155791063432e+02 min 1.115273566807e-01 max/min 1.036329648465e+03
 > 9891 KSP preconditioned resid norm 1.080641644282e+00 true resid norm 1.594096994140e-01 ||r(i)||/||b|| 8.917439322388e-03
> 9891 KSP Residual norm 1.080641644282e+00 % max 1.156952495514e+02 min 9.753038620512e-02 max/min 1.186248245835e+03
 > 9892 KSP preconditioned resid norm 1.080641644189e+00 true resid norm 1.594101905102e-01 ||r(i)||/||b|| 8.917466794493e-03
> 9892 KSP Residual norm 1.080641644189e+00 % max 1.157175115527e+02 min 8.164774923625e-02 max/min 1.417277422037e+03
 > 9893 KSP preconditioned resid norm 1.080641644177e+00 true resid norm 1.594099860409e-01 ||r(i)||/||b|| 8.917455356405e-03
> 9893 KSP Residual norm 1.080641644177e+00 % max 1.157285171248e+02 min 8.043299897298e-02 max/min 1.438818875368e+03
 > 9894 KSP preconditioned resid norm 1.080641644141e+00 true resid norm 1.594101071411e-01 ||r(i)||/||b|| 8.917462130798e-03
> 9894 KSP Residual norm 1.080641644141e+00 % max 1.158251669093e+02 min 8.042896682578e-02 max/min 1.440092686509e+03
 > 9895 KSP preconditioned resid norm 1.080641644139e+00 true resid norm 1.594101154949e-01 ||r(i)||/||b|| 8.917462598110e-03
> 9895 KSP Residual norm 1.080641644139e+00 % max 1.158318659802e+02 min 7.912549560750e-02 max/min 1.463900669321e+03
 > 9896 KSP preconditioned resid norm 1.080641643967e+00 true resid norm 1.594100896394e-01 ||r(i)||/||b|| 8.917461151744e-03
> 9896 KSP Residual norm 1.080641643967e+00 % max 1.164749819823e+02 min 7.459530237415e-02 max/min 1.561425160502e+03
 > 9897 KSP preconditioned resid norm 1.080641643939e+00 true resid norm 1.594099626317e-01 ||r(i)||/||b|| 8.917454046886e-03
> 9897 KSP Residual norm 1.080641643939e+00 % max 1.166576013049e+02 min 7.458633610448e-02 max/min 1.564061293230e+03
 > 9898 KSP preconditioned resid norm 1.080641642401e+00 true resid norm 1.594089618420e-01 ||r(i)||/||b|| 8.917398062328e-03
> 9898 KSP Residual norm 1.080641642401e+00 % max 1.166900450421e+02 min 6.207924609942e-02 max/min 1.879694944349e+03
 > 9899 KSP preconditioned resid norm 1.080641636866e+00 true resid norm 1.594083552587e-01 ||r(i)||/||b|| 8.917364129827e-03
> 9899 KSP Residual norm 1.080641636866e+00 % max 1.166908543099e+02 min 4.511837692126e-02 max/min 2.586326509785e+03
 > 9900 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073529026e-01 ||r(i)||/||b|| 8.917308057647e-03
> 9900 KSP Residual norm 1.080641636459e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9901 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073529076e-01 ||r(i)||/||b|| 8.917308057926e-03
> 9901 KSP Residual norm 1.080641636459e+00 % max 3.063497290246e+01 min 3.063497290246e+01 max/min 1.000000000000e+00
 > 9902 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073529160e-01 ||r(i)||/||b|| 8.917308058394e-03
> 9902 KSP Residual norm 1.080641636459e+00 % max 3.066566310477e+01 min 3.845858371013e+00 max/min 7.973684973919e+00
 > 9903 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073530163e-01 ||r(i)||/||b|| 8.917308064007e-03
> 9903 KSP Residual norm 1.080641636459e+00 % max 3.713375877488e+01 min 1.336326817614e+00 max/min 2.778793202787e+01
 > 9904 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073530198e-01 ||r(i)||/||b|| 8.917308064200e-03
> 9904 KSP Residual norm 1.080641636459e+00 % max 4.496516516046e+01 min 1.226794642680e+00 max/min 3.665256074336e+01
 > 9905 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073530254e-01 ||r(i)||/||b|| 8.917308064515e-03
> 9905 KSP Residual norm 1.080641636459e+00 % max 8.684929340512e+01 min 1.183106694605e+00 max/min 7.340782855945e+01
