[petsc-users] How to force the code run with a given number of iterations?
Jed Brown
jedbrown at mcs.anl.gov
Wed Oct 30 19:38:54 CDT 2013
Fande Kong <fd.kong at siat.ac.cn> writes:
> Hi all,
> I use the following script to run code, but the code stop after doing
> *two*iterations:
> * mpirun -n 2 ./linearElasticity -ksp_type gmres -pc_type asm
> -pc_asm_overlap 1 -sub_pc_type ilu -sub_pc_factor_levels 2 -sub_ksp_type
> preonly -sub_pc_factor_mat_ordering_type rcm -ksp_view - -ksp_rtol 1e-5
> -ksp_max_it 500 -ksp_monitor -ksp_monitor_singular_value*
> The residual history is listed as follows:
> * 0 KSP Residual norm 9.732477596672e+31
> 0 KSP Residual norm 9.732477596672e+31 % max 1.000000000000e+00 min
> 1.000000000000e+00 max/min 1.000000000000e+00
> 1 KSP Residual norm 8.532845325800e+31
> 1 KSP Residual norm 8.532845325800e+31 % max 4.821161757157e+55 min
> 4.821161757157e+55 max/min 1.000000000000e+00
> 2 KSP Residual norm 3.648279603061e+23
> 2 KSP Residual norm 3.648279603061e+23 % max 1.234581012401e+79 min
> 2.318814661396e+55 max/min 5.324190125905e+23
> The residual is not small enough to stop.
-ksp_converged_reason will tell you why it exited early.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131030/215c647e/attachment-0001.pgp>
