[petsc-users] Preconditioner and number of processors
Xiao, Jianjun (IKET) jianjun.xiao at kit.edu
Thu Apr 17 14:48:53 CDT 2014
Dear developers,
I find the words below in PETSc FAQ.
"Most commonly, you are using a preconditioner which behaves differently based upon the number of processors, such as Block-Jacobi which is the PETSc default."
I am testing the fidelity of my code. I don't want to be disturbed by the different numbers of procs. I know Block-Jacobi may be fast. But currently I don't care the speed. I need a preconditioner which behaves exactly the same with various procs. Which preconditioner should I use?
Thank you.
Best regards
JJ
