[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Matthew Knepley
knepley at gmail.com
Thu Oct 31 13:43:05 CDT 2013
On Thu, Oct 31, 2013 at 1:25 PM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> I did not call DMCreateMatrix() before when using just dmda (and it is
> working). In any case, I added a call to DMCreateMatrix() now but still
> there are problems. Here are the code snippets and the error I get:
Then you were allowing it to be called automatically by PETSc, and it would
have been this time as well.
> //Setting up the section and linking it to DM:
> ierr = PetscSectionCreate(PETSC_COMM_WORLD, &s);CHKERRQ(ierr);
> ierr = DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);CHKERRQ(ierr);
> ierr = PetscSectionSetChart(s, 0, nC);CHKERRQ(ierr);
> for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
> for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
> PetscInt point;
> if(isPosInDomain(&testPoisson,i,j,0)) {
> ierr = DMDAGetCellPoint(dm, i, j, 0, &point);CHKERRQ(ierr);
> ierr = PetscSectionSetDof(s, point, testPoisson.mDof); //
> No. of dofs associated with the point.
> ierr = PetscSectionSetUp(s);CHKERRQ(ierr);
> ierr = DMSetDefaultSection(dm, s);CHKERRQ(ierr);
> ierr = PetscSectionDestroy(&s);CHKERRQ(ierr);
> ierr = DMCreateMatrix(dm,&A);CHKERRQ(ierr);
> //Set up KSP:
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
> ierr = KSPSetDM(ksp,dm);CHKERRQ(ierr);
> ierr =
> KSPSetComputeOperators(ksp,computeMatrix2dSection,(void*)&testPoisson);CHKERRQ(ierr);
> ierr =
> KSPSetComputeRHS(ksp,computeRhs2dSection,(void*)&testPoisson);CHKERRQ(ierr);
> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
> The computeMatrix2dSection function has:
> ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
> ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
> ierr = DMGetDefaultGlobalSection(da,&gs);CHKERRQ(ierr);
> for(PetscInt j = info.ys; j<info.ys+info.ym; ++j) {
> for(PetscInt i = info.xs; i<info.xs+info.xm; ++i) {
> if (isPosInDomain(ctx,i,j)) {
> ierr = DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
> ierr = PetscSectionGetOffset(gs,point,&row);
> ierr = PetscSectionGetDof(gs,point,&dof);
> for(PetscInt cDof = 0; cDof < dof; ++cDof) {
> num = 0;
> row+=cDof;
> col[num] = row; //(i,j) position
> v[num++] = -4;
> if(isPosInDomain(ctx,i+1,j)) {
> ierr =
> DMDAGetCellPoint(da,i+1,j,0,&point);CHKERRQ(ierr);
> ierr = PetscSectionGetOffset(gs,point,&col[num]);
> col[num] += cDof;
> v[num++] = 1;
> if(isPosInDomain(ctx,i-1,j)) {
> ierr =
> DMDAGetCellPoint(da,i-1,j,0,&point);CHKERRQ(ierr);
> col[num] += cDof;
> v[num++] = 1;
> if(isPosInDomain(ctx,i,j+1)) {
> ierr =
> DMDAGetCellPoint(da,i,j+1,0,&point);CHKERRQ(ierr);
> col[num] += cDof;
> v[num++] = 1;
> if(isPosInDomain(ctx,i,j-1)) {
> ierr =
> DMDAGetCellPoint(da,i,j-1,0,&point);CHKERRQ(ierr);
> col[num] += cDof;
> v[num++] = 1;
> ierr =
> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> But this is not working. For e.g. for a 6X6 grid size I get the following
> error:
Okay, here is how to debug this:
0) Go to a single scalar equations to make things easier
1) Use MatView(A, PETSC_VIEWER_STDOUT_WORLD), which should output a 36
row matrix with
the preallocated nonzero pattern, filled with zeros
2) Make sure this is the pattern you want
3) Run in the debugger with -start_in_debugger
4) When you get the error, see
a) If the (i, j) is one that should be setting a value
b) Why this (i, j) was not preallocated
Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range!
> [0]PETSC ERROR: New nonzero at (0,6) caused a malloc!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development GIT revision:
> 61e5e40bb2c5bf2423e94b71a15fef47e411b0da GIT Date: 2013-10-25 21:47:45
> -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: build/poissonIrregular on a arch-linux2-cxx-debug named
> edwards by bkhanal Thu Oct 31 19:23:58 2013
> [0]PETSC ERROR: Libraries linked from
> /home/bkhanal/Documents/softwares/petsc/arch-linux2-cxx-debug/lib
> [0]PETSC ERROR: Configure run at Sat Oct 26 16:35:15 2013
> [0]PETSC ERROR: Configure options --download-mpich
> -download-f-blas-lapack=1 --download-metis --download-parmetis
> --download-superlu_dist --download-scalapack --download-mumps
> --download-hypre --with-clanguage=cxx
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 413 in
> src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: MatSetValues() line 1130 in src/mat/interface/matrix.c
> [0]PETSC ERROR: computeMatrix2dSection() line 318 in
> /user/bkhanal/home/works/poissonIrregular/poissonIrregular.cxx
> [0]PETSC ERROR: KSPSetUp() line 228 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: KSPSolve() line 399 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: main() line 598 in
> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
> [unset]: aborting job:
>> Matt
>>> However, now since I do not want the rows in the matrix corresponding to
>>> the points in the grid which do not lie in the computational domain. This
>>> means the size of the matrix will not necessarily equal the total number of
>>> cells in DMDA. So in the following code:
>>> ierr = DMDAGetLocalInfo(dm,&info);CHKERRQ(ierr);
>>> PetscInt point;
>>> // No. of dofs associated with the point.
