[petsc-users] Failed to compile the PETsc-dev with cuda, mpicc can not recognize c++ key word in thrust and cusp (Lei Shi)
Christophe Ortiz christophe.ortiz at ciemat.es
Fri Apr 11 03:42:27 CDT 2014
Maybe I'm wrong but I think the following options are missing if you want
to use C++:
--with-cxx=(g++ or icc....) --with-clanguage=cxx
Christophe
> Message: 2
> Date: Fri, 11 Apr 2014 03:26:09 -0500
> From: Lei Shi <stoneszone at gmail.com>
> To: petsc-users at mcs.anl.gov
> Subject: [petsc-users] Failed to compile the PETsc-dev with cuda,
> Message-ID:
>         <CAEV8=
> V9JJr+8Np5JaOKqgrkS12KJ6TaO3V4wM9YPo-NG29EU-A at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi guys,
> I tried to compile petsc-dev with cuda5, but failed. I think the problem
> is the PETsc-dev with cuda, mpicc can not recognize c++ key word in thrust
> and cusp. Please help me out. here is my option file
> configure_options = [
>     '--with-shared-libraries=0',
>     '--with-mpi-dir=/media/public/MPICH3/mpich-install/',
>     '--with-cuda=1',
>     '--with-cuda-dir=/usr/local/cuda',
>     '--with-cudac=/usr/local/cuda/bin/nvcc',
>     '--with-cuda-arch=sm_20',
>     '--with-cusp-dir=/usr/local/cuda/include/cusp',
>     '--with-thrust=1',
>     '--with-cusp=1',
>     '--with-debugging=0',
>     '--with-precision=double',
>     'COPTFLAGS=-O3',
>     'CXXOPTFLAGS=-O3',
>     'FOPTFLAGS=-O3',
> and the error i got
>              Configuring PETSc to compile on your system
> TESTING: alternateConfigureLibrary from
> PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:65)
>  Compilers:
>   C Compiler:         /media/public/MPICH3/mpich-install/bin/mpicc  -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3
>   CUDA Compiler:      /usr/local/cuda/bin/nvcc  -O -arch=sm_20
>   C++ Compiler:       /media/public/MPICH3/mpich-install/bin/mpicxx  -Wall
> Linkers:
>   Static linker:   /usr/bin/ar cr
>   Dynamic linker:   /usr/bin/ar
> make:
> MPI:
>   Includes: -I/media/public/MPICH3/mpich-install/include
> BLAS/LAPACK: -llapack -lblas
> X:
>   Library:  -lX11
> pthread:
>   Library:  -lpthread
> valgrind:
> cuda:
>   Includes: -I/usr/local/cuda/include
>   Library:  -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
> -lcufft -lcublas -lcudart -lcusparse
>   Arch:     -arch=sm_20
> cusp:
>   Includes: -I/usr/local/cuda/include/cusp/
> -I/usr/local/cuda/include/cusp/include
> thrust:
> sowing:
> c2html:
> PETSc:
>   PETSC_ARCH: arch-cuda5-cg-opt
>   PETSC_DIR: /home/leishi/work/development/3rd_party/petsc/petsc
>   Clanguage: C
>   Memory alignment: 16
>   Scalar type: real
>   Precision: double
>   shared libraries: disabled
> xxx=========================================================================xxx
>  Configure stage complete. Now build PETSc libraries with (gnumake build):
>    make PETSC_DIR=/home/leishi/work/development/3rd_party/petsc/petsc
> PETSC_ARCH=arch-cuda5-cg-opt all
> Using C/C++ compile: /media/public/MPICH3/mpich-install/bin/mpicc -c -Wall
> -I/home/leishi/work/development/3rd_party/pet\
> sc/petsc/include
> -I/home/leishi/work/development/3rd_party/petsc/petsc/arch-cuda5-cg-opt/include
> -I/usr/local/cuda/include -I/usr/local/cuda/include/cusp/
> -I/usr/local/cuda/include/cus\
> p/include -I/media/public/MPICH3/mpich-install/include
> mpicc -show: gcc -I/media/public/MPICH3/mpich-install/include
> -L/media/public/MPICH3/mpich-install/lib -lmpich -lopa -lmpl -lrt -lpthread
> Using CUDA compile: /usr/local/cuda/bin/nvcc -O -arch=sm_20  -c
> --compiler-options=-Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -O3 -I/home/leishi/work/development/3\
> rd_party/petsc/petsc/include
> -I/usr/local/cuda\
> /include/cusp/include -I/media/public/MPICH3/mpich-install/include
> Using C/C++ linker: /media/public/MPICH3/mpich-install/bin/mpicc
> Using C/C++ flags: -Wall -Wwrite-strings -Wno-strict-aliasing
> Using libraries:
> -L/home/leishi/work/development/3rd_party/petsc/petsc/arch-cuda5-cg-opt/lib
>  -lpetsc -llapack -lblas -lX11 -lpthread -Wl,-rpath,/usr/local/cuda/lib64
> -L/usr/local/cuda\
> /lib64 -lcufft -lcublas -lcudart -lcusparse -lm
> -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/x86_64-linux-gnu
> -L/lib/x86_64-linux-gnu -L/usr/\
