[petsc-users] Convergence_Eigenvalues_k=3
    Dave May
    dave.mayhem23 at gmail.com
    Thu Apr 24 17:27:17 CDT 2014
Absolutely not!
Run your code again with the command line args Barry suggested.
./my.app -ksp_monitor_true_residual -ksp_monitor_singular_value
As long as you have called KSPSetFromOptions() (which from your code
snippet it seems you have) these options will take effect.
On 25 April 2014 00:24, Oo <wumeng07maths at qq.com> wrote:
> Configure PETSC again?
> ------------------ Original ------------------
> *From: * "Dave May";<dave.mayhem23 at gmail.com>;
> *Send time:* Friday, Apr 25, 2014 6:20 AM
> *To:* "Oo "<wumeng07maths at qq.com>;
> *Cc:* "Barry Smith"<bsmith at mcs.anl.gov>; "Matthew Knepley"<
> knepley at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
> *Subject: * Re: [petsc-users] Convergence_Eigenvalues_k=3
> On the command line
> On 25 April 2014 00:11, Oo <wumeng07maths at qq.com> wrote:
>> Where should I put "
>> -ksp_monitor_true_residual -ksp_monitor_singular_value " ?
>> Thanks,
>> Meng
>> *From: * "Barry Smith";<bsmith at mcs.anl.gov>;
>> *Date: * Apr 25, 2014
>> *To: * "Matthew Knepley"<knepley at gmail.com>;
>> *Cc: * "Oo "<wumeng07maths at qq.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
>>    There are also a great deal of “bogus” numbers that have no meaning
>> and many zeros. Most of these are not the eigenvalues of anything.
>>    Run the two cases with -ksp_monitor_true_residual
>> -ksp_monitor_singular_value and send the output
>>   Barry
>> On Apr 24, 2014, at 4:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Thu, Apr 24, 2014 at 12:57 PM, Oo <wumeng07maths at qq.com> wrote:
>> > Hi,
>> > For analysis the convergence of linear solver,
>> > I meet a problem.
>> > One is the list of Eigenvalues whose linear system which has a
>> convergence solution.
>> > The other is the list of Eigenvalues whose linear system whose solution
>> does not converge (convergenceReason=-3).
>> > These are just lists of numbers. It does not tell us anything about the
>> computation. What is the problem you are having?
>> >   Matt
>> > Do you know what kind of method can be used to obtain a convergence
>> solution for our non-convergence case?
>> > Thanks,
>> > Meng
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140425/546d2e50/attachment.html>
