[petsc-users] Use parallel PETSc linear solver in a sequential	program
    Qin Lu
    lu_qin_2000 at yahoo.com
    Thu Oct 31 15:46:07 CDT 2013
Jed,
Thanks a lot for your nice suggestions. The CRS matrix has already been created by the program and I don't want to change that, do you mean I should read the arrays (i, j, a) and set coefficients row by row using MatSetValues? Will it be much slower than passing the arrays directly to MatCreateSeqAIJWithArrays or MatCreateMPIAIJWithArrays, especially when the matrix is big?
Qin
On Thursday, October 31, 2013 3:07 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
Qin Lu <lu_qin_2000 at yahoo.com> writes:
> Hello,
> I have successfully installed a sequential PETSc's linear solver in a sequential program. The matrix has been created in CSR format and it was passed to  MatCreateSeqAIJWithArrays (instead of using MatSetValues).
> Now I want to use a parallel PETSc solver in the same sequential program, and use the same CRS matrix mentioned above. I intend to use MatCreateMPIAIJWithArrays, since I hope to pass the array direct to PETSc, instead of using MatSetValues. There a few questions:
Use MatSetValues.  It uses less memory and is more flexible.
> 1. Is there a sample code for using MatCreateMPIAIJWithArrays?
Please don't use this function.  It only exists to support legacy users
that were already using it.  The implementation calls MatSetValues
because the input format is not suitable to actually compute with.
> 2. There seems to be a subroutine MatDistribute_MPIAIJ, but it is not
> in the PETSc manual. Where can I get the instruction how to use it? It
> would be nice if there is a sample code available.
That is a private function.  Use MatSetValues.
> 3. Manual says the matrix will be copied by MatCreateMPIAIJWithArrays
> into internal format (while it is not when using
> MatCreateSeqAIJWithArrays), does this mean I have to call
> MatMPIAIJSetPreallocation first?
Not if you call MatCreateMPIAIJWithArrays, but to avoid using the extra
memory (and to simplify your code), you should compute preallocation and
then call MatSetValues once per row, per element, or whatever.
> 4. In sample code ex2.c in the manual, both MatMPIAIJSetPreallocation
> and MatSeqAIJSetPreallocation are called to preallocate the matrix
> A. Is not the first subroutine sufficient?
The example can run in serial or parallel.  Only the matching
preallocation is used, any others will be ignored.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131031/8cfb514f/attachment-0001.html>
