[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Thu Oct 31 12:13:07 CDT 2013
On Thu, Oct 31, 2013 at 12:02 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
> On Tue, Oct 29, 2013 at 5:37 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Oct 29, 2013 at 5:31 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Mon, Oct 28, 2013 at 9:00 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Mon, Oct 28, 2013 at 2:51 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Mon, Oct 28, 2013 at 6:19 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Mon, Oct 28, 2013 at 10:13 AM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>> > wrote:
>>>>>>> On Mon, Oct 28, 2013 at 3:49 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Mon, Oct 28, 2013 at 9:06 AM, Bishesh Khanal <
>>>>>>>> bisheshkh at gmail.com> wrote:
>>>>>>>>> On Mon, Oct 28, 2013 at 1:40 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Mon, Oct 28, 2013 at 5:30 AM, Bishesh Khanal <
>>>>>>>>>>>  On Fri, Oct 25, 2013 at 10:21 PM, Matthew Knepley <
>>>>>>>>>>>> On Fri, Oct 25, 2013 at 2:55 PM, Bishesh Khanal <
>>>>>>>>>>>>> On Fri, Oct 25, 2013 at 8:18 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Fri, Oct 25, 2013 at 12:09 PM, Bishesh Khanal <
>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>> I would like to know if some of the petsc objects that I
>>>>>>>>>>>>>>> have not used so far (IS, DMPlex, PetscSection) could be useful in the
>>>>>>>>>>>>>>> following case (of irregular domains):
>>>>>>>>>>>>>>> Let's say that I have a 3D binary image (a cube).
>>>>>>>>>>>>>>> The binary information of the image partitions the cube into
>>>>>>>>>>>>>>> a computational domain and non-computational domain.
>>>>>>>>>>>>>>> I must solve a pde (say a Poisson equation) only on the
>>>>>>>>>>>>>>> computational domains (e.g: two isolated spheres within the cube). I'm
>>>>>>>>>>>>>>> using finite difference and say a dirichlet boundary condition
>>>>>>>>>>>>>>> I know that I can create a dmda that will let me access the
>>>>>>>>>>>>>>> information from this 3D binary image, get all the coefficients, rhs values
>>>>>>>>>>>>>>> etc using the natural indexing (i,j,k).
>>>>>>>>>>>>>>> Now, I would like to create a matrix corresponding to the
>>>>>>>>>>>>>>> laplace operator (e.g. with standard 7 pt. stencil), and the corresponding
>>>>>>>>>>>>>>> RHS that takes care of the dirchlet values too.
>>>>>>>>>>>>>>> But in this matrix it should have the rows corresponding to
>>>>>>>>>>>>>>> the nodes only on the computational domain. It would be nice if I can
>>>>>>>>>>>>>>> easily (using (i,j,k) indexing) put on the rhs dirichlet values
>>>>>>>>>>>>>>> corresponding to the boundary points.
>>>>>>>>>>>>>>> Then, once the system is solved, put the values of the
>>>>>>>>>>>>>>> solution back to the corresponding positions in the binary image.
>>>>>>>>>>>>>>> Later, I might have to extend this for the staggered grid
>>>>>>>>>>>>>>> case too.
>>>>>>>>>>>>>>> So is petscsection or dmplex suitable for this so that I can
>>>>>>>>>>>>>>> set up the matrix with something like DMCreateMatrix ? Or what would you
>>>>>>>>>>>>>>> suggest as a suitable approach to this problem ?
>>>>>>>>>>>>>>> I have looked at the manual and that led me to search for a
>>>>>>>>>>>>>>> simpler examples in petsc src directories. But most of the ones I
>>>>>>>>>>>>>>> encountered are with FEM (and I'm not familiar at all with FEM, so these
>>>>>>>>>>>>>>> examples serve more as a distraction with FEM jargon!)
>>>>>>>>>>>>>> It sounds like the right solution for this is to use
>>>>>>>>>>>>>> PetscSection on top of DMDA. I am working on this, but it is really
>>>>>>>>>>>>>> alpha code. If you feel comfortable with that level of
>>>>>>>>>>>>>> development, we can help you.
