[petsc-users] possible performance issues with PETSc on Cray
Jed Brown jed at jedbrown.org
Fri Apr 11 06:44:10 CDT 2014
Samar Khatiwala <spk at ldeo.columbia.edu> writes:
> Hello,
> This is a somewhat vague query but I and a colleague have been running PETSc (3.4.3.0) on a Cray
> XC30 in Germany (https://www.hlrn.de/home/view/System3/WebHome) and the system administrators
> alerted us to some anomalies with our jobs that may or may not be related to PETSc but I thought I'd ask
> here in case others have noticed something similar.
> First, there was a large variation in run-time for identical jobs, sometimes as much as 50%. We didn't
> really pick up on this but other users complained to the IT people that their jobs were taking a performance
> hit with a similar variation in run-time. At that point we're told the IT folks started monitoring jobs and
> carrying out tests to see what was going on. They discovered that (1) this always happened when we were
> running our jobs and (2) the problem got worse with physical proximity to the nodes on which our jobs were
> running (what they described as a "strong interaction" between our jobs and others presumably through the
> communication network).
It sounds like you are strong scaling (smallish subdomains) so that your
application is sensitive to network latency.  I see significant
performance variability on XC-30 with this Full Multigrid solver that is
not using PETSc.
http://59a2.org/files/hopper-vs-edison.3semilogx.png
See the factor of 2 performance variability for the samples of the ~15M
element case.  This operation is limited by instruction issue rather
than bandwidth (indeed, it is several times faster than doing the same
operations with assembled matrices).  Here the variability is within the
same application performing repeated solves.  If you get a different
partition on a different run, you can see larger variation.
If your matrices are large enough, your performance will be limited by
memory bandwidth.  (This is the typical case, but sufficiently small
matrices can fit in cache.)  I once encountered a batch system that did
not properly reset nodes between runs, leaving a partially-filled
ramdisk distributed asymmetrically across the memory busses.  This led
to 3x performance reduction on 4-socket nodes because much of the memory
demanded by the application would be faulted onto one memory bus.
Presumably your machine has a resource manager that would not allow such
things to happen.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140411/535b6469/attachment-0001.pgp>
