[petsc-users] Intel Internal compiler error: segmentation violation signal raised
TAY wee-beng zonexo at gmail.com
Mon Apr 7 18:46:56 CDT 2014
On 8/4/2014 12:40 AM, Matthew Knepley wrote:
> How about just including petsc.h90 so you get everything.
>   Thanks,
>      Matt
Sorry this is my 2nd email. See below for the 1st email. Using petsc.h90
gave the error "... segmentation violation signal raised ...."
> On Mon, Apr 7, 2014 at 5:19 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Sorry I realised that
>     *#include "finclude/petscdmda.h90"*
>     *#include "finclude/petscksp.h90"*
>     also gave errors:
>     *//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
>     error #5082: Syntax error, found ',' when expecting one of: ( % [
>     /**/          PetscInt, pointer :: array(:)/**/
>     /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
>     error #5082: Syntax error, found END-OF-STATEMENT when expecting
>     one of: ) ,/**/
>     /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11):
>     error #5082: Syntax error, found IDENTIFIER 'N' when expecting one
>     of: ( % [ : . = =>/**/
>     /**/          PetscInt  n/**/
>     /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12):
>     error #5082: Syntax error, found IDENTIFIER 'IERR' when expecting
>     one of: ( % [ : . = =>/**/
>     /**/          PetscErrorCode ierr/**/
>     /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13):
>     error #5082: Syntax error, found IDENTIFIER 'V' when expecting one
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 7/4/2014 6:16 PM, TAY wee-beng wrote:
Here's the 1st email:
>>     Hi,
>>     I encountered the error below when compiling my code using intel
>>     fortran:
>>     /tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler
>>     error: segmentation violation signal raised** Please report this
>>     error along with the circumstances in which it occurred in a
>>     Software Problem Report.  Note: File and line given may not be
>>     explicit cause of this error.
>>     In the end, I realised that it is due to using *petsc.h90*:
>>     module PETSc_solvers
>>     use set_matrix
>>     implicit none
>>     contains
>>     subroutine semi_momentum_simple_xyz(du,dv,dw)
>>     *#include "finclude/petsc.h90"*
>>     integer :: i,j,k,ijk,ierr,II !,ro...
>>     If I use :
>>     *#include "finclude/petsc.h"
>>     or
>>     Then there is no problem.
>>     May I know why this is happening?
>>     Although I can now compile and build successfully, is this the
>>     right way to go?
>>     Thank you
>>     Yours sincerely,
>>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140408/a6b111ac/attachment.html>
