[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Bishesh Khanal
bisheshkh at gmail.com
Sat Oct 26 08:27:25 CDT 2013
On Sat, Oct 26, 2013 at 2:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Oct 26, 2013 at 3:12 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Fri, Oct 25, 2013 at 10:21 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Oct 25, 2013 at 2:55 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Fri, Oct 25, 2013 at 8:18 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Fri, Oct 25, 2013 at 12:09 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> Dear all,
>>>>>> I would like to know if some of the petsc objects that I have not
>>>>>> used so far (IS, DMPlex, PetscSection) could be useful in the following
>>>>>> case (of irregular domains):
>>>>>> Let's say that I have a 3D binary image (a cube).
>>>>>> The binary information of the image partitions the cube into a
>>>>>> computational domain and non-computational domain.
>>>>>> I must solve a pde (say a Poisson equation) only on the computational
>>>>>> domains (e.g: two isolated spheres within the cube). I'm using finite
>>>>>> difference and say a dirichlet boundary condition
>>>>>> I know that I can create a dmda that will let me access the
>>>>>> information from this 3D binary image, get all the coefficients, rhs values
>>>>>> etc using the natural indexing (i,j,k).
>>>>>> Now, I would like to create a matrix corresponding to the laplace
>>>>>> operator (e.g. with standard 7 pt. stencil), and the corresponding RHS that
>>>>>> takes care of the dirchlet values too.
>>>>>> But in this matrix it should have the rows corresponding to the nodes
>>>>>> only on the computational domain. It would be nice if I can easily (using
>>>>>> (i,j,k) indexing) put on the rhs dirichlet values corresponding to the
>>>>>> boundary points.
>>>>>> Then, once the system is solved, put the values of the solution back
>>>>>> to the corresponding positions in the binary image.
>>>>>> Later, I might have to extend this for the staggered grid case too.
>>>>>> So is petscsection or dmplex suitable for this so that I can set up
>>>>>> the matrix with something like DMCreateMatrix ? Or what would you suggest
>>>>>> as a suitable approach to this problem ?
>>>>>> I have looked at the manual and that led me to search for a simpler
>>>>>> examples in petsc src directories. But most of the ones I encountered are
>>>>>> with FEM (and I'm not familiar at all with FEM, so these examples serve
>>>>>> more as a distraction with FEM jargon!)
>>>>> It sounds like the right solution for this is to use PetscSection on
>>>>> top of DMDA. I am working on this, but it is really
>>>>> alpha code. If you feel comfortable with that level of development, we
>>>>> can help you.
>>>> Thanks, with the (short) experience of using Petsc so far and being
>>>> familiar with the awesomeness (quick and helpful replies) of this mailing
>>>> list, I would like to give it a try. Please give me some pointers to get
>>>> going for the example case I mentioned above. A simple example of using
>>>> PetscSection along with DMDA for finite volume (No FEM) would be great I
>>>> think.
>>>> Just a note: I'm currently using the petsc3.4.3 and have not used the
>>>> development version before.
>>> Okay,
>>> 1) clone the repository using Git and build the 'next' branch.
>> I encountered errors when doing make on the 'next' branch. The errors are
>> as follows (I tried attached the configure.log file but the email bounced
>> back saying it awaits moderator approval for having too big an attachment,
>> so I'm sending this one with only make.log attached. ) :
> They are fixed. Pull again and rebuild.