 > 9906 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073533139e-01 ||r(i)||/||b|| 8.917308080655e-03
> 9906 KSP Residual norm 1.080641636459e+00 % max 9.802647163348e+01 min 1.168695697992e+00 max/min 8.387681395754e+01
 > 9907 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073534761e-01 ||r(i)||/||b|| 8.917308089727e-03
> 9907 KSP Residual norm 1.080641636459e+00 % max 1.123306036185e+02 min 1.141279831413e+00 max/min 9.842511934993e+01
 > 9908 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073535726e-01 ||r(i)||/||b|| 8.917308095124e-03
> 9908 KSP Residual norm 1.080641636459e+00 % max 1.134977112090e+02 min 1.090790470231e+00 max/min 1.040508826457e+02
 > 9909 KSP preconditioned resid norm 1.080641636458e+00 true resid norm 1.594074031465e-01 ||r(i)||/||b|| 8.917310868307e-03
> 9909 KSP Residual norm 1.080641636458e+00 % max 1.139911596762e+02 min 4.122331938771e-01 max/min 2.765210598500e+02
 > 9910 KSP preconditioned resid norm 1.080641636457e+00 true resid norm 1.594074609911e-01 ||r(i)||/||b|| 8.917314104156e-03
> 9910 KSP Residual norm 1.080641636457e+00 % max 1.140007179199e+02 min 2.895720290537e-01 max/min 3.936869120007e+02
 > 9911 KSP preconditioned resid norm 1.080641636457e+00 true resid norm 1.594074582552e-01 ||r(i)||/||b|| 8.917313951111e-03
> 9911 KSP Residual norm 1.080641636457e+00 % max 1.140387297689e+02 min 2.881903470643e-01 max/min 3.957062786128e+02
 > 9912 KSP preconditioned resid norm 1.080641636457e+00 true resid norm 1.594074351775e-01 ||r(i)||/||b|| 8.917312660133e-03
> 9912 KSP Residual norm 1.080641636457e+00 % max 1.140387790534e+02 min 2.501647526543e-01 max/min 4.558547031242e+02
 > 9913 KSP preconditioned resid norm 1.080641636455e+00 true resid norm 1.594074345003e-01 ||r(i)||/||b|| 8.917312622252e-03
> 9913 KSP Residual norm 1.080641636455e+00 % max 1.141359922733e+02 min 2.500654781355e-01 max/min 4.564244258117e+02
 > 9914 KSP preconditioned resid norm 1.080641636454e+00 true resid norm 1.594074280517e-01 ||r(i)||/||b|| 8.917312261516e-03
> 9914 KSP Residual norm 1.080641636454e+00 % max 1.141719413857e+02 min 2.470359663864e-01 max/min 4.621672829905e+02
 > 9915 KSP preconditioned resid norm 1.080641636430e+00 true resid norm 1.594073674253e-01 ||r(i)||/||b|| 8.917308870053e-03
> 9915 KSP Residual norm 1.080641636430e+00 % max 1.141769960812e+02 min 2.461588977988e-01 max/min 4.638345276249e+02
 > 9916 KSP preconditioned resid norm 1.080641636427e+00 true resid norm 1.594072457998e-01 ||r(i)||/||b|| 8.917302066275e-03
> 9916 KSP Residual norm 1.080641636427e+00 % max 1.150248029458e+02 min 1.817425233097e-01 max/min 6.328997795954e+02
 > 9917 KSP preconditioned resid norm 1.080641636323e+00 true resid norm 1.594068269925e-01 ||r(i)||/||b|| 8.917278638033e-03
> 9917 KSP Residual norm 1.080641636323e+00 % max 1.153659292411e+02 min 1.758211627252e-01 max/min 6.561549670868e+02
 > 9918 KSP preconditioned resid norm 1.080641636306e+00 true resid norm 1.594066853231e-01 ||r(i)||/||b|| 8.917270712996e-03
> 9918 KSP Residual norm 1.080641636306e+00 % max 1.154409736018e+02 min 1.682249410195e-01 max/min 6.862298354942e+02
 > 9919 KSP preconditioned resid norm 1.080641635944e+00 true resid norm 1.594051910900e-01 ||r(i)||/||b|| 8.917187125026e-03
> 9919 KSP Residual norm 1.080641635944e+00 % max 1.154411092996e+02 min 1.254604202789e-01 max/min 9.201396667011e+02
 > 9920 KSP preconditioned resid norm 1.080641635771e+00 true resid norm 1.594051167722e-01 ||r(i)||/||b|| 8.917182967656e-03
