[petsc-users] PETSC ERROR: KSPComputeEigenvalues()
Oo
wumeng07maths at qq.com
Thu Apr 24 05:26:19 CDT 2014
I met a problem when I tried to use "KSPComputeEigenvalues()".
The following is the solving part of my code.
When this programme run to the line
" KSPComputeEigenvalues(ksp, numberEigen, r, c,neig);"
Then, PETSc Errors appear.
Do you have any suggestions?
//Solving the Linear System Part====================================================== cout<<"solve the Linear system"<<endl; t0=(double)clock(); KSP ksp; PC pc; KSPCreate(PETSC_COMM_WORLD, &ksp); // KSPSetType(ksp, KSPCG); KSPSetType(ksp, KSPGMRES); KSPSetOperators(ksp, coeff_matrix, coeff_matrix, DIFFERENT_NONZERO_PATTERN);
PetscReal rtol=(1.e-4)*pow(h,4.0); PetscReal stol=(1.e-3)*pow(h,4.0);
KSPSetTolerances(ksp, rtol, stol, PETSC_DEFAULT, PETSC_DEFAULT);
KSPGetPC(ksp, &pc); PCSetType(pc, PCGAMG); KSPSetFromOptions(ksp);
//====KSPSetComputeEigenvalues() KSPSetComputeEigenvalues(ksp, PETSC_TRUE); //KSPSetComputeEigenvalues(ksp, PETSC_FALSE); //=============================
KSPSetUp(ksp);
KSPSolve(ksp, load_vect, m_solut);
cout<<"Before KSPComputeEignvalues()"<<endl; //======KSPComputeEigenvalues() numberEigen=1;//4*P_FEMMesh->P_Vertices->size(); KSPComputeEigenvalues(ksp,numberEigen,r,c,neig); cout<<"After KSPComputeEignvalues()"<<endl;
cout<<"EignValues:"<<endl; for(unsigned int j=0; j<numberEigen; j++) { cout<<r[numberEigen]<<" + "<<c[numberEigen]<<"i"<<endl; } //========================
Here is Petsc errors.when the programme runs to "KSPComputeEigenvalues(ksp,numberEigen,r,c,neig);"These errors appear.
PETSC ERRORs
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Null argument, when expecting valid pointer!
[0]PETSC ERROR: Null Pointer: Parameter # 3!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: /Users/wumeng/MyWork/BuildMSplineTools/bin/msplinePDE_PFEM_2 on a arch-darwin-c-debug named vis032b.sophia.inria.fr by wumeng Thu Apr 24 11:50:16 2014
[0]PETSC ERROR: Libraries linked from /Users/wumeng/MyWork/PETSc/arch-darwin-c-debug/lib
[0]PETSC ERROR: Configure run at Wed Dec 18 15:31:31 2013
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich
[0]PETSC ERROR: KSPComputeEigenvalues() line 118 in /Users/wumeng/MyWork/PETSc/src/ksp/ksp/interface/itfunc.c
EignValues:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] KSPComputeEigenvalues line 116 /Users/wumeng/MyWork/PETSc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: aborting job:
M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140424/980c85ec/attachment-0001.html>
