[petsc-users] [petsc-dev] MatCreateDense
Matthew Knepley
knepley at gmail.com
Thu Oct 31 21:48:59 CDT 2013
On Thu, Oct 31, 2013 at 8:41 PM, Jose David Bermeol <jbermeol at purdue.edu>wrote:
> For instance I have a matrix of 400x8 and I want to split it in two mpi
> process, one with the first 100 rows and the second one with the next 300
> rows.
1) Its not necessary to mail users and dev
2) You prescribed the range space, (100, 300), now you can prescribe the
domain by dividing the columns. It not usually important
Matt
> From: "Jose David Bermeol" <jbermeol at purdue.edu>
> To: "Matthew Knepley" <knepley at gmail.com>
> Cc: "petsc-users" <petsc-users at mcs.anl.gov>, "petsc-dev" <
> petsc-dev at mcs.anl.gov>
> Sent: Thursday, October 31, 2013 9:38:43 PM
> Subject: Re: [petsc-dev] MatCreateDense
> What do you mean with number of local columns??
> Thanks
> From: "Matthew Knepley" <knepley at gmail.com>
> To: "Jose David Bermeol" <jbermeol at purdue.edu>
> Cc: "petsc-dev" <petsc-dev at mcs.anl.gov>, "petsc-users" <
> Sent: Thursday, October 31, 2013 2:37:43 PM
> On Thu, Oct 31, 2013 at 1:21 PM, Jose David Bermeol < jbermeol at purdue.edu> wrote:
> Hi small question. In the method MatCreateSeqDense(MPI_Comm comm,PetscInt
> m,PetscInt n,PetscScalar *data,Mat *A) I'm giving the local number of rows
> and columns, so I should pass the total number of local columns or I should
> pass columns/number_of_MPI process.
> If its sequential, you pass the total number of columns. If its
> MatCreateMPIDense(), pass the number of local columns. This
> is used to create a vector with the same layout as y = A^T x.
> Matt
> Thanks
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131031/20bd99ed/attachment.html>