> 9920 KSP Residual norm 1.080641635771e+00 % max 1.155780759198e+02 min 1.115224613869e-01 max/min 1.036365898694e+03
 > 9921 KSP preconditioned resid norm 1.080641635689e+00 true resid norm 1.594042104954e-01 ||r(i)||/||b|| 8.917132270191e-03
> 9921 KSP Residual norm 1.080641635689e+00 % max 1.156949393598e+02 min 9.748286841768e-02 max/min 1.186823297649e+03
 > 9922 KSP preconditioned resid norm 1.080641635599e+00 true resid norm 1.594037272785e-01 ||r(i)||/||b|| 8.917105238852e-03
> 9922 KSP Residual norm 1.080641635599e+00 % max 1.157177765183e+02 min 8.161780203814e-02 max/min 1.417800695787e+03
 > 9923 KSP preconditioned resid norm 1.080641635586e+00 true resid norm 1.594039328090e-01 ||r(i)||/||b|| 8.917116736308e-03
> 9923 KSP Residual norm 1.080641635586e+00 % max 1.157297518468e+02 min 8.041713659406e-02 max/min 1.439118038125e+03
 > 9924 KSP preconditioned resid norm 1.080641635552e+00 true resid norm 1.594038177599e-01 ||r(i)||/||b|| 8.917110300416e-03
> 9924 KSP Residual norm 1.080641635552e+00 % max 1.158244835100e+02 min 8.041265899129e-02 max/min 1.440376241290e+03
 > 9925 KSP preconditioned resid norm 1.080641635551e+00 true resid norm 1.594038101782e-01 ||r(i)||/||b|| 8.917109876291e-03
> 9925 KSP Residual norm 1.080641635551e+00 % max 1.158302075022e+02 min 7.912034826741e-02 max/min 1.463974944988e+03
 > 9926 KSP preconditioned resid norm 1.080641635382e+00 true resid norm 1.594038364112e-01 ||r(i)||/||b|| 8.917111343775e-03
> 9926 KSP Residual norm 1.080641635382e+00 % max 1.164682071358e+02 min 7.460699390243e-02 max/min 1.561089665242e+03
 > 9927 KSP preconditioned resid norm 1.080641635354e+00 true resid norm 1.594039631076e-01 ||r(i)||/||b|| 8.917118431221e-03
> 9927 KSP Residual norm 1.080641635354e+00 % max 1.166492079885e+02 min 7.459740228247e-02 max/min 1.563716757144e+03
 > 9928 KSP preconditioned resid norm 1.080641633843e+00 true resid norm 1.594049513925e-01 ||r(i)||/||b|| 8.917173716256e-03
> 9928 KSP Residual norm 1.080641633843e+00 % max 1.166812081048e+02 min 6.210379986959e-02 max/min 1.878809482669e+03
 > 9929 KSP preconditioned resid norm 1.080641628410e+00 true resid norm 1.594055557080e-01 ||r(i)||/||b|| 8.917207521894e-03
> 9929 KSP Residual norm 1.080641628410e+00 % max 1.166819406955e+02 min 4.513468212670e-02 max/min 2.585194692807e+03
 > 9930 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065400862e-01 ||r(i)||/||b|| 8.917262588389e-03
> 9930 KSP Residual norm 1.080641628017e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9931 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065400814e-01 ||r(i)||/||b|| 8.917262588116e-03
> 9931 KSP Residual norm 1.080641628017e+00 % max 3.063465052437e+01 min 3.063465052437e+01 max/min 1.000000000000e+00
 > 9932 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065400730e-01 ||r(i)||/||b|| 8.917262587648e-03
> 9932 KSP Residual norm 1.080641628017e+00 % max 3.066529886382e+01 min 3.844457299464e+00 max/min 7.976496154112e+00
 > 9933 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065399737e-01 ||r(i)||/||b|| 8.917262582094e-03
> 9933 KSP Residual norm 1.080641628017e+00 % max 3.714525447417e+01 min 1.336554051053e+00 max/min 2.779180867762e+01
 > 9934 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065399702e-01 ||r(i)||/||b|| 8.917262581897e-03
> 9934 KSP Residual norm 1.080641628017e+00 % max 4.500845605790e+01 min 1.226798858744e+00 max/min 3.668772247146e+01
 > 9935 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065399646e-01 ||r(i)||/||b|| 8.917262581583e-03
> 9935 KSP Residual norm 1.080641628017e+00 % max 8.688155371236e+01 min 1.183120734870e+00 max/min 7.343422454843e+01
