[petsc-users] PetscOptionsView() line 692
Mark Adams
mfadams at lbl.gov
Fri Oct 25 17:42:01 CDT 2013
Has this been fixed in latter releases? Would removing -options_left fix
this?
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Only supports ASCII viewer!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./driver2d.Linux.64.mpiCC.mpif90.DEBUG.MPI.PETSC.ex on a
arch-linux-gnu-anag-parallel-opt named loren by dmartin Fri Oct 25 15:20:25
[0]PETSC ERROR: Libraries linked from
/usr/local/anag/pkg/petsc-3.4.0/arch-linux-gnu-anag-parallel-opt/lib
[0]PETSC ERROR: Configure run at Wed May 22 18:57:17 2013
[0]PETSC ERROR: Configure options --with-x=0 --download-hypre=1
--download-parmetis=1 --download-metis=1 --with-debugging=0 --with-mpi=1
PETSC_ARCH=arch-linux-gnu-anag-parallel-opt
[0]PETSC ERROR:
[0]PETSC ERROR: PetscOptionsView() line 692 in
/usr/local/anag/pkg/petsc-3.4.0/src/sys/objects/options.c
[0]PETSC ERROR: PetscFinalize() line 1048 in
/usr/local/anag/pkg/petsc-3.4.0/src/sys/objects/pinit.c
[0]PETSC ERROR: main() line 1141 in "unknowndirectory/"driver.cpp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131025/d97c57f1/attachment.html>
