[petsc-users] Trying to write Fortran version of ksp/ex34.c
Thu Apr 3 14:54:34 CDT 2014
On Thu, Apr 3, 2014 at 2:49 PM, Åsmund Ervik <asmund.ervik at ntnu.no> wrote:
>  Hi Matt,
> I'm handling the null space in the same way as ex34, that is, I remove the
> null space (containing just the constant functions, I think) in both
> ComputeRHS and ComputeMatrix.
That should be fine.
> However, I just tried commenting out those lines (MatNullSpaceCreate,
> MatSetNullSpace or MatNullSpaceRemove, MatNullSpaceDestroy) and that has no
> effect. The same happens in ex34.c, commenting out the lines fixing the
> null space makes no difference. Does that make sense?
It appears that the RHS in ex34 already has zero mean. Its possible for
some Krylov iteration to preserve this property, but
I think if you played around with solvers you could find one that screws it
up without null space removal.
> Are these examples intended to be run with some special options? I see in
> the makefile (e.g. runex34) that there are a lot of multigrid options, but
> I don't think that should matter?
> Also, could you confirm that ex34.c does zero Neumann BCs? The header was
> a bit confusing, it says u=0 but I assume it should be du/dn = 0 (zero
> normal derivative)?
Yes, its pure Neumann. Note that this is an easy analytical solution, so
you can check your example.
   Matt
> This is with 3.4.4, by the way.
> Thanks,
> Åsmund
> *Fra:* Matthew Knepley [knepley at gmail.com]
> *Sendt:* 3. april 2014 15:56
> *Til:* Åsmund Ervik
> *Kopi:* petsc-users at mcs.anl.gov
> *Emne:* Re: [petsc-users] Trying to write Fortran version of ksp/ex34.c
>    On Thu, Apr 3, 2014 at 8:43 AM, Åsmund Ervik <asmund.ervik at ntnu.no>wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Dear PETSc users,
>> I'm trying to write a Poisson solver in Fortran using the
>> KSPSetComputeOperators etc. framework. When debugging this, I ended up
>> modifying ksp/ex22.f so that it matches ksp/ex34.c. The difference
>> between these is that ex34.c has a non-constant RHS and Neumann BCs,
>> which is closer to what I want.
>  If it has Neumann conditions, then it has a null space. Have you
> included this in
> your solver? That can cause a residual offset.
>    Matt
>> Now, when I run these two programs I get the following:
>> ./ex22f_mod
>>    Residual, L2 norm         1.007312
>>    Error, sup norm         0.020941
>>    Error, L1 norm        10.687882
>>    Error, L2 norm         0.340425
>> ./ex34
>>    Residual, L2 norm 1.07124e-05
>>    Error, sup norm 0.0209405
>>    Error, L1 norm 0.00618512
>>    Error, L2 norm 0.000197005
>> but when I MatView/VecView the matrix and RHS for each example (write
>> them to file), there is no difference. I have attached ex22f_mod.F90,
>> any suggestions on what the error is?
>> Once this example works, you can of course include it with PETSc.
>> Regards,
>> Åsmund
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v2.0.22 (GNU/Linux)
>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>> iQEcBAEBAgAGBQJTPWWZAAoJED+FDAHgGz19aNYIANyq9k3a5kHzTlAdybkZCYDw
>> yKtDE5l/4iWYmNL49FH8AocHVcRivLaeJG5CGKqySFtZUXOlC9DM7rn4UmuQecni
>> dgIQuTk0Ym+OJccHyT5xxnebpFVNrIOTpInfQaDW6dTyeL1svAMeHqslKaGepySL
>> q/cODbgNDYgl6uumB+POMZevtlM6HPhl/1m7HofcHC9upvTRjSPqP1cg+kg+/8m2
>> Fdie/X7PCBfShrAys94kNXNcwtbO7taauphkQGMfyl0gUd+lFATG6zrEZdDqSFlV
>> c44GFFbxW/SRIDBXdOeX9/cy75KW5do1Sildwb6R4H/i7t6/hCJUJuss7FHjmLc=
>> =tV3N
>> -----END PGP SIGNATURE-----
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140403/acd9a2eb/attachment.html>