 > 9936 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065396833e-01 ||r(i)||/||b|| 8.917262565850e-03
> 9936 KSP Residual norm 1.080641628017e+00 % max 9.802499250688e+01 min 1.168932790974e+00 max/min 8.385853597724e+01
 > 9937 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065395240e-01 ||r(i)||/||b|| 8.917262556936e-03
> 9937 KSP Residual norm 1.080641628017e+00 % max 1.122446326752e+02 min 1.141662807959e+00 max/min 9.831679887675e+01
 > 9938 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065394282e-01 ||r(i)||/||b|| 8.917262551579e-03
> 9938 KSP Residual norm 1.080641628017e+00 % max 1.134942798726e+02 min 1.090790194356e+00 max/min 1.040477632269e+02
 > 9939 KSP preconditioned resid norm 1.080641628016e+00 true resid norm 1.594064902727e-01 ||r(i)||/||b|| 8.917259801801e-03
> 9939 KSP Residual norm 1.080641628016e+00 % max 1.139914516679e+02 min 4.119801790176e-01 max/min 2.766915921531e+02
 > 9940 KSP preconditioned resid norm 1.080641628015e+00 true resid norm 1.594064329818e-01 ||r(i)||/||b|| 8.917256596927e-03
> 9940 KSP Residual norm 1.080641628015e+00 % max 1.140011210085e+02 min 2.894551947128e-01 max/min 3.938472105212e+02
 > 9941 KSP preconditioned resid norm 1.080641628015e+00 true resid norm 1.594064356968e-01 ||r(i)||/||b|| 8.917256748803e-03
> 9941 KSP Residual norm 1.080641628015e+00 % max 1.140392057187e+02 min 2.880605712140e-01 max/min 3.958862028153e+02
 > 9942 KSP preconditioned resid norm 1.080641628014e+00 true resid norm 1.594064585337e-01 ||r(i)||/||b|| 8.917258026309e-03
> 9942 KSP Residual norm 1.080641628014e+00 % max 1.140392489431e+02 min 2.501713977769e-01 max/min 4.558444728556e+02
 > 9943 KSP preconditioned resid norm 1.080641628013e+00 true resid norm 1.594064592249e-01 ||r(i)||/||b|| 8.917258064976e-03
> 9943 KSP Residual norm 1.080641628013e+00 % max 1.141360412719e+02 min 2.500711817244e-01 max/min 4.564142116850e+02
 > 9944 KSP preconditioned resid norm 1.080641628011e+00 true resid norm 1.594064655583e-01 ||r(i)||/||b|| 8.917258419265e-03
> 9944 KSP Residual norm 1.080641628011e+00 % max 1.141719179255e+02 min 2.470518740808e-01 max/min 4.621374290332e+02
 > 9945 KSP preconditioned resid norm 1.080641627988e+00 true resid norm 1.594065256003e-01 ||r(i)||/||b|| 8.917261778039e-03
> 9945 KSP Residual norm 1.080641627988e+00 % max 1.141770016071e+02 min 2.461722087102e-01 max/min 4.638094698230e+02
 > 9946 KSP preconditioned resid norm 1.080641627985e+00 true resid norm 1.594066459440e-01 ||r(i)||/||b|| 8.917268510113e-03
> 9946 KSP Residual norm 1.080641627985e+00 % max 1.150251558754e+02 min 1.817297629761e-01 max/min 6.329461613313e+02
 > 9947 KSP preconditioned resid norm 1.080641627883e+00 true resid norm 1.594070613108e-01 ||r(i)||/||b|| 8.917291745887e-03
> 9947 KSP Residual norm 1.080641627883e+00 % max 1.153670348347e+02 min 1.757842027946e-01 max/min 6.562992180216e+02
 > 9948 KSP preconditioned resid norm 1.080641627867e+00 true resid norm 1.594072014571e-01 ||r(i)||/||b|| 8.917299585729e-03
> 9948 KSP Residual norm 1.080641627867e+00 % max 1.154419110590e+02 min 1.682012982555e-01 max/min 6.863318669729e+02
 > 9949 KSP preconditioned resid norm 1.080641627512e+00 true resid norm 1.594086800399e-01 ||r(i)||/||b|| 8.917382298211e-03
> 9949 KSP Residual norm 1.080641627512e+00 % max 1.154420548965e+02 min 1.254375490145e-01 max/min 9.203149758861e+02
 > 9950 KSP preconditioned resid norm 1.080641627344e+00 true resid norm 1.594087527690e-01 ||r(i)||/||b|| 8.917386366706e-03
