[petsc-users] Suggestions for code with dof >> 1 ?
Jed Brown
jedbrown at mcs.anl.gov
Wed Oct 23 10:39:09 CDT 2013
Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
>> Does a shorter time step fix the oscillations?
> Hi Jed,
> Thanks for the prompt reply.
> No, it did not in this case. However, I noticed for "smoother" cases that
> max timestep matters. I try to fix it to finaltime/100 to avoid too large
> timesteps. I also use -ts_adapt_basic_clip 0.1,1.1 to avoid large timesteps.
This just slows the rate of increasing time step.
>> Is this with
>> -ts_arkimex_type 1bee or something else?
> It occurs with 1bee, a2 or arkimex 3.
Stick with 1bee until we understand better.
>> Can you try -ts_arkimex_fully_implicit and add -snes_mf_operator if
>> necessary to get SNES to converge?
> I tried -ts_arkimex_fully_implicit and it gave a wrong result. As if there
> was no diffusion. Seems there is an artefact with fullyimplicit option.
That does not sound right. Can you send a reproducible test case (best
as a patch to PETSc)?
> With -snes_mf_operator I got an error message:
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Mat type mffd!
ALWAYS, ALWAYS, ALWAYS send the ENTIRE error message!
(Sorry about shouting, but I have to type this many times per day.
Truncating error messages kills kittens!)
>> (I'm assuming you have used an IMEX
>> formulation here, but perhaps you already use fully implicit?)
> I put everything under IFunction and IJacobian. This part is not clear to
> me actually. I understand that in IMEX methods, the LHS is solved
> implicitely and the RHS explicitely. What happens when I use an IMEX method
> with no RHS, everything in the LHS ? Is there any explicit stage ?
No, if the RHS is empty, it should reduce to an implicit method.
> Actually, I could solve the problem by adding mesh points. Since I start
> from steep gaussian distributions with large peak values, maybe there was a
> problem with large gradients.
> BTW, is it possible to have adaptive mesh in 1D with PETSc ? I am thinking
> of steep profiles that evolve and that require a fine mesh at the beginning.
You can do moving meshes (r-adaptivity) by writing coordinates as a
coupled system. Or you can create a new grid and interpolate. You can
use DMRefine and DMCoarsen.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131023/c646a1e6/attachment.pgp>