>>>>>>>>>>>>> Thanks, with the (short) experience of using Petsc so far and
>>>>>>>>>>>>> being familiar with the awesomeness (quick and helpful replies) of this
>>>>>>>>>>>>> mailing list, I would like to give it a try. Please give me some pointers
>>>>>>>>>>>>> to get going for the example case I mentioned above. A simple example of
>>>>>>>>>>>>> using PetscSection along with DMDA for finite volume (No FEM) would be
>>>>>>>>>>>>> great I think.
>>>>>>>>>>>>> Just a note: I'm currently using the petsc3.4.3 and have not
>>>>>>>>>>>>> used the development version before.
>>>>>>>>>>>> Okay,
>>>>>>>>>>>> 1)  clone the repository using Git and build the 'next' branch.
>>>>>>>>>>>> 2) then we will need to create a PetscSection that puts
>>>>>>>>>>>> unknowns where you want them
>>>>>>>>>>>> 3) Setup the solver as usual
>>>>>>>>>>>> You can do 1) an 3) before we do 2).
>>>>>>>>>>>> I've done 1) and 3). I have one .cxx file that solves the
>>>>>>>>>>> system using DMDA (putting identity into the rows corresponding to the
>>>>>>>>>>> cells that are not used).
>>>>>>>>>>> Please let me know what I should do now.
>>>>>>>>>> Okay, now write a loop to setup the PetscSection. I have the DMDA
>>>>>>>>>> partitioning cells, so you would have
>>>>>>>>>> unknowns in cells. The code should look like this:
>>>>>>>>>> PetscSectionCreate(comm, &s);
>>>>>>>>>> DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);
>>>>>>>>>> PetscSectionSetChart(s, 0, nC);
>>>>>>>>>> for (k = zs; k < zs+zm; ++k) {
>>>>>>>>>>   for (j = ys; j < ys+ym; ++j) {
>>>>>>>>>>     for (i = xs; i < xs+xm; ++i) {
>>>>>>>>>>       PetscInt point;
>>>>>>>>>>       DMDAGetCellPoint(dm, i, j, k, &point);
>>>>>>>>>>       PetscSectionSetDof(s, point, dof); // You know how many dof
>>>>>>>>>> are on each vertex
>>>>>>>>>> PetscSectionSetUp(s);
>>>>>>>>>> DMSetDefaultSection(dm, s);
>>>>>>>>>> PetscSectionDestroy(&s);
>>>>>>>>>> I will merge the necessary stuff into 'next' to make this work.
>>>>>>>>> I have put an example without the PetscSection here:
>>>>>>>>> https://github.com/bishesh/petscPoissonIrregular/blob/master/poissonIrregular.cxx
>>>>>>>>> From the code you have written above, how do we let PetscSection
>>>>>>>>> select only those cells that lie in the computational domain ?  Is it that
>>>>>>>>> for every "point" inside the above loop, we check whether it lies in the
>>>>>>>>> domain or not, e.g using the function isPosInDomain(...) in the .cxx file I
>>>>>>>>> linked to?
>>>>>>>> 1) Give me permission to comment on the source (I am 'knepley')
>>>>>>>> 2) You mask out the (i,j,k) that you do not want in that loop
>>>>>>> Done.
>>>>>>> I mask it out using isPosInDomain() function::
>>>>>>>        if(isPosInDomain(&testPoisson,i,j,k)) {
>>>>>>>             ierr = DMDAGetCellPoint(dm, i, j, k, &point);CHKERRQ(
>>>>>>> ierr);
>>>>>>>             ierr = PetscSectionSetDof(s, point, testPoisson.mDof); //
>>>>>>> You know how many dof are on each vertex
>>>>>>> And please let me know when I can rebuild the 'next' branch of petsc
>>>>>>> so that DMDAGetCellPoint can be used. Currently compiler complains as it
>>>>>>> cannot find it.
>>>>>> Pushed.
>>>>> Pulled it thanks, but compiler was complaining that it didn't find
>>>>> DMDAGetCellPoint.
>>>>> Doing grep -R 'DMDAGetCellPoint' include/
>>>>> returned nothing although the implementation is there in dalocal.c
>>>>> So I added the declaration to petscdmda.h file just above the
>>>>> declaration of DMDAGetNumCells.
