[petsc-users] ILUTP
    Torquil Macdonald Sørensen
    torquil at gmail.com
    Wed Oct 30 08:58:39 CDT 2013
Thanks Matthew!
The problem I'm working on is the Dirac equation, in various number of
dimensions. I'm going to take a stab at multigrid preconditioning.
Best regards
Torquil Sørensen
On 27 October 2013 14:48, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Oct 26, 2013 at 3:05 PM, Torquil Macdonald Sørensen <
> torquil at gmail.com> wrote:
>> Hi!
>> I have a linear problem Ax=b, with complex values, that is solved very
>> well using the ILUTP and GMRES implementations in GMM++. None of the other
>> preconditioners available in GMM++ would work (e.g. ILU and ILUT) for this
>> problem.
>> Then I tried the same problem using ILU and GMRES in PETSc, with no
>> success, despite a lot of attempts at adjusting ILU settings. I always end
>> up with gigantic residual norm values. The same PETSc program works well
>> when I apply it to a different matrix A.
>> I'm now suspecting that the ILU options cannot be set so as to obtain
>> ILUTP behaviour.
>> What would be the recommended method to access an ILUTP preconditioner
>> from PETSc?
>> According to the PETSc website, a preconditioner named ILUDT is available
>> by using the external package Hypre, but I had to deselect Hypre during the
>> PETSc build due to my use of complex numbers... So do you guys think that I
>> should transform everything to a real representation and try Hypre/ILUDT?
> I suggest you look for a different preconditioner. The fact that you have
> so much trouble reproducing the behavior shows
> you just how fragile the performance of ILU is. It may work for a certain
> size, but fail for larger or smaller problems, or slightly
> different parameters. What problem are you solving? Usually the best
> option is to consult the literature for preconditioners
> tailored to your problem, and then reproduce them.
>    Matt
>> Best regards
>> Torquil Sørensen
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131030/e5c784d8/attachment.html>
