[petsc-users] setting Sundials options within petsc4py
Veltz Romain romain.veltz at inria.fr
Wed Apr 23 12:04:32 CDT 2014
Dear pets users,
I have been trying to set some sundials options from petsc4py but I am unsuccessful. I hope somebody will have a good pointer.
For example I can pass -ts_sundials_type bdf to python in the command line.
I would like to call TSSundialsSetTolerance to set the tolerance. Hence I need to pass some options in the command line (I don't know if this is possible for this particular function) or call TSSundialsSetTolerance(…) from petsc4py. So far, I am clueless.
Also, I would like to limit the step sizes. This is not documented in petsc_manual.pdf. But in sundial.c, there is PetscErrorCode  TSSundialsSetMaxTimeStep_Sundials(TS ts,PetscReal maxdt) which I would like to call also from petsc4py.
Thank you for your help,
Best regards,
Veltz Romain
Neuromathcomp Project Team
Inria Sophia Antipolis Méditerranée
2004 Route des Lucioles-BP 93
FR-06902 Sophia Antipolis
http://www-sop.inria.fr/members/Romain.Veltz/public_html/Home.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140423/d3774968/attachment.html>