> 9950 KSP Residual norm 1.080641627344e+00 % max 1.155790984624e+02 min 1.115271921586e-01 max/min 1.036331106570e+03
 > 9951 KSP preconditioned resid norm 1.080641627264e+00 true resid norm 1.594096439404e-01 ||r(i)||/||b|| 8.917436219173e-03
> 9951 KSP Residual norm 1.080641627264e+00 % max 1.156952457641e+02 min 9.753007450777e-02 max/min 1.186251998145e+03
 > 9952 KSP preconditioned resid norm 1.080641627176e+00 true resid norm 1.594101251850e-01 ||r(i)||/||b|| 8.917463140178e-03
> 9952 KSP Residual norm 1.080641627176e+00 % max 1.157175103847e+02 min 8.164743677427e-02 max/min 1.417282831604e+03
 > 9953 KSP preconditioned resid norm 1.080641627164e+00 true resid norm 1.594099248157e-01 ||r(i)||/||b|| 8.917451931444e-03
> 9953 KSP Residual norm 1.080641627164e+00 % max 1.157285221143e+02 min 8.043281187160e-02 max/min 1.438822284357e+03
 > 9954 KSP preconditioned resid norm 1.080641627129e+00 true resid norm 1.594100434515e-01 ||r(i)||/||b|| 8.917458567979e-03
> 9954 KSP Residual norm 1.080641627129e+00 % max 1.158251567433e+02 min 8.042877586324e-02 max/min 1.440095979333e+03
 > 9955 KSP preconditioned resid norm 1.080641627127e+00 true resid norm 1.594100516277e-01 ||r(i)||/||b|| 8.917459025356e-03
> 9955 KSP Residual norm 1.080641627127e+00 % max 1.158318480981e+02 min 7.912541326160e-02 max/min 1.463901966807e+03
 > 9956 KSP preconditioned resid norm 1.080641626963e+00 true resid norm 1.594100262829e-01 ||r(i)||/||b|| 8.917457607557e-03
> 9956 KSP Residual norm 1.080641626963e+00 % max 1.164749229958e+02 min 7.459540346436e-02 max/min 1.561422253738e+03
 > 9957 KSP preconditioned resid norm 1.080641626935e+00 true resid norm 1.594099017783e-01 ||r(i)||/||b|| 8.917450642725e-03
> 9957 KSP Residual norm 1.080641626935e+00 % max 1.166575286636e+02 min 7.458642942097e-02 max/min 1.564058362483e+03
 > 9958 KSP preconditioned resid norm 1.080641625459e+00 true resid norm 1.594089210473e-01 ||r(i)||/||b|| 8.917395780257e-03
> 9958 KSP Residual norm 1.080641625459e+00 % max 1.166899683166e+02 min 6.207944430169e-02 max/min 1.879687707085e+03
 > 9959 KSP preconditioned resid norm 1.080641620143e+00 true resid norm 1.594083265698e-01 ||r(i)||/||b|| 8.917362524958e-03
> 9959 KSP Residual norm 1.080641620143e+00 % max 1.166907769657e+02 min 4.511856151865e-02 max/min 2.586314213883e+03
 > 9960 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073442756e-01 ||r(i)||/||b|| 8.917307575050e-03
> 9960 KSP Residual norm 1.080641619752e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9961 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073442805e-01 ||r(i)||/||b|| 8.917307575322e-03
> 9961 KSP Residual norm 1.080641619752e+00 % max 3.063497144523e+01 min 3.063497144523e+01 max/min 1.000000000000e+00
 > 9962 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073442888e-01 ||r(i)||/||b|| 8.917307575783e-03
> 9962 KSP Residual norm 1.080641619752e+00 % max 3.066566109468e+01 min 3.845843703829e+00 max/min 7.973714861098e+00
 > 9963 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073443871e-01 ||r(i)||/||b|| 8.917307581283e-03
> 9963 KSP Residual norm 1.080641619752e+00 % max 3.713390425813e+01 min 1.336329967989e+00 max/min 2.778797538606e+01
 > 9964 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073443904e-01 ||r(i)||/||b|| 8.917307581472e-03
> 9964 KSP Residual norm 1.080641619752e+00 % max 4.496570748601e+01 min 1.226794844829e+00 max/min 3.665299677086e+01
 > 9965 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073443960e-01 ||r(i)||/||b|| 8.917307581781e-03