doing git pull in the next branch says "Already up-to-date.", I'm not sure
if it should have said that then. Still tried ./configure and make again
but returns the same error. Does it take sometime to get updated in the
servers or do I need to do anything special again other than the following
git checkout next
git pull
> Matt
>> CXX arch-linux2-cxx-debug/obj/src/
>> mat/order/ftn-auto/spectralf.o
>> CXX arch-linux2-cxx-debug/obj/src/mat/order/ftn-custom/zsorderf.o
>> src/mat/order/wbm.c: In function ‘PetscErrorCode MatGetOrdering_WBM(Mat,
>> MatOrderingType, _p_IS**, _p_IS**)’:
>> src/mat/order/wbm.c:12:24: warning: variable ‘cntl’ set but not used
>> [-Wunused-but-set-variable]
>> src/mat/order/wbm.c:15:36: warning: unused variable ‘num’
>> [-Wunused-variable]
>> src/mat/order/wbm.c:15:56: warning: variable ‘icntl’ set but not used
>> src/mat/order/wbm.c:15:66: warning: unused variable ‘info’
>> [-Wunused-variable]
>> CXX arch-linux2-cxx-debug/obj/src/mat/matfd/fdmatrix.o
>> src/mat/order/ftn-auto/spectralf.c: In function ‘void
>> matcreatelaplacian_(Mat, PetscReal*, PetscBool*, _p_Mat**, int*)’:
>> src/mat/order/ftn-auto/spectralf.c:44:40: error: ‘MatCreateLaplacian’ was
>> not declared in this scope
>> gmake[2]: ***
>> [arch-linux2-cxx-debug/obj/src/mat/order/ftn-auto/spectralf.o] Error 1
>> gmake[2]: *** Waiting for unfinished jobs....
>> src/mat/order/hslmc64.c: In function ‘PetscErrorCode HSLmc64AD(const
>> PetscInt*, PetscInt*, PetscInt*, PetscInt*, const PetscInt*, const
>> PetscInt*, PetscScalar*, PetscInt*, PetscInt*, PetscInt*, PetscInt*,
>> PetscInt*, PetscScalar*, PetscInt*, PetscScalar*, PetscInt*)’:
>> src/mat/order/hslmc64.c:332:21: warning: variable ‘warn1’ set but not
>> used [-Wunused-but-set-variable]
>> src/mat/order/hslmc64.c:332:28: warning: variable ‘warn2’ set but not
>> src/mat/order/hslmc64.c:332:35: warning: variable ‘warn4’ set but not
>> gmake[2]: Leaving directory `/home/bkhanal/Documents/softwares/petsc'
>> gmake[1]: *** [gnumake] Error 2
>> gmake[1]: Leaving directory `/home/bkhanal/Documents/softwares/petsc'
>> **************************ERROR*************************************
>> Error during compile, check arch-linux2-cxx-debug/conf/make.log
>> Send it and arch-linux2-cxx-debug/conf/configure.log to
>> petsc-maint at mcs.anl.gov
>> make: *** [all] Error 1
>>> 2) then we will need to create a PetscSection that puts unknowns where
>>> you want them
>>> 3) Setup the solver as usual
>>> You can do 1) an 3) before we do 2).
>>> If not, just put the identity into
>>>>> the rows you do not use on the full cube. It will not hurt scalability
>>>>> or convergence.
>>>> In the case of Poisson with Dirichlet condition this might be the case.
>>>> But is it always true that having identity rows in the system matrix will
>>>> not hurt convergence ? I thought otherwise for the following reasons:
>>>> 1) Having read Jed's answer here :
>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>> Jed is talking about a constraint on a the pressure at a point. This is
>>> just decoupling these unknowns from the rest
>>> of the problem.
>>>> 2) Some observation I am getting (but I am still doing more experiments
>>>> to confirm) while solving my staggered-grid 3D stokes flow with schur
>>>> complement and using -pc_type gamg for A00 matrix. Putting the identity
>>>> rows for dirichlet boundaries and for ghost cells seemed to have effects on
>>>> its convergence. I'm hoping once I know how to use PetscSection, I can get
>>>> rid of using ghost cells method for the staggered grid and get rid of the
>>>> identity rows too.
>>> It can change the exact iteration, but it does not make the matrix
>>> conditioning worse.
>>> Matt
>>>> Anyway please provide me with some pointers so that I can start
>>>> trying with petscsection on top of a dmda, in the beginning for
>>>> non-staggered case.
>>>> Thanks,
>>>> Bishesh
>>>>> Matt
>>>>>> Thanks,
>>>>>> Bishesh
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131026/7a97f207/attachment-0001.html>
