[petsc-users] Building the same petsc matrix with different numprocs gives different results!
Jed Brown
jedbrown at mcs.anl.gov
Tue Sep 24 03:12:06 CDT 2013
Analabha Roy <hariseldon99 at gmail.com> writes:
> Hi all,
> Compiling and running this
> code<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c>that
> builds a petsc matrix gives different results when run with different
> number of processors.
Uh, if you call rand() on different processors, why would you expect it
to give the same results?
for (sitestride1 = Istart; sitestride1 < Iend; sitestride1++)
for (sitestride2 = 0; sitestride2 < matsize; sitestride2++)
for (alpha = 0; alpha < dim; alpha++)
for (mu = 0; mu < dim; mu++)
for (lambda = 0; lambda < dim; lambda++)
vecval = rand () / rand ();
VecSetValue (BDB_AA, alpha, vecval, INSERT_VALUES);
VecAssemblyBegin (BDB_AA);
VecAssemblyEnd (BDB_AA);
VecSum (BDB_AA, &element);
colvalues[sitestride2] = element;
//Insert the array of colvalues to the sitestride1^th row of H
MatSetValues (AVG_BDIBJ, 1, &sitestride1, matsize, idx, colvalues,
INSERT_VALUES);
> The code is large and complex, so I have created a smaller program
> with the same
> loop structure here. <http://pastebin.ca/2457643>
> Compile it and run it with "mpirun -np $N ./test -draw_pause -1" gives
> different results for different values of N even though it's not supposed
> to.
What do you expect to see?
> Here is a sample output <http://i42.tinypic.com/2s16ccw.jpg> for N=1,2,3,4
> from left to right.
> Can anyone guide me as to what I'm doing wrong? Are any of the petssc
> routines used not parallelizable?
> Thanks in advance,
> Regards.
> *Analabha Roy*
> C.S.I.R <http://www.csir.res.in> Senior Research
> Associate<http://csirhrdg.res.in/poolsra.htm>
> Saha Institute of Nuclear Physics <http://www.saha.ac.in>
> Section 1, Block AF
> Bidhannagar, Calcutta 700064
> India
> *Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
> *Webpage*: http://www.ph.utexas.edu/~daneel/
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130924/7fc7efc5/attachment-0001.pgp>