>>>> I will add the declaration.
>>>>>  I have also added you as a collaborator in the github project
>>>>> repository so that you can edit and add comments to the file I linked
>>>>> above. My computeMatrix still uses the DMDA instead of the PetscSection, so
>>>>> is it where the changes need to be made ?
>>>> Instead of MatSetValuesStencil(), you would go back to using
>>>> MatSetValues(), and calculate the indices using PetscSection.
>>>> You get the section
>>>>   DMGetDefaultGlobalSection(dm, &gs)
>>>> and then
>>>>   DMDAGetCellPoint(dm, i, j, k, &p);
>>>>   PetscSectionGetOffset(gs, p, &ind);
>>>>   row = ind < 0 ? -(ind+1) : ind;
>>> I'm sorry but did not understood. For e.g., in 2D, for each point p, I
>>> have 2 dof. Does PetsSectionGetOffset give me the two offsets for the dof
>>> sth like ind[0] = 0 and ind[1] = 1 ?
>>> How would you change the following code that sets 2D laplacian stencil
>>> for 2 dof to use petscsection and Matsetvalues instead ?
>> Forget about multiple degrees of freedom until your scalar problem works.
>>>  ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
>>>     ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
>>>     ierr = DMGetDefaultGlobalSection(dm,&gs);CHKERRQ(ierr); /*Here I get
>>> the PetscSection*/
>>>     for(PetscInt dof = 0; dof < 2; ++dof) {
>>>         row.c = dof;
>>>         for(PetscInt k = 0; k < 5; ++k) {
>>>             col[k].c = dof;
>> I can't imagine that this is what you want. You have two non-interacting
>> problems.
> I just wanted a very basic example to use PetscSection with multiple dofs.
> In this example I'm solving Lap(u) = f where Lap is a component wise
> laplacian and u is a vector. So if I want to apply the Lap component-wise
> independently I could solve a system thrice for fx, fy and fz; but here
> just to demonstrate, I wanted to have all fx, fy and fz line up in a single
> vector.
> I did as you suggeted to write the values in the matrix, thanks. But now
> is there a way to let Petsc know automatically the size of the matrix it
> needs to create for the linear system based on the PetsSection I created?
> When I used only DMDA without Petscsection, this was possible, so I could
> just use:
>     ierr = KSPSetDM(ksp,dm);CHKERRQ(ierr);
>     ierr =
> KSPSetComputeOperators(ksp,computeMatrix2d,(void*)&testPoisson);CHKERRQ(ierr);
>     ierr =
> KSPSetComputeRHS(ksp,computeRhs2d,(void*)&testPoisson);CHKERRQ(ierr);
> where in my computeMatrix2d function I would set the non-zero values in
> the matrix.
DMCreateMatrix(), just as before.
   Matt
> However, now since I do not want the rows in the matrix corresponding to
> the points in the grid which do not lie in the computational domain. This
> means the size of the matrix will not necessarily equal the total number of
> cells in DMDA. So in the following code:
>  ierr = DMDAGetLocalInfo(dm,&info);CHKERRQ(ierr);
>     ierr = PetscSectionCreate(PETSC_COMM_WORLD, &s);CHKERRQ(ierr);
>     ierr = DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);CHKERRQ(ierr);
>     ierr = PetscSectionSetChart(s, 0, nC);CHKERRQ(ierr);
>     for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
>         for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
>             PetscInt point;
>             if(isPosInDomain(&testPoisson,i,j,0)) {
>                 ierr = DMDAGetCellPoint(dm, i, j, 0, &point);CHKERRQ(ierr);
> No. of dofs associated with the point.
>     ierr = PetscSectionSetUp(s);CHKERRQ(ierr);
>     ierr = DMSetDefaultSection(dm, s);CHKERRQ(ierr);
>     ierr = PetscSectionDestroy(&s);CHKERRQ(ierr);
> should I myself compute proper nC (i.e. total no. of points for which I
> want the matrix to have a corresponding row) before calling
> PetscSectionSetChart() or is the masking out of the points inside the loop
> with if(isPosInDomain(&testPoisson,i,j,0)) sufficient ?
