[petsc-users] 2-stage preconditioner
    Peter Brune
    prbrune at gmail.com
    Tue Apr 22 09:49:42 CDT 2014
PCComposite is probably the answer
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCCOMPOSITE.html
The multiplicative variant will call one after the other.  In order to nest
it you may have to register your own custom type rather than using shell;
this is doable with
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCRegister.html
- Peter
On Tue, Apr 22, 2014 at 9:43 AM, Qin Lu <lu_qin_2000 at yahoo.com> wrote:
> Hello,
> I need to implement a 2-stage preconditioner using PETSc linear solver:
> 1. The first stage uses a user-provided preconditioner routine. It seems I
> can set it with PCShellSetApply.
> 2. The second stage uses PETSc's ILU.
> Shall I just call this two preconditioners in sequence, or there is a
> particular way to hook them up? Is there any sample code for this?
> Many thanks for your suggestions.
> Best Regards,
> Qin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140422/db1dc4ab/attachment.html>
