[petsc-users] Intel Internal compiler error: segmentation violation signal raised
TAY wee-beng zonexo at gmail.com
Mon Apr 7 05:19:25 CDT 2014
Sorry I realised that
*#include "finclude/petscdmda.h90"*
*#include "finclude/petscksp.h90"*
also gave errors:
*//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
error #5082: Syntax error, found ',' when expecting one of: ( % [ : . =
/**/          PetscInt, pointer :: array(:)/**/
/**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
error #5082: Syntax error, found END-OF-STATEMENT when expecting one of:
/**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11):
error #5082: Syntax error, found IDENTIFIER 'N' when expecting one of: (
/**/          PetscInt  n/**/
/**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12):
error #5082: Syntax error, found IDENTIFIER 'IERR' when expecting one
of: ( % [ : . = =>/**/
/**/          PetscErrorCode ierr/**/
/**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13):
error #5082: Syntax error, found IDENTIFIER 'V' when expecting one of: (
Thank you
Yours sincerely,
TAY wee-beng
On 7/4/2014 6:16 PM, TAY wee-beng wrote:
> Hi,
> I encountered the error below when compiling my code using intel fortran:
> /tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler error:
> segmentation violation signal raised** Please report this error along
> with the circumstances in which it occurred in a Software Problem
> Report.  Note: File and line given may not be explicit cause of this
> error.
> In the end, I realised that it is due to using *petsc.h90*:
> module PETSc_solvers
> use set_matrix
> implicit none
> contains
> subroutine semi_momentum_simple_xyz(du,dv,dw)
> *#include "finclude/petsc.h90"*
> integer :: i,j,k,ijk,ierr,II !,ro...
> If I use :
> *#include "finclude/petsc.h"
> or
> Then there is no problem.
> May I know why this is happening?
> Although I can now compile and build successfully, is this the right
> way to go?
> Thank you
> Yours sincerely,
> TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140407/6900443b/attachment-0001.html>
