[petsc-users] DMPlexCreateFromCellList and hybrid meshes
Cedric Doucet
cedric.doucet at inria.fr
Thu Oct 31 05:20:22 CDT 2013
Thank you very much for your help.
Do you plan to add this code to Petsc?
It would be better for us to call an official Petsc function than maintaining a Petsc-style code into our C++ software.
Best regards,
Cédric Doucet
----- Mail original -----
> De: "Matthew Knepley" <knepley at gmail.com>
> À: "Cedric Doucet" <cedric.doucet at inria.fr>
> Cc: petsc-users at mcs.anl.gov
> Envoyé: Mardi 29 Octobre 2013 17:24:03
> Objet: Re: [petsc-users] DMPlexCreateFromCellList and hybrid meshes
> On Tue, Oct 29, 2013 at 10:24 AM, Cedric Doucet <
> cedric.doucet at inria.fr > wrote:
> > Hello,
> > I have a short question about the code I need to modify.
> > As far as I understand, numCorner should be replaced by an array
> > numCorners[numCells] containing the number of vertices of each
> > cell.
> > The body of DMPlexBuildFromCellList_Private function becomes
> > ierr = DMPlexSetChart(dm, 0, numCells+numVertices);CHKERRQ(ierr);
> maxCorners = 0;
> > for (c = 0; c < numCells; ++c) {
> > ierr = DMPlexSetConeSize(dm, c, numCorners[c]);CHKERRQ(ierr);
> maxCorners = PetscMax(maxCorners, numCorners[c]);
> > ierr = DMSetUp(dm);CHKERRQ(ierr);
> ierr = DMGetWorkArray(dm, maxCorners, PETSC_INT,
> &cone);CHKERRQ(ierr);
> > for (c = 0, off = 0; c < numCells; ++c) {
> > for (p = 0; p < numCorners[c]; ++p) {
> > cone[p] = cells[off+p]+numCells;
> > ierr = DMPlexSetCone(dm, c, cone);CHKERRQ(ierr);
> off += numCorners[c];
> ierr = DMRestoreWorkArray(dm, maxCorners, PETSC_INT,
> > ierr = DMPlexSymmetrize(dm);CHKERRQ(ierr);
> > ierr = DMPlexStratify(dm);CHKERRQ(ierr);
> Matt
> > However, I am not quite sure that DMGetWorkArray and
> > DMRestoreWorkArray should be used like this.
> > I guess that DMRestoreWorkArray behaves like free function in ansi
> > c
> > but I am not sure.
> > Do you think that calling DMGetWorkArray and DMRestoreWorkArray
> > inside a loop is a good thing from the point of view of
> > computational time and memory management?
> > Note: the best way to do this may be to first sort cells by
> > numCorners to avoid many calls to DMGetWorkArray and
> > DMRestoreWorkArray. This is actually what I have in my own code but
> > I would like to maintain Petsc's philosophy.
> > Thanks,
> > Cédric
> > > De: "Matthew Knepley" < knepley at gmail.com >
> > > À: "Cedric Doucet" < cedric.doucet at inria.fr >
> > > Envoyé: Vendredi 25 Octobre 2013 16:31:59
> > > meshes
> > > On Fri, Oct 25, 2013 at 7:23 AM, Cedric Doucet <
> > > > Hello,
> > > > I've noticed that DMPlexCreateFromCellList assumes that cells
> > > > have
> > > > the same number of vertices (numcorners argument).
> > > > What should be done when one wants to create a DMPlex from a
> > > > mesh
> > > > containing different types of cells?
> > > > Does one have to create several DMPlex structures and merge
> > > > them?
> > > > Does one have to create a unique DMPlex by hand?
> > > The code is very short:
> > > ierr = DMPlexSetConeSize(dm, c, numCorners);CHKERRQ(ierr);
> > > ierr = DMGetWorkArray(dm, numCorners, PETSC_INT,
> > > for (p = 0; p < numCorners; ++p) {
> > > cone[p] = cells[c*numCorners+p]+numCells;
> > > ierr = DMRestoreWorkArray(dm, numCorners, PETSC_INT,
> > > This code is all in plexcreate.c. If you want different cells,
> > > you
> > > can change numCorners for each cell.
> > > I could make a convenience form if necessary.
> > > Matt
> > > > Cédric
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> > > which
> > > their experiments lead.
> > > -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131031/a01c3963/attachment-0001.html>
