[petsc-users] [beginner question] Different communicators in the two objects: Argument # 1 and 2 flag 3!
    Niklas Fischer
    niklas at niklasfi.de
    Tue Apr 22 06:48:12 CDT 2014
Am 22.04.2014 13:08, schrieb Jed Brown:
> Niklas Fischer <niklas at niklasfi.de> writes:
>> Hello,
>> I have attached a small test case for a problem I am experiencing. What
>> this dummy program does is it reads a vector and a matrix from a text
>> file and then solves Ax=b. The same data is available in two forms:
>>   - everything is in one file (matops.s.0 and vops.s.0)
>>   - the matrix and vector are split between processes (matops.0,
>> matops.1, vops.0, vops.1)
>> The serial version of the program works perfectly fine but unfortunately
>> errors occure, when running the parallel version:
>> make && mpirun -n 2 a.out matops vops
>> mpic++ -DPETSC_CLANGUAGE_CXX -isystem
>> /home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/include -isystem
>> /home/data/fischer/libs/petsc-3.4.3/include petsctest.cpp -Werror -Wall
>> -Wpedantic -std=c++11 -L
>> /home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/lib -lpetsc
>> /usr/bin/ld: warning: libmpi_cxx.so.0, needed by
>> /home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/lib/libpetsc.so,
>> may conflict with libmpi_cxx.so.1
>> /usr/bin/ld: warning: libmpi.so.0, needed by
>> may conflict with libmpi.so.1
>> librdmacm: couldn't read ABI version.
>> librdmacm: assuming: 4
>> CMA: unable to get RDMA device list
>> [[43019,1],0]: A high-performance Open MPI point-to-point messaging module
>> was unable to find any relevant network interfaces:
>> Module: OpenFabrics (openib)
>>    Host: dornroeschen.igpm.rwth-aachen.de
> It looks like your MPI is either broken or some of the code linked into
> your application was compiled with a different MPI or different version.
> Make sure you can compile and run simple MPI programs in parallel.
Hello Jed,
thank you for your inputs. Unfortunately MPI does not seem to be the
issue here. The attachment contains a simple MPI hello world program
which runs flawlessly (I will append the output to this mail) and I have
not encountered any problems with other MPI programs. My question still
stands.
Greetings,
Niklas Fischer
mpirun -np 2 ./mpitest
[[44086,1],0]: A high-performance Open MPI point-to-point messaging module
Another transport will be used instead, although this may result in
lower performance.
Hello world from processor dornroeschen.igpm.rwth-aachen.de, rank 0 out
of 2 processors
Hello world from processor dornroeschen.igpm.rwth-aachen.de, rank 1 out
of 2 processors
[dornroeschen.igpm.rwth-aachen.de:128141] 1 more process has sent help
message help-mpi-btl-base.txt / btl:no-nics
[dornroeschen.igpm.rwth-aachen.de:128141] Set MCA parameter
"orte_base_help_aggregate" to 0 to see all help / error messages
