[petsc-users] Intel Internal compiler error: segmentation violation signal raised
Dharmendar Reddy dharmareddy84 at gmail.com
Tue Apr 8 11:31:37 CDT 2014
Hello wee-beng,
                            What is the version of intel compiler you
are using ? I use 13.1.0.146 Build 20130121, i have no issues using
petsc.h90 in my fortran code.
Reddy
On Tue, Apr 8, 2014 at 7:15 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi Barry,
> Thanks for the advice. It took me a while to compile and build successfully
> with gfortran due to the stricter rules and entirely different options.
> But the most problematic thing was that most clusters I work with use old
> versions of gcc/gfortran. With the gcc/gfortran tied to the MPI, it seems
> that I can't just update myself to use the new version, or can I?
> Also, can anyone recommend options to get optimized results in gfortran?
> I'm using :
> -fno-signed-zeros  -fno-trapping-math -ffast-math -march=native
> -funroll-loops -ffree-line-length-none -O3
> Thank you.
> Yours sincerely,
> TAY wee-beng
> On 8/4/2014 8:04 PM, Barry Smith wrote:
>>     You should never get yourself in a position where you "have to" use a
>> particular compiler. Strive to have portable makefiles that don't depend on
>> the compiler (with PETSc makefiles this is easy) and to have portable code
>> that doesn't depend on the compiler. Then switching between compilers takes
>> literally a couple minutes. It is extremely counter productive to do nothing
>> for days because the compiler you are using doesn't work under a particular
>> circumstance. It really isn't hard to set things up so changing compilers is
>> easy.
>>     Barry
>> On Apr 8, 2014, at 6:39 AM, Jed Brown <jed at jedbrown.org> wrote:
>>> TAY wee-beng <zonexo at gmail.com> writes:
>>>> My impression was intel is mostly faster. However, does it apply to
>>>> gfortran too? Is it also faster for a lot of code than Intel fortran?
>>>> I'll give it a go if it's so. However, I remember changing a no. of
>>>> options to build and in the end, it was slower. that's a few yrs ago
>>>> though.
>>> It varies, but usually not by a large factor and a broken compiler takes
>>> infinitely long to produce correct answers.  Report the bug to Intel,
>>> use gfortran (latest version), and get on with your business.  If/when
>>> Intel fixes the bug, if you still have a license, try ifort again.