> 9965 KSP Residual norm 1.080641619752e+00 % max 8.684970616180e+01 min 1.183106833938e+00 max/min 7.340816878957e+01
 > 9966 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073446787e-01 ||r(i)||/||b|| 8.917307597597e-03
> 9966 KSP Residual norm 1.080641619752e+00 % max 9.802644805035e+01 min 1.168698112506e+00 max/min 8.387662049028e+01
 > 9967 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073448376e-01 ||r(i)||/||b|| 8.917307606488e-03
> 9967 KSP Residual norm 1.080641619752e+00 % max 1.123297332549e+02 min 1.141283907756e+00 max/min 9.842400518531e+01
 > 9968 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073449323e-01 ||r(i)||/||b|| 8.917307611782e-03
> 9968 KSP Residual norm 1.080641619752e+00 % max 1.134976751689e+02 min 1.090790474217e+00 max/min 1.040508492250e+02
 > 9969 KSP preconditioned resid norm 1.080641619751e+00 true resid norm 1.594073935137e-01 ||r(i)||/||b|| 8.917310329444e-03
> 9969 KSP Residual norm 1.080641619751e+00 % max 1.139911627557e+02 min 4.122309806702e-01 max/min 2.765225519207e+02
 > 9970 KSP preconditioned resid norm 1.080641619750e+00 true resid norm 1.594074502003e-01 ||r(i)||/||b|| 8.917313500516e-03
> 9970 KSP Residual norm 1.080641619750e+00 % max 1.140007220037e+02 min 2.895709152543e-01 max/min 3.936884403725e+02
 > 9971 KSP preconditioned resid norm 1.080641619750e+00 true resid norm 1.594074475189e-01 ||r(i)||/||b|| 8.917313350515e-03
> 9971 KSP Residual norm 1.080641619750e+00 % max 1.140387347164e+02 min 2.881891122657e-01 max/min 3.957079912555e+02
 > 9972 KSP preconditioned resid norm 1.080641619750e+00 true resid norm 1.594074249007e-01 ||r(i)||/||b|| 8.917312085247e-03
> 9972 KSP Residual norm 1.080641619750e+00 % max 1.140387839472e+02 min 2.501648230072e-01 max/min 4.558545944886e+02
 > 9973 KSP preconditioned resid norm 1.080641619748e+00 true resid norm 1.594074242369e-01 ||r(i)||/||b|| 8.917312048114e-03
> 9973 KSP Residual norm 1.080641619748e+00 % max 1.141359929290e+02 min 2.500655391090e-01 max/min 4.564243171438e+02
 > 9974 KSP preconditioned resid norm 1.080641619747e+00 true resid norm 1.594074179174e-01 ||r(i)||/||b|| 8.917311694599e-03
> 9974 KSP Residual norm 1.080641619747e+00 % max 1.141719411262e+02 min 2.470361384981e-01 max/min 4.621669599450e+02
 > 9975 KSP preconditioned resid norm 1.080641619724e+00 true resid norm 1.594073585052e-01 ||r(i)||/||b|| 8.917308371056e-03
> 9975 KSP Residual norm 1.080641619724e+00 % max 1.141769961595e+02 min 2.461590320913e-01 max/min 4.638342748974e+02
 > 9976 KSP preconditioned resid norm 1.080641619721e+00 true resid norm 1.594072392992e-01 ||r(i)||/||b|| 8.917301702630e-03
> 9976 KSP Residual norm 1.080641619721e+00 % max 1.150248073926e+02 min 1.817423531140e-01 max/min 6.329003967526e+02
 > 9977 KSP preconditioned resid norm 1.080641619621e+00 true resid norm 1.594068288737e-01 ||r(i)||/||b|| 8.917278743269e-03
> 9977 KSP Residual norm 1.080641619621e+00 % max 1.153659432133e+02 min 1.758207322277e-01 max/min 6.561566531518e+02
 > 9978 KSP preconditioned resid norm 1.080641619605e+00 true resid norm 1.594066900433e-01 ||r(i)||/||b|| 8.917270977044e-03
> 9978 KSP Residual norm 1.080641619605e+00 % max 1.154409858489e+02 min 1.682246559484e-01 max/min 6.862310711714e+02
 > 9979 KSP preconditioned resid norm 1.080641619257e+00 true resid norm 1.594052257365e-01 ||r(i)||/||b|| 8.917189063164e-03
> 9979 KSP Residual norm 1.080641619257e+00 % max 1.154411216580e+02 min 1.254601679658e-01 max/min 9.201416157000e+02
 > 9980 KSP preconditioned resid norm 1.080641619092e+00 true resid norm 1.594051529133e-01 ||r(i)||/||b|| 8.917184989407e-03