> lib/gcc/x86_64-linux-gnu/4.8 -lmpichcxx -lstdc++ -ldl -lmpich -lopa -lmpl
> -lrt -lpthread -lgcc_s -ldl
> Using mpiexec: /media/public/MPICH3/mpich-install/bin/mpiexec
> Building PETSc using GNU Make with 18 build threads
> make[2]: Entering directory
> `/home/leishi/work/development/3rd_party/petsc/petsc'
> Use "/usr/bin/make V=1" to see the verbose compile lines.
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/arch.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/fhost.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/fuser.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/memc.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/mpiu.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/psleep.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sortd.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sorti.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/str.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sortip.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/pbarrier.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/pdisplay.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/ctable.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/psplit.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/select.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/mpimesg.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sseenabled.o
>           CC arch-cuda5-cg-opt/obj/src/sys/utils/mpitr.o
> In file included from /usr/local/cuda/include/cusp/detail/config.h:24:0,
>                  from /usr/local/cuda/include/cusp/complex.h:63,
>                  from
> /home/leishi/work/development/3rd_party/petsc/petsc/include/petscmath.h:145,
>                  from
> /home/leishi/work/development/3rd_party/petsc/petsc/include/petscsys.h:366,
>                  from
> /home/leishi/work/development/3rd_party/petsc/petsc/include/petsc-private/petscimpl.h:8,
>                  from
> /home/leishi/work/development/3rd_party/petsc/petsc/src/sys/objects/options.c:14:
> /usr/local/cuda/include/thrust/version.h:69:1: error: unknown type name
> ?namespace?
> /usr/local/cuda/include/thrust/version.h:70:1: error: expected ?=?, ?,?,
> ?;?, ?asm? or ?__attribute__? before ?{? token
> /home/leishi/work/development/3rd_party/petsc/petsc/include/petscmath.h:145:0,
>                  from
>                  from
>                  from
> /usr/local/cuda/include/cusp/complex.h:70:19: fatal error: complex: No such
> file or directory
> compilation terminated.
>           CC arch-cuda5-cg-opt/obj/src/sys/objects/state.o
>           CC arch-cuda5-cg-opt/obj/src/sys/objects/aoptions.o
>           CC arch-cuda5-cg-opt/obj/src/sys/objects/subcomm.o
>                  from
>                  from
>                  from
> /home/leishi/work/development/3rd_party/petsc/petsc/src/sys/objects/init.c:10:
> /usr/local/cuda/include/thrust/version.h:69:1: error:* unknown type name
> ?namespace? *
>                  from
>                  from
> file or directory
> make: *** [all] Error 1
> Sincerely Yours,
> Lei Shi
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140411/4831a810/attachment.html
> petsc-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> End of petsc-users Digest, Vol 64, Issue 26
> Confidencialidad:
> Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su
> destinatario y puede contener información privilegiada o confidencial. Si
> no es vd. el destinatario indicado, queda notificado de que la utilización,
> divulgación y/o copia sin autorización está prohibida en virtud de la
> legislación vigente. Si ha recibido este mensaje por error, le rogamos que
> nos lo comunique inmediatamente respondiendo al mensaje y proceda a su
> destrucción.
> Disclaimer:
> This message and its attached files is intended exclusively for its
> recipients and may contain confidential information. If you received this
> e-mail in error you are hereby notified that any dissemination, copy or
> disclosure of this communication is strictly prohibited and may be
> unlawful. In this case, please notify us by a reply and delete this email
> and its contents immediately.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140411/0db82cfb/attachment.html>
