[petsc-users] MATLAB and PetSc
Sudheer Kumar sudheer3 at gmail.com
Wed Apr 23 07:36:58 CDT 2014
Hi Barry,
I have looked at code in bin/matlab/classes. It is not clear to me how to
use the code. Great if you could help me how to use these codes. So, with
these codes can we run the parallel version of Petsc code from MATLAB. Is
mex interface involved in compiling the Petsc code to MATLAB executable
dynamic library.
Regards
Sudheer
On Tue, Apr 22, 2014 at 11:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   PETSc does have a MATLAB interface in bin/matlab/classes that provides
> most of PETSc's functionality directly to Matlab. Unfortunately we do not
> have the resources to maintain it, so it is a bit broken. If you are
> familiar with MATLAB and interfacing with C then git it a try and we can
> provide a small amount of support to help you use it, but as I said we
> cannot make it perfect ourselves.
>    Barry
> On Apr 22, 2014, at 12:19 PM, Sudheer Kumar <sudheer3 at gmail.com> wrote:
> > On Tue, Apr 22, 2014 at 9:41 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > How much Matlab code do you have that computes the Jacobian and
> functions and is it parallel?
> > The MATLAB code that I am working with is of 1000s lines of code
> (reservoir simulator, http://www.sintef.no/Projectweb/MRST/). The 90% of
> the time taken by the code on benchmarks is for linear solvers. And that's
> the reason to look for PetSc to speedup the entire code.
> > >> This is a great deal of work and probably not worth it.
> > Ok, unfortunately here I guess I need to attempt to do that work. Do let
> me know your suggestions. Thanks.
> > Regards
> > Sudheer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140423/72ad3c94/attachment.html>
