[petsc-users] Problem with TS and PCMG
Torquil Macdonald Sørensen
torquil at gmail.com
Tue Apr 1 17:00:51 CDT 2014
On 19/12/13 00:50, Jed Brown wrote:
>> I'm using PCMG. My minimal testcase program has everything
>> hardcoded. I'm not providing any runtime options other than
>> -start_in_debugger, so everything can be seen from the code. I've
>> since made a couple of small changes that might influence line number
>> statements from GDB, so I'm including the newest version in this
>> message.
>> Here is the GDB output of "bt full" and the corresponding program code:
>> (gdb) bt full
>> #1 0x00007ffdc080d172 in DMCoarsen (dm=0x1fa7df0, comm=0x7ffdbffdd9c0
>> <ompi_mpi_comm_null>, dmc=0x2048f00) at dm.c:1811
>> ierr = 0
>> link = 0x7ffdc1af1640
>> __func__ = "DMCoarsen"
>> #2 0x00007ffdc0c41c1e in PCSetUp_MG (pc=0x1ff7570) at mg.c:593
>> kdm = 0x1d5b370
>> p = 0xb453
>> rscale = 0x1ff7570
>> lu = PETSC_FALSE
>> svd = (PETSC_TRUE | unknown: 32764)
>> dB = 0x0
>> __func__ = "PCSetUp_MG"
>> tvec = 0x0
>> viewer = 0x0
>> mglevels = 0x2006980
>> ierr = 0
>> preonly = PETSC_FALSE
>> cholesky = (unknown: 3246112504)
>> mg = 0x20060c0
>> i = 0
>> n = 2
>> redundant = (unknown: 1211234)
>> use_amat = PETSC_TRUE
>> dms = 0x2048f00
>> cpc = 0x200f620
>> dump = PETSC_FALSE
>> opsset = PETSC_FALSE
>> dA = 0x7ffdc1af1640
>> uflag = DIFFERENT_NONZERO_PATTERN
> Okay, this is the relevant bit of code.
> /* Skipping this for galerkin==2 (externally managed hierarchy such as ML and GAMG). Cleaner logic here would be great. Wrap ML/GAMG as DMs? */
> if (pc->dm && mg->galerkin != 2 && !pc->setupcalled) {
> /* construct the interpolation from the DMs */
> Mat p;
> Vec rscale;
> ierr = PetscMalloc1(n,&dms);CHKERRQ(ierr);
> dms[n-1] = pc->dm;
> for (i=n-2; i>-1; i--) {
> DMKSP kdm;
> ierr = DMCoarsen(dms[i+1],MPI_COMM_NULL,&dms[i]);CHKERRQ(ierr);
> ierr = KSPSetDM(mglevels[i]->smoothd,dms[i]);CHKERRQ(ierr);
> if (mg->galerkin) {ierr = KSPSetDMActive(mglevels[i]->smoothd,PETSC_FALSE);CHKERRQ(ierr);}
> ierr = DMGetDMKSPWrite(dms[i],&kdm);CHKERRQ(ierr);
> /* Ugly hack so that the next KSPSetUp() will use the RHS that we set. A better fix is to change dmActive to take
> * a bitwise OR of computing the matrix, RHS, and initial iterate. */
> kdm->ops->computerhs = NULL;
> kdm->rhsctx = NULL;
> if (!mglevels[i+1]->interpolate) {
> ierr = DMCreateInterpolation(dms[i],dms[i+1],&p,&rscale);CHKERRQ(ierr);
> I'm inclined to implement DMCoarsen_Shell() so that it carries through
> to the levels. It won't be used for interpolation because of the final
> conditional (the user has already set mglevels[i+1]->interpolate). This
> is slightly annoying because it's one more function that users have to
> implement. I think the patch below will also work, though I'm nervous
> about DMShellSetCreateMatrix().