> 9980 KSP Residual norm 1.080641619092e+00 % max 1.155780886655e+02 min 1.115223976110e-01 max/min 1.036366605645e+03
 > 9981 KSP preconditioned resid norm 1.080641619012e+00 true resid norm 1.594042648383e-01 ||r(i)||/||b|| 8.917135310152e-03
> 9981 KSP Residual norm 1.080641619012e+00 % max 1.156949417657e+02 min 9.748351070064e-02 max/min 1.186815502788e+03
 > 9982 KSP preconditioned resid norm 1.080641618926e+00 true resid norm 1.594037912594e-01 ||r(i)||/||b|| 8.917108817969e-03
> 9982 KSP Residual norm 1.080641618926e+00 % max 1.157177699729e+02 min 8.161808862755e-02 max/min 1.417795637202e+03
 > 9983 KSP preconditioned resid norm 1.080641618914e+00 true resid norm 1.594039926066e-01 ||r(i)||/||b|| 8.917120081407e-03
> 9983 KSP Residual norm 1.080641618914e+00 % max 1.157297318664e+02 min 8.041726690542e-02 max/min 1.439115457660e+03
 > 9984 KSP preconditioned resid norm 1.080641618881e+00 true resid norm 1.594038798061e-01 ||r(i)||/||b|| 8.917113771305e-03
> 9984 KSP Residual norm 1.080641618881e+00 % max 1.158244868066e+02 min 8.041279440761e-02 max/min 1.440373856671e+03
 > 9985 KSP preconditioned resid norm 1.080641618880e+00 true resid norm 1.594038723728e-01 ||r(i)||/||b|| 8.917113355483e-03
> 9985 KSP Residual norm 1.080641618880e+00 % max 1.158302224434e+02 min 7.912036884330e-02 max/min 1.463974753110e+03
 > 9986 KSP preconditioned resid norm 1.080641618717e+00 true resid norm 1.594038980749e-01 ||r(i)||/||b|| 8.917114793267e-03
> 9986 KSP Residual norm 1.080641618717e+00 % max 1.164682835790e+02 min 7.460686106511e-02 max/min 1.561093469371e+03
 > 9987 KSP preconditioned resid norm 1.080641618691e+00 true resid norm 1.594040222541e-01 ||r(i)||/||b|| 8.917121739901e-03
> 9987 KSP Residual norm 1.080641618691e+00 % max 1.166493032152e+02 min 7.459727412837e-02 max/min 1.563720720069e+03
 > 9988 KSP preconditioned resid norm 1.080641617240e+00 true resid norm 1.594049907736e-01 ||r(i)||/||b|| 8.917175919248e-03
> 9988 KSP Residual norm 1.080641617240e+00 % max 1.166813081045e+02 min 6.210350927266e-02 max/min 1.878819884271e+03
 > 9989 KSP preconditioned resid norm 1.080641612022e+00 true resid norm 1.594055829488e-01 ||r(i)||/||b|| 8.917209045757e-03
> 9989 KSP Residual norm 1.080641612022e+00 % max 1.166820415947e+02 min 4.513453999933e-02 max/min 2.585205069033e+03
 > 9990 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065477745e-01 ||r(i)||/||b|| 8.917263018470e-03
> 9990 KSP Residual norm 1.080641611645e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
 > 9991 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065477696e-01 ||r(i)||/||b|| 8.917263018201e-03
> 9991 KSP Residual norm 1.080641611645e+00 % max 3.063465549435e+01 min 3.063465549435e+01 max/min 1.000000000000e+00
 > 9992 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065477615e-01 ||r(i)||/||b|| 8.917263017744e-03
> 9992 KSP Residual norm 1.080641611645e+00 % max 3.066530412302e+01 min 3.844470687795e+00 max/min 7.976469744031e+00
 > 9993 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065476642e-01 ||r(i)||/||b|| 8.917263012302e-03
> 9993 KSP Residual norm 1.080641611645e+00 % max 3.714516899070e+01 min 1.336552632161e+00 max/min 2.779177422339e+01
 > 9994 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065476608e-01 ||r(i)||/||b|| 8.917263012110e-03
> 9994 KSP Residual norm 1.080641611645e+00 % max 4.500812884571e+01 min 1.226798972667e+00 max/min 3.668745234425e+01
 > 9995 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065476552e-01 ||r(i)||/||b|| 8.917263011801e-03