> And, when you write:
> it seems you allow the possibility of getting a -ve ind when using
> PetscSectionGetOffset. When would an offset to a particular dof and point?
>>>         for(PetscInt j = info.ys; j<info.ys+info.ym; ++j) {
>>>             for(PetscInt i = info.xs; i<info.xs+info.xm; ++i) {
>>>                 num = 0;
>>>                 /*ierr =
>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);*/ /*Get the PetscPoint*/
>>>                 /*But I did now understand how I would emulate the row.c
>>> and col.c info with PetscSection*/
>>>                 row.i = i;  row.j = j;
>> Here you would call
>>    ierr = DMDAGetCellPoint(da, i, j, 0, &cell);CHKERRQ(ierr);
>>    ierr = PetscSectionGetOffset(da, cell, &row);CHKERRQ(ierr);
>>    ierr = PetscSectionGetDof(da, cell, &dof);CHKERRQ(ierr);
>> This means that this cell has global rows = [row, row+dof).
>>>                  col[num].i = i; col[num].j = j;
>>>                 if (isPosInDomain(ctx,i,j)) {      /*put the operator
>>> for only the values for only the points lying in the domain*/
>>>                     v[num++] = -4;
>>>                     if(isPosInDomain(ctx,i+1,j)) {
>>>                         col[num].i = i+1;   col[num].j = j;
>>>                         v[num++] = 1;
>>>                     if(isPosInDomain(ctx,i-1,j)) {
>>>                         col[num].i = i-1;   col[num].j = j;
>>>                         v[num++] = 1;
>>>                     if(isPosInDomain(ctx,i,j+1)) {
>>>                         col[num].i = i;     col[num].j = j+1;
>>>                         v[num++] = 1;
>>>                     if(isPosInDomain(ctx,i,j-1)) {
>>>                         col[num].i = i;     col[num].j = j-1;
>>>                         v[num++] = 1;
>>>                 } else {
>>>                     v[num++] = dScale;  /*set Dirichlet identity rows
>>> for points in the rectangle but outside the computational domain*/
>> You do the same thing for the columns, and then call
>>   ierr = MatSetValues(A, dof, rows, num*dof, cols, v,
>> INSERT_VALUES);CHKERRQ(ierr);
>>>                 ierr =
>>> MatSetValuesStencil(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>     Thanks,
>>>>      Matt
>>>>>>    Matt
>>>>>>>>    Matt
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>>>  If not, just put the identity into
>>>>>>>>>>>>>> the rows you do not use on the full cube. It will not hurt
>>>>>>>>>>>>>> scalability or convergence.
>>>>>>>>>>>>> In the case of Poisson with Dirichlet condition this might be
>>>>>>>>>>>>> the case. But is it always true that having identity rows in the system
>>>>>>>>>>>>> matrix will not hurt convergence ? I thought otherwise for the following
>>>>>>>>>>>>> reasons:
>>>>>>>>>>>>> 1)  Having read Jed's answer here :
>>>>>>>>>>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>>>>>>>>>>> Jed is talking about a constraint on a the pressure at a point.
>>>>>>>>>>>> This is just decoupling these unknowns from the rest
>>>>>>>>>>>> of the problem.
>>>>>>>>>>>>> 2) Some observation I am getting (but I am still doing more
>>>>>>>>>>>>> experiments to confirm) while solving my staggered-grid 3D stokes flow with
>>>>>>>>>>>>> schur complement and using -pc_type gamg for A00 matrix. Putting the
>>>>>>>>>>>>> identity rows for dirichlet boundaries and for ghost cells seemed to have
>>>>>>>>>>>>> effects on its convergence. I'm hoping once I know how to use PetscSection,
>>>>>>>>>>>>> I can get rid of using ghost cells method for the staggered grid and get
>>>>>>>>>>>>> rid of the identity rows too.
>>>>>>>>>>>> It can change the exact iteration, but it does not make the
>>>>>>>>>>>> matrix conditioning worse.
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>  Anyway please provide me with some pointers so that I can
>>>>>>>>>>>>> start trying with petscsection on top of a dmda, in the beginning for
>>>>>>>>>>>>> non-staggered case.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131031/01b7d425/attachment-0001.html>
