[petsc-users] DMPlex example with manual grid layout
Bernhard Reinhardt b.reinhardt at physik.uni-muenchen.de
Mon Oct 28 06:17:00 CDT 2013
Hi there,
I am trying to familiarize myself with unstructured grids. For this I
started with the example given in the petsc-manual (mesh of 2 triangles)
and tried to modify it according to my needs.
However, the example seems to be incomplete. At least I was not able to
create a matrix without applying a DMPlexSetDimension.
In the end I decided to set up an an example as simple as possible:
1D transport of a scalar in a bar with periodic boundaries.
Lets say I have a bar consisting of 3 volumes and 3 faces.
You could write this down as a vector of length 3 containing the scalar
in the volumes and a 3x3 matrix containing the transport coefficients on
the faces.
I have already tried many different ways of setting this up with plex
but always failed. Attached you find the version that makes most sense
to me. It gives me vectors of length 3 and a 3x3 matrix. However, the
matrix contains no writable entries and I think the returned closures
are not correct.
Is there a simple example with good documentation of the individual
steps like in the manual which is complete and working?
Kind regards
Bernhard
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131028/76959009/attachment.bin>
