[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Bishesh Khanal
bisheshkh at gmail.com
Fri Oct 25 12:09:32 CDT 2013
Dear all,
I would like to know if some of the petsc objects that I have not used so
far (IS, DMPlex, PetscSection) could be useful in the following case (of
irregular domains):
Let's say that I have a 3D binary image (a cube).
The binary information of the image partitions the cube into a
computational domain and non-computational domain.
I must solve a pde (say a Poisson equation) only on the computational
domains (e.g: two isolated spheres within the cube). I'm using finite
difference and say a dirichlet boundary condition
I know that I can create a dmda that will let me access the information
from this 3D binary image, get all the coefficients, rhs values etc using
the natural indexing (i,j,k).
Now, I would like to create a matrix corresponding to the laplace operator
(e.g. with standard 7 pt. stencil), and the corresponding RHS that takes
care of the dirchlet values too.
But in this matrix it should have the rows corresponding to the nodes only
on the computational domain. It would be nice if I can easily (using
(i,j,k) indexing) put on the rhs dirichlet values corresponding to the
boundary points.
Then, once the system is solved, put the values of the solution back to the
corresponding positions in the binary image.
Later, I might have to extend this for the staggered grid case too.
So is petscsection or dmplex suitable for this so that I can set up the
matrix with something like DMCreateMatrix ? Or what would you suggest as a
suitable approach to this problem ?
I have looked at the manual and that led me to search for a simpler
examples in petsc src directories. But most of the ones I encountered are
with FEM (and I'm not familiar at all with FEM, so these examples serve
more as a distraction with FEM jargon!)
Bishesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131025/88f1ba9b/attachment.html>