> diff --git i/src/dm/interface/dm.c w/src/dm/interface/dm.c
> index ec60763..c987200 100644
> --- i/src/dm/interface/dm.c
> +++ w/src/dm/interface/dm.c
> @@ -1943,7 +1943,11 @@ PetscErrorCode DMCoarsen(DM dm, MPI_Comm comm, DM *dmc)
> PetscFunctionBegin;
> PetscValidHeaderSpecific(dm,DM_CLASSID,1);
> - ierr = (*dm->ops->coarsen)(dm, comm, dmc);CHKERRQ(ierr);
> + if (dm->ops->coarsen) {
> + ierr = (*dm->ops->coarsen)(dm, comm, dmc);CHKERRQ(ierr);
> + } else {
> + ierr = DMShellCreate(comm,dmc);CHKERRQ(ierr);
> (*dmc)->ops->creatematrix = dm->ops->creatematrix;
> ierr = PetscObjectCopyFortranFunctionPointers((PetscObject)dm,(PetscObject)*dmc);CHKERRQ(ierr);
> (*dmc)->ctx = dm->ctx;
I tried this patch against 3.4.4, and got the following error when
running my test program:
tmac at lenovo:/tmp/build$ ./ts_multigrid.exe
[0]PETSC ERROR: PetscCommDuplicate() line 148 in
/tmp/petsc-3.4.4/src/sys/objects/tagm.c
[0]PETSC ERROR: PetscHeaderCreate_Private() line 55 in
/tmp/petsc-3.4.4/src/sys/objects/inherit.c
[0]PETSC ERROR: DMCreate() line 82 in /tmp/petsc-3.4.4/src/dm/interface/dm.c
[0]PETSC ERROR: DMShellCreate() line 589 in
/tmp/petsc-3.4.4/src/dm/impls/shell/dmshell.c
[0]PETSC ERROR: DMCoarsen() line 1815 in
[0]PETSC ERROR: PCSetUp_MG() line 593 in
/tmp/petsc-3.4.4/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: PCSetUp() line 890 in
/tmp/petsc-3.4.4/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 278 in
/tmp/petsc-3.4.4/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 399 in
[0]PETSC ERROR: SNESSolve_KSPONLY() line 44 in
/tmp/petsc-3.4.4/src/snes/impls/ksponly/ksponly.c
[0]PETSC ERROR: SNESSolve() line 3636 in
/tmp/petsc-3.4.4/src/snes/interface/snes.c
[0]PETSC ERROR: TSStep_Theta() line 183 in
/tmp/petsc-3.4.4/src/ts/impls/implicit/theta/theta.c
[0]PETSC ERROR: TSStep() line 2507 in /tmp/petsc-3.4.4/src/ts/interface/ts.c
[0]PETSC ERROR: main() line 57 in
"unknowndirectory/"/home/tmac/programming/petsc/source/ts_multigrid.cpp
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
The test program ts_multigrid.cpp is:
#include "petscts.h"
int main(int argc, char ** argv)
PetscErrorCode ierr = PetscInitialize(&argc, &argv, 0, 0);
CHKERRQ(ierr);
int const nb_dof_fine = 5;
int const nb_dof_coarse = 3;
Vec x; // A vector to hold the solution on the fine grid
ierr = VecCreateSeq(PETSC_COMM_SELF, nb_dof_fine, &x); CHKERRQ(ierr);
Mat Id; // Identity matrix on the vector space of the fine grid
ierr = MatCreateSeqAIJ(PETSC_COMM_SELF, nb_dof_fine, nb_dof_fine, 1,
0, &Id); CHKERRQ(ierr);
for(int i = 0; i != nb_dof_fine; ++i) {
MatSetValue(Id, i, i, 1.0, INSERT_VALUES);
ierr = MatAssemblyBegin(Id, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
ierr = MatAssemblyEnd(Id, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
Mat interpolation; // Multigrid interpolation matrix
ierr = MatCreateSeqAIJ(PETSC_COMM_SELF, nb_dof_fine, nb_dof_coarse,
2, 0, &interpolation); CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 0, 0, 1.0, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 1, 0, 0.5, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 1, 1, 0.5, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 2, 1, 1.0, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 3, 1, 0.5, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 3, 2, 0.5, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatSetValue(interpolation, 4, 2, 1.0, INSERT_VALUES);
CHKERRQ(ierr);
ierr = MatAssemblyBegin(interpolation, MAT_FINAL_ASSEMBLY);
CHKERRQ(ierr);
ierr = MatAssemblyEnd(interpolation, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
TS ts;
ierr = TSCreate(PETSC_COMM_SELF, &ts); CHKERRQ(ierr);
ierr = TSSetProblemType(ts, TS_LINEAR); CHKERRQ(ierr);
ierr = TSSetType(ts, TSBEULER);
ierr = TSSetInitialTimeStep(ts, 0.0, 0.1); CHKERRQ(ierr);
ierr = TSSetSolution(ts, x); CHKERRQ(ierr);
ierr = TSSetIFunction(ts, 0, TSComputeIFunctionLinear, 0);
CHKERRQ(ierr);
ierr = TSSetIJacobian(ts, Id, Id, TSComputeIJacobianConstant, 0);
CHKERRQ(ierr);
KSP ksp;
ierr = TSGetKSP(ts, &ksp); CHKERRQ(ierr);
PC pc;
ierr = KSPGetPC(ksp, &pc); CHKERRQ(ierr);
ierr = PCSetType(pc, PCMG); CHKERRQ(ierr);
ierr = PCMGSetLevels(pc, 2, 0); CHKERRQ(ierr);
ierr = PCMGSetInterpolation(pc, 1, interpolation); CHKERRQ(ierr);
ierr = PCMGSetGalerkin(pc, PETSC_TRUE); CHKERRQ(ierr);
ierr = TSSetFromOptions(ts); CHKERRQ(ierr);
ierr = TSSetUp(ts); CHKERRQ(ierr);
ierr = TSStep(ts); CHKERRQ(ierr);
ierr = TSDestroy(&ts); CHKERRQ(ierr);
ierr = MatDestroy(&interpolation); CHKERRQ(ierr);
ierr = VecDestroy(&x); CHKERRQ(ierr);
ierr = MatDestroy(&Id); CHKERRQ(ierr);
ierr = PetscFinalize(); CHKERRQ(ierr);
return 0;
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140402/924dec7f/attachment-0001.pgp>