> 9995 KSP Residual norm 1.080641611645e+00 % max 8.688131738345e+01 min 1.183120593233e+00 max/min 7.343403358914e+01
 > 9996 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065473796e-01 ||r(i)||/||b|| 8.917262996379e-03
> 9996 KSP Residual norm 1.080641611645e+00 % max 9.802499878957e+01 min 1.168930461656e+00 max/min 8.385870845619e+01
 > 9997 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065472234e-01 ||r(i)||/||b|| 8.917262987642e-03
> 9997 KSP Residual norm 1.080641611645e+00 % max 1.122454823211e+02 min 1.141659208813e+00 max/min 9.831785304632e+01
 > 9998 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065471295e-01 ||r(i)||/||b|| 8.917262982389e-03
> 9998 KSP Residual norm 1.080641611645e+00 % max 1.134943126018e+02 min 1.090790203681e+00 max/min 1.040477923425e+02
 > 9999 KSP preconditioned resid norm 1.080641611644e+00 true resid norm 1.594064989598e-01 ||r(i)||/||b|| 8.917260287762e-03
> 9999 KSP Residual norm 1.080641611644e+00 % max 1.139914489020e+02 min 4.119830336343e-01 max/min 2.766896682528e+02
 > 10000 KSP preconditioned resid norm 1.080641611643e+00 true resid norm 1.594064428168e-01 ||r(i)||/||b|| 8.917257147097e-03
> 10000 KSP Residual norm 1.080641611643e+00 % max 1.140011170215e+02 min 2.894564222709e-01 max/min 3.938455264772e+02
> Then the number of iteration >10000
> The Programme stop with convergenceReason=-3
> Best,
> Meng
> ------------------ Original ------------------
> From:  "Barry Smith";<bsmith at mcs.anl.gov>;
 > Send time: Friday, Apr 25, 2014 6:27 AM
> To: "Oo "<wumeng07maths at qq.com>;
> Cc: "Dave May"<dave.mayhem23 at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
 > Subject:  Re: [petsc-users] Convergence_Eigenvalues_k=3
> On Apr 24, 2014, at 5:24 PM, Oo <wumeng07maths at qq.com> wrote:
> > Configure PETSC again?
>    No, the command line when you run the program.
> Barry
 > > From:  "Dave May";<dave.mayhem23 at gmail.com>;
> > Send time: Friday, Apr 25, 2014 6:20 AM
 > > Cc: "Barry Smith"<bsmith at mcs.anl.gov>; "Matthew Knepley"<knepley at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
> > On the command line
> > On 25 April 2014 00:11, Oo <wumeng07maths at qq.com> wrote:
> > Where should I put "-ksp_monitor_true_residual -ksp_monitor_singular_value " ?
> > Thanks,
> > Meng
> > Date:  Apr 25, 2014
> > To:  "Matthew Knepley"<knepley at gmail.com>;
 > > Cc:  "Oo "<wumeng07maths at qq.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
> >    There are also a great deal of “bogus” numbers that have no meaning and many zeros. Most of these are not the eigenvalues of anything.
> >    Run the two cases with -ksp_monitor_true_residual -ksp_monitor_singular_value and send the output
> >   Barry
> > On Apr 24, 2014, at 4:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > On Thu, Apr 24, 2014 at 12:57 PM, Oo <wumeng07maths at qq.com> wrote:
> > > Hi,
 > > > For analysis the convergence of linear solver,
> > > I meet a problem.
> > > One is the list of Eigenvalues whose linear system which has a convergence solution.
 > > > The other is the list of Eigenvalues whose linear system whose solution does not converge (convergenceReason=-3).
> > > These are just lists of numbers. It does not tell us anything about the computation. What is the problem you are having?
> > >   Matt
> > > Do you know what kind of method can be used to obtain a convergence solution for our non-convergence case?
> > > Thanks,
> > > Meng
> > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
 > > > -- Norbert Wiener
 -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140425/2cbb5b31/attachment-0001.html>
