[petsc-users] Elasticity tensor in ex52
Sat Apr 19 18:19:10 CDT 2014
On Sat, Apr 19, 2014 at 5:25 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> Thanks for your response. Now I understand a bit better your
> implementation, but I am still confused. Is the g3 function equivalent to
> the f_{1,1} function in the matrix in equation (3) in this paper:
> http://arxiv.org/pdf/1309.1204v2.pdf ? If so, why would it have terms
> that depend on the trial fields? I think this is what is confusing me.
Yes, it is. It has no terms that depend on the trial fields. It is just
indexed by the number of components in that field. It is
a continuum thing, which has nothing to do with the discretization. That is
why it acts pointwise.
   Matt
> On Sat, Apr 19, 2014 at 11:35 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Apr 18, 2014 at 1:23 PM, Miguel Angel Salazar de Troya <
>>> Hello everybody.
>>> First, I am taking this example from the petsc-dev version, I am not
>>> sure if I should have posted this in another mail-list, if so, my
>>> apologies.
>>> In this example, for the elasticity case, function g3 is built as:
>>> void g3_elas(const PetscScalar u[], const PetscScalar gradU[], const
>>> PetscScalar a[], const PetscScalar gradA[], const PetscReal x[],
>>> PetscScalar g3[])
>>>   const PetscInt dim   = spatialDim;
>>>   const PetscInt Ncomp = spatialDim;
>>>   PetscInt       compI, d;
>>>   for (compI = 0; compI < Ncomp; ++compI) {
>>>     for (d = 0; d < dim; ++d) {
>>>       g3[((compI*Ncomp+compI)*dim+d)*dim+d] = 1.0;
>>> Therefore, a fourth-order tensor is represented as a vector. I was
>>> checking the indices for different iterator values, and they do not seem to
>>> match the vectorization that I have in mind. For a two dimensional case,
>>> the indices for which the value is set as 1 are:
>>> compI = 0 , d = 0      ----->     index = 0
>>> compI = 0 , d = 1      ----->     index = 3
>>> compI = 1 , d = 0      ----->     index = 12
>>> compI = 1 , d = 1      ----->     index = 15
>>> The values for the first and last seem correct to me, but they other two
>>> are confusing me. I see that this elasticity tensor (which is the
>>> derivative of the gradient by itself in this case) would be a four by four
>>> identity matrix in its matrix representation, so the indices in between
>>> would be 5 and 10 instead of 3 and 12, if we put one column on top of each
>>> other.
>> I have read this a few times, but I cannot understand that you are
>> asking. The simplest thing I can
>> respond is that we are indexing a row-major array, using the indices:
>>   g3[ic, id, jc, jd]
>> where ic indexes the components of the trial field, id indexes the
>> derivative components,
>> jc indexes the basis field components, and jd its derivative components.
>>    Matt
>>> I guess my question is then, how did you vectorize the fourth order
>>> tensor?
>>> Thanks in advance
>>> Miguel
>>> *Miguel Angel Salazar de Troya*
>>> Graduate Research Assistant
>>> Department of Mechanical Science and Engineering
>>> University of Illinois at Urbana-Champaign
>>> (217) 550-2360
>>> salaza11 at illinois.edu
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140419/75018348/attachment.html>