>>> should I myself compute proper nC (i.e. total no. of points for which I
>>> want the matrix to have a corresponding row) before calling
>>> PetscSectionSetChart() or is the masking out of the points inside the loop
>>> with if(isPosInDomain(&testPoisson,i,j,0)) sufficient ?
>>> And, when you write:
>>> PetscSectionGetOffset(gs, p, &ind);
>>> row = ind < 0 ? -(ind+1) : ind;
>>> it seems you allow the possibility of getting a -ve ind when using
>>> PetscSectionGetOffset. When would an offset to a particular dof and point?
>>>>> num = 0;
>>>>> /*ierr =
>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);*/ /*Get the PetscPoint*/
>>>>> /*But I did now understand how I would emulate the
>>>>> row.c and col.c info with PetscSection*/
>>>>> row.i = i; row.j = j;
>>>> Here you would call
>>>> ierr = DMDAGetCellPoint(da, i, j, 0, &cell);CHKERRQ(ierr);
>>>> ierr = PetscSectionGetOffset(da, cell, &row);CHKERRQ(ierr);
>>>> ierr = PetscSectionGetDof(da, cell, &dof);CHKERRQ(ierr);
>>>> This means that this cell has global rows = [row, row+dof).
>>>>> col[num].i = i; col[num].j = j;
>>>>> if (isPosInDomain(ctx,i,j)) { /*put the operator
>>>>> for only the values for only the points lying in the domain*/
>>>>> v[num++] = -4;
>>>>> col[num].i = i+1; col[num].j = j;
>>>>> v[num++] = 1;
>>>>> col[num].i = i-1; col[num].j = j;
>>>>> v[num++] = 1;
>>>>> col[num].i = i; col[num].j = j+1;
>>>>> v[num++] = 1;
>>>>> col[num].i = i; col[num].j = j-1;
>>>>> v[num++] = 1;
>>>>> } else {
>>>>> v[num++] = dScale; /*set Dirichlet identity rows
>>>>> for points in the rectangle but outside the computational domain*/
>>>> You do the same thing for the columns, and then call
>>>> ierr = MatSetValues(A, dof, rows, num*dof, cols, v,
>>>>> ierr =
>>>>> MatSetValuesStencil(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>> Thanks,
>>>>>> Matt
>>>>>>>> Matt
>>>>>>>>>> Matt
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Matt
>>>>>>>>>>>>>> If not, just put the identity into
>>>>>>>>>>>>>>>> the rows you do not use on the full cube. It will not hurt
>>>>>>>>>>>>>>>> scalability or convergence.
>>>>>>>>>>>>>>> In the case of Poisson with Dirichlet condition this might
>>>>>>>>>>>>>>> be the case. But is it always true that having identity rows in the system
>>>>>>>>>>>>>>> matrix will not hurt convergence ? I thought otherwise for the following
>>>>>>>>>>>>>>> reasons:
>>>>>>>>>>>>>>> 1) Having read Jed's answer here :
>>>>>>>>>>>>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>>>>>>>>>>>>> Jed is talking about a constraint on a the pressure at a
>>>>>>>>>>>>>> point. This is just decoupling these unknowns from the rest
>>>>>>>>>>>>>> of the problem.
>>>>>>>>>>>>>>> 2) Some observation I am getting (but I am still doing more
>>>>>>>>>>>>>>> experiments to confirm) while solving my staggered-grid 3D stokes flow with
>>>>>>>>>>>>>>> schur complement and using -pc_type gamg for A00 matrix. Putting the
>>>>>>>>>>>>>>> identity rows for dirichlet boundaries and for ghost cells seemed to have
>>>>>>>>>>>>>>> effects on its convergence. I'm hoping once I know how to use PetscSection,
>>>>>>>>>>>>>>> I can get rid of using ghost cells method for the staggered grid and get
>>>>>>>>>>>>>>> rid of the identity rows too.
>>>>>>>>>>>>>> It can change the exact iteration, but it does not make the
>>>>>>>>>>>>>> matrix conditioning worse.
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>> Anyway please provide me with some pointers so that I can
>>>>>>>>>>>>>>> start trying with petscsection on top of a dmda, in the beginning for
>>>>>>>>>>>>>>> non-staggered case.
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131031/cb57b64d/attachment-0001.html>
